POV-Ray : Newsgroups : povray.advanced-users : Area light Server Time
13 May 2025 14:47:44 EDT (-0400)
  Area light (Message 1 to 9 of 9)
Subject: Area light
Date: 6 Aug 2018 01:57:30
Message: <5b67e34a$1@news.povray.org>
In one of my scenes, I have constructed my own area light by placing
multiple point lights using spherical coordinates, so that a bulb or sun
is simulated and shadows are smoothed a bit.
#if (Toggle_Area_Light = true)
	// my version of an area light, very slow
	#local light_radius		= RWorld_sun_radius;
	#local light_theta		= 0;
	#local light_theta_num	= 8;
	#local light_theta_dif	= 2 * pi/light_theta_num;
	#local light_phi_num	= 4;
	#local light_phi_dif	= pi/light_phi_num;
	#declare light_lumens	= 2/light_theta_num/light_phi_num;		// float
	#declare light_temp		= Daylight(5800);				// float
	#declare light_color	= Light_Color(light_temp,light_lumens);		// vector
	#for (i, 1, light_theta_num)
		#local light_phi = 0;
		#for (j, 1, light_phi_num)
			#local light_x = light_radius * cos(light_theta) * sin(light_phi);
			#local light_y = light_radius * cos(light_phi);
			#local light_z = light_radius * sin(light_theta) * sin(light_phi);
			light_source
				<light_x, light_y, light_z>
				light_color
			#local light_phi = light_phi + light_phi_dif;
		#local light_theta = light_theta + light_theta_dif;
#else
	#declare light_lumens	= 2;						// float
//	#declare light_color	= light_color * light_color;
	light_source
		0
		light_color
However, IIRC, POV-Ray's own area light syntax allows for similar
effects. What are the advantages of POV-Ray area lights over the method
I selected above?
Thanks.
Mike
Subject: Re: Area light
Date: 6 Aug 2018 04:51:42
Message: <5b680c1e$1@news.povray.org>
Am 06.08.2018 um 07:57 schrieb Mike Horvath:
> I selected above?
Firs of all, from a quick glance at your code it seems to me that you're
actually constructing a (uniform) light dome, not an area light. At
present, POV-Ray doesn't do light domes (except indirectly via sky
spheres and radiosity).
The difference between a light dome and an area light is that a light
dome covers an entire hemisphere (or even an entire sphere), while an
area light is (or simulates) a localized array of light sources.
Now if we're talking about area lights, the advantages of genuine area
lights over a homebrew array of light sources is as follows:
- Easier to set up.
- Lower memory footprint (which may also improve render speed due to
better CPU cache utilization).
- [optional] Adaptive sampling of the shadow rays, tracing as few as 4
rays per area light if it is unobstructed or completely obstructed, but
as many rays as you like if it is partially obstructed (in a process
similar to adaptive anti-aliasning), for faster rendering at high quality.
- [optional] Jittering of the "lightlets" to break up pattern-like
artifacts caused by the regular arrangement of the lightlets, trading
them for less obvious noise-like artifacts.
- [optional] Substituting a single light source for the entire area
light in certain computations, most notably diffuse and specular
shading, for faster rendering at low cost in quality.
- [optional] Dynamic re-orientation of the area light to simulate a
spherical (as opposed to flat disc-like or rectangular) light source
without having to add more lights for same quality.
- Possibly one or two other optimizations that I may currently be
forgetting about.
There are, of course, also drawbacks:
- Less flexibility in the arrangement of "lightlets" (you're stuck with
lines, rectangles, discs, and quasi-spheres).
- Non-ideal "lightlet" pattern in the spherical case, potentially
leading to (usually subtle) directional artifacts.
As mentioned above, POV-Ray does not provide an area-light-like
mechanism for light domes. What you /can/ do however is create a light
dome out of area lights, probably allowing you to get away with fewer
light sources.
Date: 6 Aug 2018 05:32:49
Message: <5b6815c1$1@news.povray.org>
>> I selected above?
Ah, sorry. The lights I created are located at the center of a solar
system, so they cover a relatively small area of the much larger scene.
So I am wondering if it might not just be easier to replace the lights
(the sun) with one area light.
Mike
Date: 6 Aug 2018 07:34:44
Message: <5b683254$1@news.povray.org>
When using the `circular` keyword, is there an ideal area light size one
should show preference to? Odd numbers? Some pattern of integers?
Mike
Date: 6 Aug 2018 08:20:01
Message: <web.5b683c06ccf38e97c42a86fe0@news.povray.org>
snipped
> I selected above?
> Thanks.
> Mike
a disadvantage of area lights is that it affects media as a point source.
Date: 6 Aug 2018 09:53:19
Message: <5b6852cf$1@news.povray.org>
Am 06.08.2018 um 13:34 schrieb Mike Horvath:
If you intend to use `adaptive`, go for 2^N+1, e.g. 9, 17 or 33, just
like you would for a rectangular area light.
Date: 6 Aug 2018 09:54:25
Message: <5b685311@news.povray.org>
Am 06.08.2018 um 14:16 schrieb green:
Which might be an advantage performance-wise, if the light is reasonably
far away from the media container.
Date: 6 Aug 2018 12:50:50
Message: <5b687c6a@news.povray.org>
>>> I selected above?
> Mike
Yes
area_light RWorld_sun_radius*x RWorld_sun_radius*z 33 33 circular orient
adaptive 0
This will simulate a spherical light
circular squish the area_light into a circle.
orient always make that circle perpendicular to the point currently been
rendered.
adaptive 0 start the sampling with a 2*2 array and subdivide it as needed.
Date: 6 Aug 2018 12:52:20
Message: <5b687cc4$1@news.povray.org>
or 65, 129, 257,...
