![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Folks,
I was playing with Gilles' cloud pigment and hit a problem: what is the
best (ie fastest rendering) way to reproduce an arbitrary pigment from
it's function?
For example, given
#declare PIG = pigment { bozo colour_map {[0.2 rgbf 1][0.5 rgb
y*1.3][0.7 rgb x transmit 1] } }
#declare FNPIG = function { pigment { PIG } }
#declare REBUILD = pigment { ... }
how do you define REBUILD to give the same pigment as PIG, based on
FNPIG?
Normally it's just a matter of
average
pigment_map {
[1 function { FNPIG(x,y,z).x } colour_map {[0 rgb 0][1 rgb 3*x]} ]
[1 function { FNPIG(x,y,z).y } colour_map {[0 rgb 0][1 rgb 3*y]} ]
[1 function { FNPIG(x,y,z).z } colour_map {[0 rgb 0][1 rgb 3*z]} ]
but with filter, transmit or colours with values greater than one this
doesn't work.
I've come up with one structure which works, but is very slow for how I
am using it.
So, I was hoping someone can come up with a better method. Any takers?
Bye for now,
Mike Andrews.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 10 Apr 2002 14:12:15 +0100, Michael Andrews <m.c### [at] reading ac uk>
> average
> pigment_map {
>doesn't work.
have you teste below ? I'm not sure but I think it should work
average
pigment_map {
[1 function { FNPIG(x,y,z).red } colour_map {[0 rgb 0][1 red 5]} ]
[1 function { FNPIG(x,y,z).green } colour_map {[0 rgb 0][1 green 5]} ]
[1 function { FNPIG(x,y,z).blue } colour_map {[0 rgb 0][1 blue 5]} ]
[1 function { FNPIG(x,y,z).filter } colour_map {[0 rgb 0][1 filter 5]} ]
[1 function { FNPIG(x,y,z).transmit } colour_map {[0 rgb 0][1 transmit 5]} ]
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sorry, no, this is always black :-/
I hadn't thought of trying this way though ...
Bye for now,
Mike Andrews.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> FNPIG?
AFAIK, it's not currently possible.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > FNPIG?
Well, yes it is possible (see the picture I just posted in Gilles' fast
cloud thread on p.b.i) but the method I've found is pretty brute-force
and klutzy. I was hoping somone would have a bright idea on how to do it
better than I have. That's why I haven't posted my attempt yet - I don't
want to predispose folks to look at the problem from one direction.
If noone comes up with anything by the weekend I'll post my solution.
Bye for now,
Mike Andrews.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Thu, 11 Apr 2002 13:18:26 +0100, Michael Andrews <m.c### [at] reading ac uk>
layers ?
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
__________________
RAY
"Michael Andrews" <m.c### [at] reading ac uk> wrote in message
news:3CB### [at] reading ac uk...
> Hi Folks,
> it's function?
> For example, given
> FNPIG?
> average
> pigment_map {
would #declare REBUILD = pigment {function {FNPIG}}; work
> doesn't work.
> am using it.
Yes ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
average
pigment_map {
[1 function{FNPIG(x,y,z).red} colour_map {[0 rgbft<-2, 0, 0, 0,
0>][1 rgbft< 3, 0, 0, 0, 0>]}]
[1 function{FNPIG(x,y,z).green} colour_map {[0 rgbft< 0,-2, 0, 0,
0>][1 rgbft< 0, 3, 0, 0, 0>]}]
[1 function{FNPIG(x,y,z).blue} colour_map {[0 rgbft< 0, 0,-2, 0,
0>][1 rgbft< 0, 0, 3, 0, 0>]}]
[1 function{FNPIG(x,y,z).filter} colour_map {[0 rgbft< 1, 1, 1, 0,
0>][1 rgbft< 1, 1, 1, 5, 0>]}]
[1 function{FNPIG(x,y,z).transmit}colour_map {[0 rgbft< 1, 1, 1, 0,
0>][1 rgbft< 1, 1, 1, 0, 5>]}]
This seems to work. I'm fairly certain the math is OK, but I still have
to mull it over. Seemed to worked in a visual comparison test with the
original and rebuilt pigments side by side.
> > > FNPIG?
> Bye for now,
> Mike Andrews.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
...except it still will not work for color component values outside of
the range of 0 to 1 since the technique is limited by the color_map
index range. A workaround (if one knew beforehand the color range) would
involve scaling FNPIG by 1/[maximum expected color range] and setting up
the color_map entries to cover the maximum expected color range.
Abe
> average
> pigment_map {
> > > > FNPIG?
> > Bye for now,
> > Mike Andrews.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"RAY" <RAY### [at] yahoo com> wrote in message news:3cb73511@news.povray.org...
> __________________
> RAY
> > Hi Folks,
> > it's function?
> > For example, given
Replace this with a five-parameter function:
#declare FNPIG = function(rd,gr,bl,ft,tr) { pigment { PIG } }
> > FNPIG?
> > average
> > pigment_map {
After replacing the FNPIG function, the simple declare should work:
#declare REBUILD = pigment { function(rd,gr,bl,ft,tr) {FNPIG}}
> > doesn't work.
> > am using it.
> Yes ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
