![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
OK, have a look at this:
#macro Rectangle(A, B, C, D, r)
sphere {A, r}
sphere {B, r}
sphere {C, r}
sphere {D, r}
cylinder {A, B, r}
cylinder {B, C, r}
cylinder {C, D, r}
cylinder {D, A, r}
As you can see, this draws a wireframe rectangle between 4
user-specified points in space.
Assuming that all 4 points are actually co-plannar, what would the *the
simplest* way to fit a box{} object into the middle of the thing?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Actually it's not enough for the points to be coplanar, they must also
form a perfect parallelogram or else 1 box will not do. If the shape is
not a perfect parallelogram then you'll have to use at least the difference
of two or three boxes.
Of course you could go the easy way and close that object with
polygons or even triangles, unless you really want it to be solid,
in which case you'll have to either go with the boxes or use eg.
planes.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> planes.
Used for CSG --> I'd like it to be solid.
Hmm... planes is a good idea though!
(Actually, the code that generates the 4 points guarantees them to form
a rectangle. To be specific, A and B are identical except for the Z
coordinate, as are C and D...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> sphere {A, r}
> sphere {B, r}
> sphere {C, r}
> sphere {D, r}
> cylinder {A, B, r}
> cylinder {B, C, r}
> cylinder {C, D, r}
> cylinder {D, A, r}
> #end
Use Matrix_Trans() or Shear_Trans()
(These are macros in transforms.inc)
This may also be relevant:
"How to transform a triangle into another", 2. October 2002
http://news.povray.org/povray.text.tutorials/thread/%3C3D9B843D.E5392CD0@hotmail.com%3E
http://tinyurl.com/nwvck
Tor Olav
http://subcube.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I don't think that's a guarantee of rectangularity nor even
parallelogramity.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That will only work if the points form a perfect parallelogram.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, that's true.
(But I assumed that he wanted to use his macro for his wireframe
letters. See his latest post in povray.binaries.images)
Tor Olav
http://subcube.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> parallelogramity.
Why not?
Oh, did I not mention that A and C have *the same* Z coordinate? (As do
B and D...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks for the tip! :-D
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This seems to work...
#macro DrawPoly(Points, Radius)
#local A = Points[0];
#local B = Points[1];
#local C = Points[2];
#local AB = B - A;
#local AC = C - A;
#local Norm = vnormalize(vcross(AB, AC));
#local V1 = Norm;
#local V2 = vnormalize(AB);
#local V3 = vcross(V1, V2);
prism
linear_sweep
linear_spline
-Radius, +Radius, dimension_size(Points, 1),
#local lp = 0;
#while (lp < dimension_size(Points, 1))
<vdot(V3, Points[lp]), vdot(V2, Points[lp])>
#local lp = lp + 1;
translate +y*vdot(A, Norm)
Reorient_Trans(y, Norm)
In case it way be of use to anybod else...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
