POV-Ray : Newsgroups : povray.advanced-users : Pov-ray units Server Time
11 Apr 2026 14:26:42 EDT (-0400)
  Pov-ray units (Message 1 to 10 of 12)
Subject: Pov-ray units
Date: 19 Mar 2002 16:16:28
Message: <3c97aaac@news.povray.org>
What is a pov-ray unit ? 1 milimeter ? 1 centimeter ?... I think that
question can help me to find the good scale for lightening, medias... Thanks
Subject: Re: Pov-ray units
Date: 19 Mar 2002 16:42:40
Message: <3C97B131.8EE01503@LuxLab.com>
It is whatever you want it to be.
_____________
Kari Kivisalo
Date: 19 Mar 2002 18:16:49
Message: <3c97c6e1@news.povray.org>
Personally I use one unit = one centimeter, because the things I model are
easier to code with numbers of that scale. But whatever is best for you, the
important thing is to adjust the camera angle, so the result doesn't look
like a fish-eye (unless this is desired). My own trial-and-error made me
decide always to use "angle 48" in ordinary camera statements, as this seems
to fit my unit scale.
I also would advide you to write in all your scenes, that you want to share
with people, what scale you use, so we can adjust it to ours if necessary.
:o)
Hugo
Date: 19 Mar 2002 19:42:41
Message: <3c97db00@news.povray.org>
  Not really. Even if I want one pov-unit to be one kilogram, that doesn't
make much sense, does it? ;)
Date: 19 Mar 2002 20:17:10
Message: <chrishuff-04AE24.20171619032002@netplex.aussie.org>
In article <3c97db00@news.povray.org>, Warp <war### [at] tagpovrayorg>
It does on a graph. ;-)
Date: 20 Mar 2002 01:20:53
Message: <3c982a45@news.povray.org>
seems
You know, the scale of your scene should affect the camera angle necessary.
If you change the scale of your scene (including the camera position and
look_at point) uniformly, the scene should look *exactly* the same. (unless
there's media, in which case you have to multiply the density of all your
media by one over whatever factor you changed the scale by.) It's likely
that your angle change would be necessary no matter what scale you use; it's
probably just your preference for the appearance of your scene.
To answer the original question, as people have said, the scale is
arbitrary... when you have empty, undefined space, who cares if the distance
from point A to B is a mile or a millimeter? If you have complete control
over the appearance and size of objects (as you do in POV-Ray), the distance
from A to B is whatever you want it to be. So, choose a scale that will be
most convenient to you.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 20 Mar 2002 04:31:08
Message: <3c9856dc$1@news.povray.org>
> and look_at point) uniformly, the scene should look *exactly*
> the same.
Oh really.. Thanks for telling!  :o)  I fooled around with this years ago,
and left the subject as I found a way to make it look good..
> it's probably just your preference for the
Yes.. I thought angle was linked to scale factor but okay.. :o)
Hugo
Date: 20 Mar 2002 14:39:32
Message: <amnh9ug2qiibscp99hsdum6p8a9rs680kt@4ax.com>
Try to tell this to the particle system nuts around here. :)
Peter Popov ICQ : 15002700
Subject: Re: PS-Nuts
Date: 21 Mar 2002 14:19:54
Message: <3C9A3257.9ECB4E5F@gmx.de>
Hm. I don't get it.
Try to tell me, seriously. POV-Units and
kilogramms? Where is the connection to a
particle system?
Peter Popov said something like:
Tim Nikias
Date: 21 Mar 2002 15:42:39
Message: <j6hk9uolvoh9b9m9l0am1v647hctraq18k@4ax.com>
On Thu, 21 Mar 2002 20:19:51 +0100, Tim Nikias <tim### [at] gmxde>
>particle system?
In what other way would you calculate gravity?
