POV-Ray : Newsgroups : povray.advanced-users : Reproducing pigment from functions ... Server Time
18 Mar 2026 22:59:53 EDT (-0400)
  Reproducing pigment from functions ... (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Reproducing pigment from functions ...
Date: 10 Apr 2002 15:21:25
Message: <3cb490b4@news.povray.org>
Michael Andrews <m.c### [at] readingacuk> wrote:
> #declare REBUILD = pigment { ... }
> how do you define REBUILD to give the same pigment as PIG, based on
> FNPIG?
  AFAIK, it's not currently possible.
Date: 11 Apr 2002 08:09:50
Message: <3CB57F12.36BE6832@reading.ac.uk>
> > FNPIG?
Well, yes it is possible (see the picture I just posted in Gilles' fast
cloud thread on p.b.i) but the method I've found is pretty brute-force
and klutzy. I was hoping somone would have a bright idea on how to do it
better than I have. That's why I haven't posted my attempt yet - I don't
want to predispose folks to look at the problem from one direction.
If noone comes up with anything by the weekend I'll post my solution.
Bye for now,
	Mike Andrews.
Date: 11 Apr 2002 09:55:57
Message: <4d5bbu06jsaojahr97a8eeoscld0a0sv27@4ax.com>
On Thu, 11 Apr 2002 13:18:26 +0100, Michael Andrews <m.c### [at] readingacuk>
layers ?
ABX
Date: 12 Apr 2002 15:27:13
Message: <3cb73511@news.povray.org>
__________________
 RAY
"Michael Andrews" <m.c### [at] readingacuk> wrote in message
news:3CB### [at] readingacuk...
> Hi Folks,
> I was playing with Gilles' cloud pigment and hit a problem: what is the
> best (ie fastest rendering) way to reproduce an arbitrary pigment from
> it's function?
> For example, given
> #declare PIG = pigment { bozo colour_map {[0.2 rgbf 1][0.5 rgb
> y*1.3][0.7 rgb x transmit 1] } }
> #declare FNPIG = function { pigment { PIG } }
> FNPIG?
> Normally it's just a matter of
>   average
>   pigment_map {
>     [1 function { FNPIG(x,y,z).x } colour_map {[0 rgb 0][1 rgb 3*x]} ]
>     [1 function { FNPIG(x,y,z).y } colour_map {[0 rgb 0][1 rgb 3*y]} ]
>     [1 function { FNPIG(x,y,z).z } colour_map {[0 rgb 0][1 rgb 3*z]} ]
would #declare REBUILD = pigment {function {FNPIG}}; work
> but with filter, transmit or colours with values greater than one this
> doesn't work.
> I've come up with one structure which works, but is very slow for how I
> am using it.
> So, I was hoping someone can come up with a better method. Any takers?
Yes ;-)
Date: 12 Apr 2002 16:33:53
Message: <3CB743C8.C1816CA2@taconic.net>
average
pigment_map {
   [1 function{FNPIG(x,y,z).red}     colour_map {[0 rgbft<-2, 0, 0, 0,
0>][1 rgbft< 3, 0, 0, 0, 0>]}]
   [1 function{FNPIG(x,y,z).green}   colour_map {[0 rgbft< 0,-2, 0, 0,
0>][1 rgbft< 0, 3, 0, 0, 0>]}]
   [1 function{FNPIG(x,y,z).blue}    colour_map {[0 rgbft< 0, 0,-2, 0,
0>][1 rgbft< 0, 0, 3, 0, 0>]}]
   [1 function{FNPIG(x,y,z).filter}  colour_map {[0 rgbft< 1, 1, 1, 0,
0>][1 rgbft< 1, 1, 1, 5, 0>]}]
   [1 function{FNPIG(x,y,z).transmit}colour_map {[0 rgbft< 1, 1, 1, 0,
0>][1 rgbft< 1, 1, 1, 0, 5>]}]
This seems to work. I'm fairly certain the math is OK, but I still have
to mull it over. Seemed to worked in a visual comparison test with the
original and rebuilt pigments side by side.
> > > FNPIG?
> Bye for now,
>         Mike Andrews.
Date: 12 Apr 2002 18:00:54
Message: <3CB75832.881C4B28@taconic.net>
...except it still will not work for color component values outside of
the range of 0 to 1 since the technique is limited by the color_map
index range. A workaround (if one knew beforehand the color range) would
involve scaling FNPIG by 1/[maximum expected color range] and setting up
the color_map entries to cover the maximum expected color range.
Abe
> average
> pigment_map {
> > > > FNPIG?
> > Bye for now,
> >         Mike Andrews.
Date: 12 Apr 2002 20:58:22
Message: <3cb782ae$1@news.povray.org>
"RAY" <RAY### [at] yahoocom> wrote in message news:3cb73511@news.povray.org...
> __________________
>  RAY
> > Hi Folks,
> > it's function?
> > For example, given
Replace this with a five-parameter function:
#declare FNPIG = function(rd,gr,bl,ft,tr) { pigment { PIG } }
> > FNPIG?
> >   average
> >   pigment_map {
After replacing the FNPIG function, the simple declare should work:
#declare REBUILD = pigment { function(rd,gr,bl,ft,tr) {FNPIG}}
> > doesn't work.
> > am using it.
> Yes ;-)
Date: 12 Apr 2002 21:16:47
Message: <3cb786ff$1@news.povray.org>
  Have you actually tried that?
Date: 12 Apr 2002 22:29:14
Message: <3cb797fa@news.povray.org>
news:3CB45A4F.413CA07F@reading.ac.uk...
> >     [1 function { FNPIG(x,y,z).filter } colour_map {[0 rgb 0][1 filter
5]} ]
> Sorry, no, this is always black :-/
> I hadn't thought of trying this way though ...
> Bye for now,
> Mike Andrews.
I tried a 5-parameter function thinking that the results would be truncated
otherwise... POV rejected it as an error:
"Function parameters for pigment functions are not allowed."
I suspect that your problem is that any 5D color vector that is interpreted
in a function block is truncated to 3D RGB form.  If that's so then you're
SOL.
Date: 13 Apr 2002 16:45:08
Message: <3cb898d4@news.povray.org>
In article <3cb797fa@news.povray.org> , "David Wallace"
> SOL.
No, this is not the case.  The error message simply says you may not specify
function parameters for functions with a fixed parameter list, which is
explained in the documentation.
    Thorsten
