POV-Ray : Newsgroups : povray.advanced-users : Clouds Server Time
13 Nov 2025 09:16:41 EST (-0500)
  Clouds (Message 1 to 10 of 14)
Subject: Clouds
Date: 3 Mar 2002 22:29:35
Message: <3c82ea1f$1@news.povray.org>
Alright, I've got some really neat looking clouds using the stacked planes
method, but it only looks good at lower resolutions. So when I increase the
resolution, I increase the number of layers. However, when I get to the
point of over 100 or so layers, POV-Ray says: Too many nested refraction
objects. I assume this has something to do with stack overflows from the
recursion?
Is there anyway around this? If I decrease the max_trace_level, I get black
sillouts of the disc object, but if I don't have enough disks, you can see
the individual layers. Any ideas?
Subject: Re: Clouds
Date: 3 Mar 2002 23:48:06
Message: <3c82fc86@news.povray.org>
"Chris Becker" <cmb### [at] ritedu> wrote in message
news:3c82ea1f$1@news.povray.org...
> recursion?
black
There is a work-around.  Use very thin cylinders (however infinitely thin is
impossible).  It seems to be a limitation with infinite objects of which
disc and plane are two such things.
I don't know the reason for it or if there's a setting that will circumvent
this error.
bob h
Subject: Re: Clouds
Date: 4 Mar 2002 00:35:16
Message: <chrishuff-7E2D75.00352004032002@netplex.aussie.org>
In article <3c82ea1f$1@news.povray.org>,
> recursion?
Planes only have one surface, so POV never exits a layer, and it sees
all the layers as being nested. Use an object which the ray will
eventually exit, like a box. The box will simulate two planes, halving
the number of objects used for the clouds, and will be better bounded
than planes.
Subject: Re: Clouds
Date: 4 Mar 2002 02:23:43
Message: <3c8320ff@news.povray.org>
Wow, it was that simple, it worked better than great!
Thanks a bunch!
the
> recursion?
black
Subject: Re: Clouds
Date: 4 Mar 2002 23:02:55
Message: <3c84436f$1@news.povray.org>
> method, ...
I don't understand why people use this "stacked-planes" technique when
method 3 media basically simulates it, sometimes making it faster because of
it's anti-aliasing capability.
Unless, of course, one doesn't have version 3.5, although I created some
pretty good clouds with 3.1 media once...
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Subject: Re: Clouds
Date: 5 Mar 2002 07:08:12
Message: <3c84b52c@news.povray.org>
  When a concept gets popular, it's quite difficult to eradicate. In this
case the concept is "media is slow".
  (Another example of this kind of misconception is "area lights are slow;
it's better to use an array of point lights". See
http://www.students.tut.fi/~warp/povQandT/misconceptions.html#arealightconfusion)
Subject: Re: Clouds
Date: 5 Mar 2002 10:13:15
Message: <3C84E0E0.16BE866A@engineer.com>
I have a scene where area_light length*x,z,32,1 takes 6 times
longer to render than 32 point lights.
_____________
Kari Kivisalo
Subject: Re: Clouds
Date: 5 Mar 2002 17:07:59
Message: <3c8541bf@news.povray.org>
I'd be interested in the source.
- Slime
Subject: Re: Clouds
Date: 5 Mar 2002 17:12:34
Message: <3c8542d2@news.povray.org>
  Me too. There's no logical explanation for this.
  (Unless 1-dimensional light sources have some defect or bug in POV-Ray.)
Subject: Re: Clouds
Date: 5 Mar 2002 17:43:08
Message: <3C854A52.15853322@engineer.com>
Here is the 2.0 source hastily converted to 3.5:
#version 3.5;
#declare USE_AREA=1;
  location  <6,6,-6>
  direction <0,0,1.5>
  look_at   <1,0,0>
#declare length=10;
#declare h=0.6;
#declare i=1;
#declare tube1=
union{
  light_source{
    <0, h, 0>
    color rgb i
  cylinder{
    <-length/2,h,0>,<length/2,h,0>,0.05
    pigment{color rgb<1,1,1>}
    finish{diffuse 0 ambient 1}
    no_shadow
#declare d=length/31;
#declare di=i/32;
#declare light=light_source{<-length/2,h,0> color rgb di}
#declare tube2=
union{
  #declare I=0;#while(I<32)
    object{light translate I*d*x}
  #declare I=I+1;#end
  cylinder{
    no_shadow
#if(USE_AREA=1)
  object{tube1}
#else
  object{tube2}
#declare ball=sphere{<0,0.25,0>,0.25}
#declare row=
union{
  object{ball translate<-1.5,0,0.5>}
  object{ball translate<-0.5,0,0.5>}
  object{ball translate<0.5,0,0.5>}
  object{ball translate<1.5,0,0.5>}
union{
  object{row translate<0,0,1>}
  object{row translate<0,0,0>}
  object{row translate<0,0,-1>}
  object{row translate<0,0,-2>}
  finish{diffuse 1.5 ambient 0.1 phong 1}
plane{y,0
  texture{
    pigment{checker color rgb<1,1,1> color rgb<0.5,0.8,1>}
    finish{diffuse 1.5 ambient 0.1}
    scale 0.5
_____________
Kari Kivisalo
