![](/i/fill.gif) |
"HenryW" <pov### [at] henrywagner org> wrote in message
news:web.3f43c86f4e495bb8aa8c3f990@news.povray.org...
> I've been working on a POV model of a football stadium:
> http://www.henrywagner.org/povray/images/POPMart2.htm
> http://www.henrywagner.org/povray/images/POPMart3.htm
> Currently the model is generated using the POV scripting syntax to
generate
> the stadium out of triangles in the shape of an ellipse. As I add more
> details, the number of triangles is getting out of control. Today it hit
> me, I could just define the points that make up the profile and "sweep"
the
> stadium out with lathe or sor, but I haven't been able to figure out how
to
> create the elliptical shape. One idea is to create a spherical stadium and
> use "scale" to stretch it along one axis, but I don't think that will look
> right. Is there away to sweep an object along an elliptical path? Any
other
> ideas of how to speed this up?
I passed this message up before thinking someone would give you some kind of
answer before now. I was thinking perhaps something Tor Olav Kristensen has
done in the past might help. Mainly because he's done some great things with
manipulating POV-Ray objects. Unfortunately I'm not finding the exact thing
to show you. Only this:
http://news.povray.org/povray.general/23254/
But there's also 'prism', which could be plotted out into a ellipse and be
made conical at the same time. Might take a little learning if you're
unfamiliar with it but that would be my best suggestion.
Well, maybe you can adjust this one:
// stadium
prism {
conic_sweep
cubic_spline
0.5, // height 1
1, // height 2
22, // number of points
/* now the uv vectors */
// inner
< -0.5, -1.5>*0.9,
< 0, -2>*0.9,
< 1, -1.5>*0.9,
< 1.25, 0>*0.9,
< 1, 1.5>*0.9,
< 0, 2>*0.9,
< -1, 1.5>*0.9,
< -1.25, 0>*0.9,
< -1, -1.5>*0.9,
< 0, -2>*0.9,
< 0.5,-1.5>*0.9,
// outer
< -0.5, -1.5>,
< 0, -2>,
< 1, -1>,
< 1.25, 0>,
< 1, 1>,
< 0, 2>,
< -1, 1>,
< -1.25, 0>,
< -1, -1>,
< 0, -2>,
< 0.5,-1.5>
pigment {rgb 1}
scale <1,0.667,1>
![](/i/fill.gif) |
![](/i/fill.gif) |
gonzo wrote:
>>news:web.3f43c86f4e495bb8aa8c3f990[at]news.povray.org...
>>generate
>>the
>>to
><snip>
>Or maybe a combination of the two... Make spline of your profile, then make
>a lathe object and union it with prisms made from the same spline. Prism
>requires a closed spline so you probably have to use lathe rather than SOR.
>RG
Thanks for the tips! Currently I'm working on the triangle based version,
though I think I'm going to need more memory ;-)
Henry
![](/i/fill.gif) |
