POV-Ray : Newsgroups : povray.advanced-users : Preferable OS for fastest rendering? Server Time
11 Apr 2026 03:28:25 EDT (-0400)
  Preferable OS for fastest rendering? (Message 1 to 10 of 13)
Subject: Preferable OS for fastest rendering?
Date: 18 May 2003 12:51:53
Message: <3ec7ba29@news.povray.org>
Does anybody know, when using the same hardware
what operation system will offer fastest rendering time
for current version of POV, compiled with the best compiler
available?
E.g. for PC i32:
- DOS
- W98
- W2K
- WXP
- Unix * v*.*
- Linux * v*.*
(Assume that PC is powerful enough to run any of them
and their configuration is oriented to get the fastest result)
Is the difference significant(say, >10-20%)
Is it scene-dependent(fastest parsing vs fastest rendering)?
Gleb
Subject: Re: Preferable OS for fastest rendering?
Date: 18 May 2003 21:11:17
Message: <3EC82F28.8070207@hotpop.com>
> E.g. for PC i32:
> - DOS
> - W98
> - W2K
> - WXP
> - Unix * v*.*
> - Linux * v*.*
Since the code to build povray is almost exactly the same for every
versions of Povray, it'd say the biggest bottleneck is with the system.
I'd say (though I don't have any true data about this) that Linux would
be the fastest of all.  (Forget about Unix on a PC, and I'd say DOS is
pretty obsolete now)
Why?  Simply because I've tried many things that are exactly the same,
games like Unreal Tournament would run much faster on Linux instead of
WindowsXP.
I also get higher frame rate when running my own home written programs
on linux instead of WindowsXP.
Another good thing about linux is that at some time (about a year ago) I
started an animation render, the animation was a 1 minute (1500 frames)
of pure psychedelism, a camera looking through a lens at a wonderful
scene, my computer was render 24/24h, 7 days a week at 100% capacity (oh
and my CPU was overclocked, 433->527Mhz!) and this for about 30 days
without any kind of problems.
(At the end I had to cancel the render because after 30 days it was only
at 50 frames!)
But frankly, I wouldn't bother changing OS for speed, change OS for
suitability; I personnally prefer Linux...
Hope this helps..
   Xilo
Dedicated to audio/visual and interactive artwork.
http://www.geocities.com/simonlemieux/
Date: 19 May 2003 02:58:30
Message: <0mugcvoav23t5q18knr8gerav7d9ekmu8p@4ax.com>
On Sun, 18 May 2003 21:11:04 -0400, Xilo Musimene <xil### [at] hotpopcom> wrote:
> > E.g. for PC i32:
> > - DOS
> > - W98
> > - W2K
> > - WXP
> > - Unix * v*.*
> > - Linux * v*.*
But the compiler and optimization flags are different.
Considering that the most popular compiler for Linux is GCC (because available
"as is") and the most popular compiler for Windows is Intel C++ (because used
for official binaries) then I think you are wrong. Binary used on _the_same_
architecture with _the_same_ amount of CPU time will be faster on Windowses IMO.
The other thing are priority settings, memory swapping, need of other parallel
work and
You might be surprised, but when the altiernative is to perform development on
Windows platform without buying compiler then the fastest free compiler under
Windows is... DJGPP working in DOS box. See
http://news.povray.org/povray.unofficial.patches/30656/
> WindowsXP.
POV-Ray is not a game. It does use different type of computation (better
accuracy) and it does not take benefits from some CPU goodies for simple
floating point accuracy as it is done in games. Such comparison is bad.
This is not argument for anything except bad compiler with poor settings used
somewhere.
So ? I computed one still image 8000x8000 pixels on Windows NT within whole
month too and without any kind of problems. Problem of stability under Windowses
had gone long time ago. With careful administrator there is no problem with it.
Note it is not an OS flame war - I tried to point out how useless your arguments
are. For real POV driven production in long run I also think Linux based render
farm can be better thought users of this production line can take benefits from
using Windowses without any shame.
ABX
Date: 19 May 2003 06:30:19
Message: <3ec8b23b@news.povray.org>
  But since the official Windows compile is noticeably faster than a
DOS-djgpp compile, it's kind of non-productive to switch to a slower
version.
Date: 19 May 2003 06:41:33
Message: <9pchcvo9qkdtcs53q9a5g3itlum02h3fqg@4ax.com>
> version.
Sure. My fault. I meant 'development' of patched POV in this sentence when whole
context was about development using official package.
ABX
Date: 19 May 2003 07:42:32
Message: <3EC8C32A.5070104@hotpop.com>
Anyway, what I just said was just my opinion over my own personnal
experience.
Date: 19 May 2003 15:54:58
Message: <3ec93692$1@news.povray.org>
> work and
Since there is a free available version of the Intel C++ Compiler, I
wonder, if anyone has tested, compiling povray under linux with this
compiler, and if the speed differences are significant.
Florian Pesth
Date: 20 May 2003 07:41:00
Message: <3eca144c@news.povray.org>
I have made icc binaries, you can get them from
http://www.povworld.org/povray/binaries.html
(some test times can be found somewhere in the newsgroup archive)
- Micha
POV-Ray Objects Collection: http://objects.povworld.org
Date: 20 May 2003 07:48:03
Message: <4d5kcv0eitvq9s93uf9seo5o70f4fh1bfb@4ax.com>
http://news.povray.org/povray.unix/26169/
ABX
Date: 20 May 2003 09:30:11
Message: <3eca2de3@news.povray.org>
> ABX
Thanks, both of you!
Florian Pesth
