![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi All,
I have been using POVRAY to generate explosion movies. My first question is
that how is it that density has been linked to the color of the media and
there is no facility to specify the transparency of the media in POVRAY? If
we look in particular at explosion then color is a function of temperature
and transparency is a function of density.
Can anyone please suggest how the transparency of the media can be
specified?
Thanks a lot
Maurya
http://www-scf.usc.edu/~mauryash
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> specified?
The color specifies both the color and the transparency of the media.
In chromatic terms, the hue/saturation of the color specify its color,
and the brightness specifies its transparency.
That is, for example if you want an orange media you would use
rgb <1, .5, 0>. If you want to make it more transparent, diminish its
brightness. For example if you want to increase its transparency
by half, use rgb <.5, .25, 0>.
The color of the density specifies how the light passing through it
is filtered.
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:40288afc$1@news.povray.org...
> specified?
In media scattering, the extinction keyword gives more control on
"transparency" (actually absorption) for artistic purposes.
Btw, the explosion pics on your site are very nice. Is a full animation
available ? And would the code be available for a patched version of
POV-Ray?
G.
http://www.oyonale.com
- Graphic experiments
- Posters
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Gilles,
Thanks for your comments.
Unfortunately I cannot give a full movie right now, I have to take certain
permissions.
However, I would certainly love to contribute back to POVRAY.
The features I have added so far are -
1) Hermite interpolation - its better because it gives smoother
interpolation and uses more information
2) Given a density mass, the user can specify a threshold and an epsilon, so
that all the values below
threshold-epsilon are clamped to zero and and those between threshold
to threshold-epsilon are
smoothly interpolated towards zero. This is basically to get different
shapes with the same density
volume without getting any artifiacts due to truncation by a threshold.
3) Use of temperature instead of density to specify the color of the media.
Adding perlin noise to the
color values to simulate the details.
I am new to the open source community and not quite sure of the procudures
involved in here. But
surely if these features are useful to others I will be glad to clean them
up first and share it with others.
Maurya
"Gilles Tran" <tra### [at] inapg inra fr> wrote in message
news:4028cca7@news.povray.org...
> > specified?
> POV-Ray?
> G.
> - POV-Ray and Poser computer images
> - Posters
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <402b0c90@news.povray.org>,
Interpolation of what? Is this some kind of spline-based integration for
media, like Simpson's rule, or is it a new spline type? Or something
else?
> epsilon, so that all the values below threshold-epsilon are clamped
> to zero and and those between threshold to threshold-epsilon are
> different shapes with the same density volume without getting any
I'm not sure of what use this is. It sounds fairly trivial to do with a
function pattern.
How is this different from just using a density pattern and density map?
Sounds like just a multiplier for the density color...
> Adding perlin noise to the color values to simulate the details.
Could you explain further? Are you adjusting the final computed values,
some kind of 2D modulation of the media?
> procudures involved in here. But surely if these features are useful
> to others I will be glad to clean them up first and share it with
> others.
Well, first, POV isn't open source. ;-)
The source code is available, and it is allowed for you to distribute
modified versions, but there are more restrictions than what you get in
a "true Open Source" license.
Just clearly mark the locations of your changes/additions, and
distribute the modified files, or if the patch is simple enough, the
modified portions and instructions on where to put them. It'd be a good
idea to follow the MegaPOV conventions...that's about as standard as it
gets. More info here:
http://megapov.inetart.net/manual/internals.html
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: <chr### [at] tag povray org>
http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Tue, 10 Feb 2004 13:24:35 +0100, "Gilles Tran" <tra### [at] inapg inra fr>
>POV-Ray?
I must assure you the animations are incredible (Maurya contacted me
some time ago about this project).
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
