Subject: Radiosity Save/Load without re-pre-trace?
Date: 22 Apr 2002 16:20:20
Message: <3CC47068.35B58A86@gmx.de>
I've been working on a radiosity scene lately (see my recent
Gerbera images in binaries.images), and use the save_file
option to output the radiosity. But even when using
load_file, I always get the pretracing, and it never
saves any time.
How can I tell POV to simply load the radiosity and
don't do all the calculations again although I'm loading?
And what do I have to leave in for the data to stay
the way it was saved?
Tim Nikias
Email: Tim### [at] gmx de
This should do it:
load_file "my_radiosity.rad"
pretrace_start 1
pretrace_end 1
always_sample off
I only tried a few times, but it seems necessary to also input the same rad
settings as used in the saved file, along with this.
Hugo
Subject: Re: Radiosity Save/Load without re-pre-trace?
Date: 22 Apr 2002 18:09:52
Message: <3cc48a2f@news.povray.org>
Hugo wrote:
> This should do it:
> pretrace_start 1
> pretrace_end 1
> always_sample off
> rad settings as used in the saved file, along with this.
Only error_bound seems to be computed when loading rad files, from my
experience. Using the same value seems the faster option. Using a lower
value gives poor results but cleans artifacts.
Hope this helps...
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 23 Apr 2002 00:46:40
Message: <3CC4E713.9142662@gmx.de>
Thanks you two, it helped.
Jaime Vives Piqueres wrote:
> Hugo wrote:
> > This should do it:
> > pretrace_start 1
> > pretrace_end 1
> > always_sample off
> Hope this helps...
> La Persistencia de la Ignorancia
Tim Nikias
> experience.
What about brightness and recursion limit?
Hugo
Date: 26 Apr 2002 14:19:18
Message: <3cc99a25@news.povray.org>
>> experience.
Sorry the late answer: I've now little time for POV-Ray. But I've just
tested more about loading rad files, and learned some more things.
Brightness is indeed taken into account, but recursion_limit has no
effect on both render time nor quality. Count slows down rendering but
seems to not increases quality. I will keep testing...
