POV-Ray : Newsgroups : povray.advanced-users : Apparent circular pattern of scratches Server Time
16 May 2024 03:49:27 EDT (-0400)
  Apparent circular pattern of scratches (Message 1 to 10 of 17)
Subject: Apparent circular pattern of scratches
Date: 22 Jan 2019 19:50:00
Message: <web.5c47b977410683ba765e06870@news.povray.org>
I'm sure everyone has seen this at some point:
When you look at a light source's reflection on a smooth piece of glass or metal
or plastic, the scratches all tend to appear as a series of arcs and lines
roughly in a circular pattern centered around the "hotspot".
I was wondering if anyone has ever attempted to replicate this effect, and
perhaps has an optical explanation for why the scratches appear in a circular
pattern.
https://st.depositphotos.com/1032492/3139/i/950/depositphotos_31397463-stock-photo-texture-of-scratched-metal-surface.j
pg
https://thumbs.dreamstime.com/thumblarge_2060/20605588.jpg
http://cpi.studiod.com/getty/caf73bdee00eeaa57d5e24c213f6b09c.jpg
http://www.performancemotorcare.com/blog/wp-content/uploads/2011/06/How_to_avoid_swirl_marks.jpg
https://www.wavesdetailpro.com.au/wp-content/uploads/2017/08/poi-1.jpg
..... you get the idea.
Subject: Re: Apparent circular pattern of scratches
Date: 23 Jan 2019 02:32:26
Message: <5c48188a$1@news.povray.org>
> pattern.
> pg
This one gets 404.
Let me try an explanation: assuming that all scratches are randomly
orientated, only those parallel(?) to the light source get reflected
maximally, all others are dimmer or - when perpendicular to the light
source - do not reflect at all.
Date: 23 Jan 2019 03:50:01
Message: <web.5c482a255e3f44509c5d6c810@news.povray.org>
> > pattern.
ce.j
> > pg
> This one gets 404.
Just needs the lopped off "pg" added to end. Same object as 2nd below, a smaller
size.
> Thomas
Not sure if that would be the way to put it, since mainly perpendicular
scratches are what reflect light most. Not parallel to the viewer/camera and
light source, because that would be along a line of view... I think.
Anyway... yes, this was something tried many years ago by me at least. I'm sure
others did too, probably before I ever did.
I couldn't locate a scene file of mine, and no luck finding anything online
either, so I retried something similar again now. Was to see how reflected light
formed those circular areas among twigs and thin branches (wet/icy is best).
So not exactly the scratches idea, mainly to show the effect on 'sticks', but I
did try that too and failed. My feeble attempt at a scene file here, notice the
white highlights on the sticks formed around the white sphere light_source:
// BEGIN SCENE FILE
//cmd: +w640 +h480 +am2 +a0.2 +r2
#version 3.7;
global_settings{ assumed_gamma 1.0 }
 perspective angle 90
 location <1.0, 3.0, -9.0>
    look_at <2.0, 3.0, 4.0>
light_source{< -6,-1,-9> color rgb <1,0,0> }
light_source{< 6,3,9> color rgb 1
 looks_like {sphere {0,1 pigment {rgb 1} finish {emission 1}}}
 area_light 1*x,1*y,8,8 area_illumination}
sky_sphere { pigment { gradient <0,1,0>
                       color_map { [0.0 rgb <0.3,0.2,0.1>]
                                   [0.2 rgb <0.1,0.1,0.1>]
                                   [0.5 rgb <0.0,0.0,0.0>]
                                   [1.0 rgb <0.2,0.3,0.5>]
                       scale 2
// checkered floor
plane{ <0,1,0>, 0
       texture{
        pigment{
        checker color rgb <0.5,0.5,0.5> color rgb <0.1,0.1,0.1>
        scale 5
        finish { phong 0.1}
       translate -9*y
// random sticks
    #for (R,1,333)
    #local S=seed(R*9);
    #local Rx=rand(S)*9;
cylinder {
 -x,x,1
    scale <3*Rx,0.1,0.1>
  pigment {rgb 0}
  finish {specular 1 roughness 0.05}
    rotate <0,90,180>*Rx
 translate <3*Rx,2*Rx,1*Rx>
    rotate <360,360,360>*Rx
    //scale 0.5
    translate <-3,1,13>
// reflective sphere with scratches/bumps?
