POV-Ray : Newsgroups : povray.advanced-users : --( Input/Output TEXT - Assign to Variables )-- Server Time
30 Jun 2026 11:30:37 EDT (-0400)
  --( Input/Output TEXT - Assign to Variables )-- (Message 1 to 3 of 3)
Subject: --( Input/Output TEXT - Assign to Variables )--
Date: 19 Mar 2003 17:53:56
Message: <3e78f504@news.povray.org>
--------------( oo )--------------
I'm looking for a way to keep in memory some Variables over a frame state. I
tought using Input/Output text (.txt) as external parameters in POVRAY to
keep an initial state and reimport every state at the begining of each new
frame.
My problem is that I have scene state wich is the position of every state of
Cells on a Grid and I would like to be able to call back the previous state
of cells after each frames. This could be formatted in a .txt file.
Is there a way to Input/Output text and assign text elements to new
variables?
Is there a way to keep Variable defined over an animation?
I'm currently working on Cellular Automata and Genetic Algorithms. I'm
planning to use PovRay for renders. I have states wich is the position of
the elements in the scene. The previous state influence the second for each
frames.
Architecture CAAO Website[UDM]-
http://ps.dgtic.umontreal.ca:2050/data/p0034/site
Subject: Re: --( Input/Output TEXT - Assign to Variables )--
Date: 19 Mar 2003 18:52:32
Message: <3e7902c0@news.povray.org>
So, if its just data (floats, vectors up to 5 dimensions), I've got
some IO-Macros on my homepage designed for ease of use:
#declare Array=array[x][y] { ... }
Save_Array(Array,"filename.ext")
#declare Array=Load_Array("filename.ext");
As for filenames, you'd have to save them in strings, but my
system wasn't designed (and tested) for that. Concerning the
state-loading:
#if (frame_number=0)
 [Initial setup]
 Save_Array(Initial_Data,"somedata.tmp")
#else
 #declare Initial_Data=Load_Array("somedata.tmp")
This way, the initial frame will calculate the new data into an
array, and every frame thereafter will load the data. This assumes
that your first frame is 0, not 1 (which you would have to change
in the if-statement).
To generate identifiers, it is possible to "parse" strings:
#declare String="#declare Variable="
Then write this to HD and #include the newly created file.
I'm not so sure if "#declare Variable=" works though, cause
I think that you'd have to define the part behind "=" inside
the include-file as well, but you might experiment with that
knowledge...
Hope this gets you going,
Tim
Tim Nikias v2.0
Email: Tim### [at] gmxde
I
> frame.
of
state
> variables?
each
> frames.
Date: 20 Mar 2003 13:19:30
Message: <3e7a0632$1@news.povray.org>
Danke Tim!
I'll try to experiment with that and I'll give you informations.
"Tim Nikias v2.0" <tim### [at] gmxde> wrote in message
news:3e7902c0@news.povray.org...
> state-loading:
>  [Initial setup]
> #else
> #end
> knowledge...
> Tim
> Tim Nikias v2.0
> Homepage: http://www.digitaltwilight.de/no_lights
state.
> I
to
new
> > frame.
state
> of
> state
> > variables?
of
> each
> > frames.
