POV-Ray : Newsgroups : povray.advanced-users : Focal-Blur VS Antialiasting method 2 Server Time
1 Nov 2024 19:14:24 EDT (-0400)
  Focal-Blur VS Antialiasting method 2 (Message 1 to 10 of 10)
Subject: Focal-Blur VS Antialiasting method 2
Date: 7 Feb 2002 14:26:52
Message: <3C62D4E7.E408EE7@gmx.de>
While tracing images and doing some test runs
for the IRTC-Still, I've noticed that using
focal-blur with 20 samples takes far longer
than Antialiasing method 2 with depth set 2
(which may use 25 samples). I haven't run
with depth set to 3 (since on thumbnail-tests
thats not worth it), but it still is a huge amount
of time in comparison.
I guess it has to do with the algorithm, since
focal-blur probably uses all samples, whereas
the antialiasing only kicks in when needed.
Any suggestions on how to improve focal-blur?
 A major trace is running for one and a half days
now, and since RL will get in the way, I'll probably
have to jump to antialiasing anyway. But I thought
a nice discussion could clear some things up for me.
Thanks in advance!
Tim Nikias
Subject: Re: Focal-Blur VS Antialiasting method 2
Date: 7 Feb 2002 16:18:27
Message: <3c62ef23$1@news.povray.org>
Antialiasing and focal blur are very different. If you use focal blur and no
antialiasing you'll get 'pixel grainy' effects or some rough, noisy blurs
No vocal blur and high antialiasing leads to very sharp, almost perfect
edges.
Date: 7 Feb 2002 16:23:25
Message: <3c62f04d@news.povray.org>
You have to take into account that there's one big difference between
focal blur and antialiasing:
  Antialiasing is triggered when the color of *adjacent* pixels differ more
than a threshold value. There are many places in the image where only one
ray is shot for the current pixel and that's it.
  However, focal blur shoots many rays for each pixel (I don't know exactly
how the algorithm works) and then (I think) shoots even more rays if the
difference between the previous ones was large enough.
  Also the "samples" taken by the initial rays are dispersed a lot more than
antialiasing pixels (focal blur can extend over an area equivalent to tens of
pixels) which means that there will be a lot more variation and a lot more
chances for the samples to differ over the threshold.
Date: 7 Feb 2002 16:25:14
Message: <3c62f0ba@news.povray.org>
Apache <apa### [at] yahoocom> wrote:
: If you use focal blur and no
: antialiasing you'll get 'pixel grainy' effects or some rough, noisy blurs
  Not necessarily. For example, see
http://www.students.tut.fi/~warp/pics/GlowTest.jpg
Date: 7 Feb 2002 16:51:38
Message: <3c62f6ea$1@news.povray.org>
I like that picture, but in my opinion focal blur has a totally different
objective than pixel-oriented antialiasing has...
BTW, I'm having problems typing that word 'antialiasing' all the time. I
keep typing things like 'anitalisaing' and things like that. Maybe we should
change that word into something else?  :-)   Maybe I'm too tired...
Date: 8 Feb 2002 00:40:40
Message: <3C6364BF.E0285E42@gmx.de>
Thanks! I agree, it looks like focal blur isn't useful
for antialiasing AND little focal depth, but using
a lot of blurring can enhance images (if you wanna
see one, look in my gallery for the chess image, I
think the first on the page). But the image I was
tracing for the IRTC-Stills round now took
2 days, and it reached the difficult part about a day
ago and has traced about 40 lines since.
Since I don't have all February for my entry -
we all know RL - I'll stick to antialiasing for
the entry. All I wanted was a slightly blurred moon
and clouds in the background, but I think, the image
doesn't really need it. It can go without that.
Tim Nikias
Date: 8 Feb 2002 00:41:53
Message: <3C636509.CAE84EDD@gmx.de>
> edges.
Hey, "vocal" blur? I thought we were talking about images,
not wave-files... ;)
But I do agree, too few samples get a grainy blur-look, at least
when used with sharp contrasts.
Tim Nikias
Date: 8 Feb 2002 03:07:21
Message: <2j176ugsbnijjtsca5n5dsp27qsopbqnvm@4ax.com>
> antialiasing
Note: you can't use it together with 3.5
Have you seen http://www.wozzeck.net/images/DoF.html ?
> edges.
Unfortunatelly reality is not perfect :-)
ABX
Date: 8 Feb 2002 06:44:30
Message: <3c63ba1e@news.povray.org>
Tim Nikias <tim### [at] gmxde> wrote:
: But I do agree, too few samples get a grainy blur-look, at least
: when used with sharp contrasts.
  The main parameter affecting graininess is variance. AFAIK its default
value was lowered (from 1/128 to 1/10000) in order to get a much better result
with the defaults (previously it didn't matter how many samples you defined,
20 or 2000, you always got a grainy result due to the default value of
variance).
  Then, of course, the number of samples and the aperture are things that
affect this (the higher the aperture, the more samples you'll need).
Date: 12 Feb 2002 05:22:51
Message: <3c68ecfb$1@news.povray.org>
> > If you use focal blur and no antialiasing
Correct. There is no sense in using both AA and focal_blur at the same time!
Btw, I found focal blur to be quite efficient and fast. I doubt I'll be
using AA a lot, in the future.. Focalblur is much better.
You have girls on your mind, that's what's going on. :o)  Anita... Lisa...
Hugo