sphere { <0,0,0>, 1.0 scale <1,1,1>
 texture { pigment {rgb 0}
     normal {
         average
                normal_map {
                #for (R,1,33) //create axis lines, rotate randomly
     #local S=seed(R);
                 #local Rx=rand(S)*3;
                     [1 function {(x)} bump_size 1 ramp_wave
                     frequency 33 rotate <0,360,360>*Rx]
                     [1 function {(y)} bump_size 1 ramp_wave
                     frequency 33 rotate <360,0,360>*Rx]
                     [1 function {(z)} bump_size 1 ramp_wave
                     frequency 33 rotate <360,360,0>*Rx]
     finish {
            specular 1 roughness 0.02 reflection {0.1,0.9}
 scale 3 rotate <0,0,0> translate <-3,1.5,3>
// reflective cylinder with curved scratches/bumps?
cylinder { <0,0,0>, <0,0,1>, 1.0 scale <1,1,1>
     normal {
         average
                normal_map {
     #local S=seed(R);
                     [1
                     //function {(x)}
                     onion scale <11,1,1>
                     frequency 50 rotate <0,360,360>*Rx]
                     [1
                     //function {(x)}
                     onion scale <1,11,1>
                     frequency 50 rotate <360,0,360>*Rx]
                     [1
                     //function {(x)}
                     onion scale <1,1,11>
                     frequency 50 rotate <360,360,0>*Rx]
     finish {
 scale 4 rotate <-10,-15,0> translate <-4,-6,6>
// END SCENE FILE
Date: 23 Jan 2019 06:46:26
Message: <5c485412@news.povray.org>
Well, I was not sure how to describe the orientation with regard to the
light source (and camera of course): parallel, perpendicular, a bit
confusing. You got the idea though.
Date: 23 Jan 2019 07:40:37
Message: <5c4860c5$1@news.povray.org>
Play with this (very rough):
#version 3.8;
global_settings {
   assumed_gamma 1.0
   location  <0, 100, -10>
   sky       y
   up        y
   direction z
   right     image_width/image_height
   angle     54
   look_at   <0, 0, 0>
light_source {
   <0,0,0>
   color rgb <1, 1, 0.7>*2
   translate <0, 50, 20>
background {rgb 0}
plane {
   y, 0
   pigment {rgb <0.1,0.1,0.1>}
   normal {
     average
     normal_map {
       [1.0 crackle 1.00 solid scale 1.5 warp {turbulence 0.05}]
       [0.4 granite 1.00 scale 0.001]
     scale 5
   finish {
     specular albedo 0.5
     diffuse albedo 0.5
     roughness 0.001
Date: 23 Jan 2019 16:55:01
Message: <web.5c48e23f5e3f44509c5d6c810@news.povray.org>
> Thomas
Maybe offset perpendicular... whatever. LOL
I like that crackle pattern idea, I was able to get the effect easily that way
going with your SDL.
Just probably needs a randomization of the averaged normal parameters.
Lighting/specular highlighting changes it drastically too.
