Can anyone recommend the scripts on this site?
http://www.econym.demon.co.uk/isotut/approx.htm
I am currently rendering an image of my LCH color solid isosurface, and
it is at 11% after 2.2 hours. And so far only the easiest parts.
Do you think I could benefit from converting to a mesh instead? Or is
the benefit only if you want to render the scene multiple times (such as
an animation)?
Thanks.
Mike
> an animation)?
> Thanks.
> Mike
I tried it and it's a bad choice I think. Edges aren't sufficiently
sharp and smooth.
Mike
Yes Mike's page is a treasure trove of hints and examples.
Thomas used Mike's Cityscape in our image "Dhalgren".
I have not used the isosurface approximation macro but I notice that
there are two files adapted by Jaap Frank. I have a couple of macros
written by Jaap and they work very well.
Oh! Joy. :)
> an animation)?
But you might want to render it many times as you adjust things like
your texture or camera view. Just a thought.
Looking at your image in p.b.i. it is quite regular. I would try the
approximation macro.
Regards
>> an animation)?
>> Thanks.
>> Mike
> sharp and smooth.
Did you use the version with subdivision and variable depth?
And you can always edit it to give sharp edges. In fact I would edit it
anyway to make some faces flat and the curved face smooth.
Regards
>>> an animation)?
>>> Thanks.
>>> Mike
>> sharp and smooth.
Yes, I tried with subdivision and the following values:
#declare isoSegs = <32,32,32>;
#declare Depth = 3;
The edges are still too rough. I've attached the result. I'm not good
with modifying meshes by hand, so I will forego doing that. I will
instead wait for the true isosurface to finish rendering.
There's one thing I'm worried about though. The place where the
isosurface meets the cylinder showed holes or gaps last time I rendered
a test image. But hopefully decreasing "accuracy" will clear up the issue.
Mike
Download 'cielch_color_solid_cylinder_isosurface_mesh.png' (181 KB)
Preview of image 'cielch_color_solid_cylinder_isosurface_mesh.png'
> #declare Depth = 3;
Yes, that is rough and I wouldn't want to clean it up, myself.
I have had to abandon several projects because the future did not arrive
fast enough and my machine was vastly underpowered for what I wanted to
do. :(
Regards
>>>> (such as
>>>> an animation)?
>>>> Thanks.
>>>> Mike
>>> sharp and smooth.
> #declare Depth = 3;
> Mike
It's a accuracy isue, but not the one you think of. It's a isue of
floating point accuracy, or FPU accuracy.
In this case, try increasing the overall scale of your scene by 10: Put
every objects and light_source into an union and add scale 10, then
apply the same to the camera by multiplying the location and look_at
also by 10.
