POV-Ray : Newsgroups : povray.advanced-users : Can PovRay pre-parse a file and then render from this file Server Time
30 Jun 2026 13:02:51 EDT (-0400)
  Can PovRay pre-parse a file and then render from this file (Message 1 to 5 of 5)
Subject: Can PovRay pre-parse a file and then render from this file
Date: 26 Nov 2002 23:37:31
Message: <3de44c0b@news.povray.org>
I have implemented a distributed renderer using the PovRay engine. I have
only gotten a 67% (best) (%60 worst so far 16 min vs. 40 min. The ideal max
is 80%) speed improvement on 5 nodes. One of the major wastes of time is
that each node parses the data and the parsing time of the image is
non-trivial. Also the image is split into more chunks than nodes for load
balancing reasons (So if there are 100 chunks time parse time which is
static, you see the problem). Also I have access to a lot more nodes and I
would like to use them  but the benefit of them is going to decrease unless
I can get rid of the parse time (as chunk size goes down (aka more
chunks/nodes) parse time has more of effect).
So what I need is a way to parse once (by the master node) and render from
the pre-parsed file.
    A) Has any one created a way to extract/read pre-parsed data?
    B) Know how to do it with no or about 2 days of coding?
Any help is appreciated!!
-James
Subject: Re: Can PovRay pre-parse a file and then render from this file
Date: 26 Nov 2002 23:50:59
Message: <chrishuff-F77A36.23481326112002@netplex.aussie.org>
It is not possible. Or rather, there are too many dynamic structures, it
would be a huge amount of work to write code to serialize and
reconstruct all of them, especially since they were never designed to
allow this. There is no "pre-parse" stage, most of the scene is created
as the file is parsed, except for things like radiosity and photons
which are computed immediately after parsing. The best solution for
anything based on POV is to have each node parse the scene.
http://tag.povray.org/
Date: 27 Nov 2002 10:19:45
Message: <3de4e291$1@news.povray.org>
Dam, that is not the answer I wanted to hear :)! Currently each node does
parse the scene before rendering it.
Thanks for the answer!
-James
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
from
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 27 Nov 2002 15:26:39
Message: <uaaauukvee3a5u5ugrcicr9gjdgccn544j@4ax.com>
James,
sorry I pop up like that as my question is completely off-topic in
this thread, but could you please re-post your bug report, this time
with a valid email address, so that the bug report moderator can
contact you back? Thanks.
Peter Popov ICQ : 15002700
Date: 27 Nov 2002 16:16:20
Message: <3de53624$1@news.povray.org>
I will repost it later today when I get home (the message is stored on my
home machine).
"Peter Popov" <pet### [at] vipbg> wrote in message
news:uaaauukvee3a5u5ugrcicr9gjdgccn544j@4ax.com...
> James,
> Personal e-mail : pet### [at] vipbg
> TAG      e-mail : pet### [at] tagpovrayorg