/* from Thomas' circular scratches lighting effect */
   location  <11, 111, -11>
   sky       y
   up        y
   direction z
   angle     50
   look_at   <0, 0, -11>
light_source {
   <0,0,0>
   parallel point_at -y // spreads light
   area_light x*5,z*5,5,5
   area_illumination on // tones down shine
   translate <12, 123, 12>
background {rgb 0}
plane {
   y, 0
   normal {
     average
     normal_map {
       [1.0 crackle 1.00 solid scale <3,0.5,0.1>
       [1.0 crackle 1.00 solid scale <0.2,1,6>
       [1.0 crackle 1.00 solid scale <4,1.5,1>
       [1.0 crackle 1.00 solid scale <3,0.5,0.1> rotate 30*y
       [1.0 crackle 1.00 solid scale <0.2,1,6> rotate -30*y
       [1.0 crackle 1.00 solid scale <4,1.5,1> rotate 60*y
       [1.0 crackle 1.00 solid scale <3,0.5,0.1> rotate 45*y
       [1.0 crackle 1.00 solid scale <0.2,1,6> rotate -45*y
       [1.0 crackle 1.00 solid scale <4,1.5,1> rotate 22.5*y
     scale 3
   finish {
     specular albedo 0.3
     diffuse albedo 0.5
     roughness 0.001
Date: 23 Jan 2019 19:20:00
Message: <web.5c4903f85e3f44509c5d6c810@news.povray.org>
"omniverse" <omn### [at] charternet> wrote:
Retry of random sticks scene I posted before, thanks to Thomas for the different
pattern.
Still not sure what I'm doing with it, making guesses about warp {} and scaling.
Lighting and surface finishes really play a major part in how the scratches
appear. As does antialiasing and image/object size, to name other things.
// BEGIN SCENE
#version 3.8;
light_source { 0, color rgb <1,0.1,0.1>
 looks_like {
  sphere {0,3 pigment {rgb <1,0.1,0.1>}
  finish {emission <1,0.1,0.1>}
 area_light 1*x,1*y,8,8 area_illumination on
 translate <-6,-1,-9>
light_source { 0, color rgb 1
 looks_like {
  finish {emission 1}
 translate <6,3,9>
                       scale 2
// checkered floor
plane{ <0,1,0>, 0
       texture{
        pigment{
        scale 5
        finish { phong 0.1}
       translate -9*y
// random sticks
    #for (R,1,333)
    #local S=seed(R*9);
cylinder {
 -x,x,1
  pigment {rgb 0}
    //scale 0.5
    translate <-3,1,13>
#declare SphericalScratches=
material {
   normal {
    average
    normal_map {
 #for (R,3,33)
 #local S=seed(R);
 #local Rx=rand(S);
 #local Ry=rand(S);
 #local Rz=rand(S);
  [0.5+Ry/2
   crackle solid bump_size 3*Ry
   warp {turbulence 0.2*Rz}
   scale <0.9+9*Rx,0.2+0.3*Ry,0.5+1*Rz>
   rotate <9*Rx,360*Ry,9*Rz>
  [0.5 granite 1.00 scale 0.01]
   scale 1/10 // adjust for object size
     warp {spherical}
  finish {
   specular albedo 0.3
   diffuse albedo 0.5
   roughness 0.001
   reflection {0.05,0.5}
#declare CylindricalScratches=
material {
   normal {
    average
    normal_map {
 #for (R,3,33)
 #local S=seed(R);
 #local Rx=rand(S);
 #local Ry=rand(S);
 #local Rz=rand(S);
  [0.5+Ry/2
     warp {spherical}
  finish {
   specular albedo 0.3
   diffuse albedo 0.5
   roughness 0.001
material {
 SphericalScratches
} // material
cylinder { <0,0,0>, <0,1,0>, 1.0 scale <1,1,1>
material {
} // material
rotate 90*x
 scale 4 rotate <15,-15,0> translate <-6,-4,4>
// END SCENE
Date: 23 Jan 2019 20:05:01
Message: <web.5c490e395e3f4450765e06870@news.povray.org>
I would have never thought that using crackle would give rise to this effect.
I was experimenting with wood and ripples...
Yes, likely so.
This is getting close - something finer, less grainy, and with that "all other
scratches are invisible except the very few that reflect light" would be the
goal.   I'll hopefullly get a chance to try it out on something in a scene and
see how it works.
