POV-Ray : Newsgroups : povray.advanced-users : HDRI starfield Server Time
13 May 2025 11:03:55 EDT (-0400)
  HDRI starfield (Message 1 to 7 of 7)
Subject: HDRI starfield
Date: 10 Jan 2021 03:18:52
Message: <5ffab86c$1@news.povray.org>
Can anyone recommend an HDRI starfield texture that works with POV-Ray?
I haven't used HDRI ever before so I don't know what to look for. Thanks!
Michael
Subject: Re: HDRI starfield
Date: 25 Jan 2021 12:25:01
Message: <web.600efd3bd6c0391287570eab0@news.povray.org>
You didn't mention the context so I don't know what the starfield would be used
for, but there are some nice HDRIs at https://hdrihaven.com/hdris/ and even a
few with night skies.
If you just need something for a backdrop here's a simple noise-based texture
that might do the trick:
// Stars and Nebula
#declare T_StarField = texture {
      average
      pigment_map {
         [2
            bumps
            color_map {
               [0 rgb 0]
               [0.925 rgb 0]
               [1 srgb 0.6] // white (with emission)
            scale 1/2
         [2
            bumps
            color_map {
               [0 rgb 0]
               [0.925 rgb 0]
               [1 srgb 0.65] // white (with emission)
            scale 1/3
         [1.5
            bumps
            color_map {
               [0 rgb 0]
               [0.95 rgb 0]
               [1 srgb <0.75,0.75,0>] // yellow
            scale 1/4
         [0.5
            bumps
            color_map {
               [0 rgb 0]
               [0.95 rgb 0]
               [1 srgb <0.75, 0, 0>] // red
            scale 1/8
         [0.5
            bumps
            color_map {
               [0 rgb 0]
               [0.95 rgb 0]
               [1 srgb <0, 0, 0.75>] // blue
            scale 1/8
         [0.5
            bumps
            color_map {
               [0 rgb 0]
               [0.925 rgb 0]
            scale 1/16
   finish { emission 15 }
#declare T_Nebula = texture {
      bozo
      turbulence 0.75
      scale 0.125/2
      color_map {
         [0 rgbt 1]
         [0.7 rgbt 1]
         [0.8 srgbt <1, 0, 0.5, 0.75>]
         [0.9 srgbt <0, 0, 2.5, 0.75>]
         [1.0 srgbt <0, 2, 0, 0.75>]
      omega 0.65
      lambda 3
      octaves 5
      scale 10000*4
   finish { emission 0.0035 }
// Stars and Nebula
sphere { 0, 10000
   texture { T_StarField scale 10 }
   texture { T_Nebula scale 1 }
   texture { T_Nebula scale 1.5 rotate 45 }
   rotate 180
Cheers,
Rob
Date: 25 Jan 2021 18:03:42
Message: <600f4e4e$1@news.povray.org>
Ah, sorry. I meant for an Outer Space scene. Those are all ground-based
photographs.
Yeah, I'm using that. But you can tell they aren't point sources but are
blobb-ish smudges.
Mike
Date: 26 Jan 2021 06:17:09
Message: <600ffa35@news.povray.org>
> Michael
Not HDRI, but if you want to place actual objects as stars take a look
at BrightStar5 in the POV-Ray objects collection.
<http://lib.povray.org/searchcollection/index.php>
I used it in the opening sequence of this animation:
<https://youtu.be/GyqQolOK_qI>
m@
Date: 26 Jan 2021 17:37:04
Message: <60109990$1@news.povray.org>
>> POV-Ray? I haven't used HDRI ever before so I don't know what to look
>> for. Thanks!
>> Michael
> m@
Thank you!
The problem is that I use 1 meter resolution, and numbers in POV are not
64 bit.
Mike
Date: 27 Jan 2021 11:33:24
Message: <601195d4$1@news.povray.org>
>>> for. Thanks!
>>> Michael
>> m@
> Thank you!
> 64 bit.
> Mike
That should not be a problem. The various background constructions tend
to be scale independent.
In POV, the numbers are not 64 bit integer, they are double precision
floats, except for the colours that are in single precision during the
calculations.
Date: 29 Jan 2021 02:33:51
Message: <6013ba5f$1@news.povray.org>
Op 26/01/2021 om 00:03 schreef Mike Horvath:
>>> Thanks!
Retrospectively, after answering to Hj. Malthaner in p.b.i. ("The
Expanse" Fanart, WIP - Ship passing a ringgateintotheringspace) I
thought that you could use any deep space photograph from the net (NASA
has some stunning ones) and convert it to .hdr or .exr. Gimp or (even
better) IC from Lilysoft can do that. However, you will also need to
convert to a spherical projection. IC can do some 3d projections but not
sure about those in this context.
