Just me again!
So, I have following problem:
-50 discs
-using different, but algorithmically generated texture
-lit by one spotlight
-have to throw shadows onto themselves
-but should not throw shadows into the other scenery
-don't use lightgroups (they're buggy in the betas at the moment)
Any ideas?
To give you an idea what its about: I'm using textured discs as
slices through a cloud-scape. Thus, the slices have to throw
shadows onto themselves. But, when using the area-light
(only in this scene, in others, that'll probably be different),
they don't throw shadows on anything else, because the
shadows are blurred away.
Now, I could save tracing time (a lot!) if those shadows were
only calculated for the discs, not anything else.
But, as mentioned above, lightgroups are a little buggy and
difficult to implement into the existing scene.
Ideas, anyone?
Tim Nikias
Hmm not buggy lightgroups? Just use -ul and they should work as expected.
Jonathan.
-UL doesn't work. Strange lighting:
Some objects aren't lit though in same lightgroup.
Ah, well. Guess I'll take the longer rendering time and
the "more real" approach... ;-)
Tim Nikias
Subject: Re: Difficult Light-Shadow Question...
Date: 6 Feb 2002 05:10:51
Message: <3c61012b@news.povray.org>
In article <3C605592.9400E6A3@gmx.de> , Tim Nikias <tim### [at] gmx de> wrote:
Or wait for beta 11 to test if the changes in there correct the problem.
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
I actually noted that in my mind. I guess, that's what beta-testing is about:
-Find errors
-Verify them
-Make them known to the programmers
-check if fixes interfere with other options
-give standing ovations when everything is finished and the programmers
did a magnificient job, and in the case of POV-Ray:
THEY DID IT AGAIN!
Tim Nikias
Wasn't it Tim Nikias who wrote:
>Just me again!
>-50 discs
>Any ideas?
Cheat: Render two separate images. One of the discs (with a transparent
background) and one of the other scenery, and combine the two with a
paint program. Or combine the two halves in POV by pulling in the disc
image as a no-shadow image-mapped plane over the other scenery.
Mike Williams
Gentleman of Leisure
> Mike Williams
If this is to do with Tim's IRTC entry (which I think it is...) then
cheating is definitely NAO! POV-Ray cheating might be permissible
though...
signature{
"Grey Knight" contact{ email "gre### [at] yahoo com" }
Right. Cheating is NAO, and I actually try to
stick to the real result of an image.
IRTC is about not-cheated, but well-designed /-scripted,
/-modelled or /-"whatever useful" images, so thats what
I wanted to produce.
Tim Nikias