Also - pretty good for a plane --- now how do we achieve this on the surface of
a a 3D primitive?  Does the crackle / granite already take care of that?
We need a Scratched Sphere on a Checkered Plane scene... :)
Too many things to do lately, but this gave me the nudge to dig through the
source and look at how the crackle pattern is actually implemented, and I found
these comment gems that ought to make their way into the docs:
*   Large scale, without turbulence, makes a pretty good stone wall.
*   Small scale, without turbulence, makes a pretty good crackle ceramic glaze.
*   Highly turbulent (with moderate displacement) makes a good marble, solving
*   the problem of apparent parallel layers in Perlin's method.
*   2 octaves of full-displacement turbulence make a great "drizzled paint"
*   pattern, like a 1950's counter top.
*   Rule of thumb:  put a single colour transition near 0 in your colour map.
Very nice - I'm hoping this effect will get further honed into an include /
macro with a few options, so we can have a new easy-to-use tool for making more
realistic looking hard surfaces.
Date: 24 Jan 2019 02:36:07
Message: <5c496ae7$1@news.povray.org>
I guess that every surface perturbation would do the trick, except that
the more random the scratch patter the better the effect will look. Also
with straight, fairly long, scratches the effect will be stronger.
I was in a hurry when I posted my sdl and the render engine was busy
with a scene, but I wanted to use a scratch bump_map. I'll experiment today.
> Yes, likely so.
> see how it works.
Try a bump_map.
Now that you mention it, we have something like this by Przemek Loesch:
brushed_metal, from 2004, in p.b.s-f. Here it is:
//start code
   location <0,100,-1000>
   look_at <0,100,0>
   angle 60
light_source { <500,1000,-1000> rgb 1}
#declare fin = finish {reflection 0.1 specular 0.5 metallic}
#declare col = color rgb 1;
#declare t0 = texture {
   pigment {col}
   finish {fin}
#declare t1 = texture {
   pigment {bozo scale 50 rotate y*0 color_map {[0 col] [1 rgbt <1,1,1,1>]}}
   normal { pigment_pattern {waves warp {repeat x*100} color_map {[0,
rgb 0][1, rgb 1]} translate 0 scale 3} 10}
   finish {fin}
#declare t2 = texture {
   pigment {bozo scale 50 rotate y*30 color_map {[0 col] [.8 rgbt
<1,1,1,1>]}}
   normal { pigment_pattern {waves warp {repeat y*100} color_map {[0,
rgb 0][1, rgb 1]} translate 30 scale 3} 10}
   finish {fin}
#declare t3 = texture {
   pigment {bozo scale 50 rotate y*70 color_map {[0 col] [.7 rgbt
<1,1,1,1>]}}
   normal { pigment_pattern {waves warp {repeat z*100} color_map {[0,
rgb 0][1, rgb 1]} translate -30 scale 3} 10}
   finish {fin}
#declare metal =
texture {t0}
texture {t1}
texture {t2}
texture {t3}
sphere {<300,200,0>, 200 texture {metal}}
cylinder {<-400,200,0>,<0,200,600>, 200 texture {metal}}
plane {y,0 texture {metal}}
cone {<0,0,-100>, 150, <0,350,-100>, 0 texture {metal}}
sky_sphere {
     gradient y
     color_map {[0 rgb 1] [.5 rgb <0,0.3,1>]}
//end code
This might be a good start to investigate the matter at hand.
Yes, I remember those. Worth investigating further too.
Date: 24 Jan 2019 03:00:59
Message: <5c4970bb@news.povray.org>
Replace the normal {} as given, by this (download the bump_map):
   normal {
     bump_map {png "Scratches.png" gamma 1}
     rotate 90*x
     scale 10
     bump_size 1
Going into the right direction but it is more difficult than I initially
realised.
Download 'scratches.png' (345 KB)
Preview of image 'scratches.png'
