POV-Ray : Newsgroups : povray.advanced-users : Blobs in Macros... Server Time
29 Jul 2024 08:19:47 EDT (-0400)
  Blobs in Macros... (Message 1 to 7 of 7)
Subject: Blobs in Macros...
Date: 27 Oct 2002 05:20:21
Message: <3dbbbde5@news.povray.org>
I've got following problem:
My Particle System allows the usage of macros to define
particles. Now I've set a macro which places blob-spheres.
The system is called inside a blob{}-statement, so I'd
expect POV to parse, find the macro, use it, place the
components, and render just fine.
I know that POV can't issue a warning for macros, because
parameters for the macro may be set after the declaration
of the macro itself. But why does POV tell me
Parse Error: No mathing } in "sphere", , found instead
(that last "," is referring to the comma between the
radius and the strength)?
Is there actually any possibility to place components with
macros that are called from inside a macro?
Even if I place blob{} around the include file with
the macro which will call the particle-macro, it doesn't
work. Any ideas?
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: Blobs in Macros...
Date: 27 Oct 2002 14:21:35
Message: <chrishuff-D52370.14145527102002@netplex.aussie.org>
In article <3dbbbde5@news.povray.org>, "Tim Nikias" <tim### [at] gmxde>
I've never had this problem. Are you ever trying to declare a component
in your macros?
http://tag.povray.org/
Date: 27 Oct 2002 14:39:56
Message: <3dbc410c$1@news.povray.org>
Its not declaring a component, but placing one. Any clues?
Tim Nikias
> in your macros?
Date: 27 Oct 2002 15:29:52
Message: <3dbc4cbf@news.povray.org>
A minimalistic example showing the problem would be helpful.
Date: 27 Oct 2002 15:54:05
Message: <3dbc526d@news.povray.org>
I don't get. In the file I tried it with, it never worked.
Then, I remodeled it, in order to use several
cylinders and spheres instead of blobbing components.
After Warp asked for a small example, I fiddled with
an example, and it worked. Thus, I went back to the
scene-file and experimented with it, trying to get back
to the state when I tried to use blob-components in
the macro.
And now it works. I must have screwed up something pretty
bad, seems like it does work after all. Perhaps I had a
closing bracket somewhere, and when the first particle
was placed, POV thought the blob-object was complete,
tried to put a sphere, and then found the strength-variable,
which isn't required in a simple sphere...
I promise, the next time I'll be more thorough. sorry for any
troubles I caused, and thanks for your concern...
Tim
Tim Nikias
Date: 27 Oct 2002 16:00:08
Message: <chrishuff-503187.15532927102002@netplex.aussie.org>
In article <3dbc410c$1@news.povray.org>,
Show some code?
Date: 27 Oct 2002 16:44:28
Message: <3dbc5e3c@news.povray.org>
Tim Nikias <tim### [at] gmxde> wrote:
> Perhaps I had a
  That's why a good, clear and consistent indentation scheme is useful.
When you get accustomed to one, you never make such errors. :)
  (I know, "never say never", but still... :) )
