POV-Ray : Newsgroups : povray.advanced-users : Trace() and memory Server Time
12 Mar 2026 07:20:35 EDT (-0400)
  Trace() and memory (Message 1 to 10 of 13)
Subject: Trace() and memory
Date: 12 Dec 2001 02:02:33
Message: <3C1700A6.28651428@gmx.de>
I've found in the docs that the new trace()-function from POV-Ray3.5
only
checks for an intersection with a declared object.
Now I'm wondering. This, if I want to check for an intersection in a
complex
scene, requires me to declare the entire scene, and thus, also to place
it using
object{}.
So, how much does this affect memory consumption?
And, while we're at it:
If I want to do an algorithm that trace()s a plane and places sphere on
top,
and does so over and over again, but is also supposed to place spheres
ON spheres just placed as well...
Do I have to create an array, in which I save the objects placed, and
call on these
again and again for each new sphere?
So, my main question is:
Is there an easy solution which provides me with a way to use trace() on
a
scene, alter it, and use trace() again after the alterations, without
having to
tamper around with arrays and declarations of objects en mass?
Tim
Subject: Re: Trace() and memory
Date: 12 Dec 2001 05:29:52
Message: <3c1731a0$1@news.povray.org>
In article <3C1700A6.28651428@gmx.de> , Tim Nikias <Tim### [at] gmxde>
During parsing you need slightly more memory, but no additional memory will
be needed.
As for you problem, you don't need trace to place spheres on a plane.  The
math to know where the plane is in space really isn't that hard...
    Thorsten
e-mail: tho### [at] trfde
Date: 12 Dec 2001 06:57:14
Message: <3C1745B9.66BB82A3@gmx.de>
I wasn't literary speaking about "spheres on planes". Take any object, and
any environment. Use trace to place the object anywhere. Now, when I
want to place the next object, it should also consider the new object I just
placed. And this goes on and on, perhaps inside a loop?
Tim
Date: 12 Dec 2001 07:29:19
Message: <3c174d9f@news.povray.org>
Tim Nikias schrieb in Nachricht <3C1745B9.66BB82A3@gmx.de>...
>Now, when I
just
I would say: Just union{} the new Object with the old union{}. This way you
can always trace() against the same object. No arrays needed IMO.
Marc-Hendrik
Date: 12 Dec 2001 07:37:47
Message: <rpje1uknmu0c8ip0530f6dfje5o8hbv0p8@4ax.com>
you want something like this ?
#local Base=box{<-1,-1,-1><1,0,1> pigment{granite}}
#local Count=100;
#local Spheres=array[Count];
#local Counter=0;
#local rs=seed(0);
#local R=.1;
#while (Counter<Count)
  #local Found=no;
  #while (!Found)
    #local Start=2*<2*rand(rs)-1,rand(rs),2*rand(rs)-1>;
    #local Dir=<2*rand(rs)-1,rand(rs),2*rand(rs)-1>;
    #local Dir=vnormalize(Dir-Start);
    #local Norm=<0,0,0>;
    #local Intersection=trace(Base,Start,Dir,Norm);
    #if(vlength(Norm)>0)
      #local Center=Intersection+Norm*R;
      #if(Center.y>=R)
        #local Bad=no;
        #local Temp=0;
        #while (Temp<Counter)
          #if(vlength(Spheres[Temp]-Center)<2*R)
            #local Bad=yes;
          #local Temp=Temp+1;
        #if(!Bad)
          #local Found=yes;
          #local Spheres[Counter]=Center;
          #local Base=union{
            object{Base}
            sphere{
              Center
              R
              pigment{color rgb .5+.5*<rand(rs)rand(rs)rand(rs)>}
  #local Counter=Counter+1;
object{Base no_shadow}
camera{
  location <2,2,-3>
  up y
  look_at <0,.5,0>
light_source{ y*100 color rgb 1}
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)&_((x+y)*.7,z,.1)&_((x+y+2)*.7,z,.1)&_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 12 Dec 2001 07:39:35
Message: <lsje1ugjcq77mqt0f2k96bfagmt08u593b@4ax.com>
On Wed, 12 Dec 2001 13:29:15 +0100, "Marc-Hendrik Bremer"
> > Now, when I
Without arrays with previous parameters intersection testing is much more
complicated. But probably possible.
ABX
Date: 12 Dec 2001 10:19:13
Message: <3C17750F.5249405@gmx.de>
Though I couldn't test your code yet (POV-Ray doesn't do multiple
instances yet, and I've got an I/O thingy running), I had a close look at it.
Somehow, I don't know why, there is this rumour that objects itself
can't be stored in arrays. You can actually do things like:
#declare Objects=array[3]
 {sphere{<0,0,0>,1},box{-1,1},cylinder{0,y,1}}
Somehow, most people think you can only store variables in there...
But yes, your code did actually (in some other method, not using objects
themselves) do the job I was talking about. Though that was of no concern,
I just wanted to know, if there is some easier way, some special clue, which
might improve the process.
Seems there is not, but that's fine.
Another thing that was just on my mind:
Using Macros, one could also increase the dimensions of arrays dynamically,
so there is also no need to set an amount beforehand.(Just in case someone was
curious about that).
Tim
Date: 12 Dec 2001 10:30:31
Message: <fmte1ukc8osi309h4db72ja0o8uainlce0@4ax.com>
> instances yet
POV-Ray does multiple instances, but... with previous beta :-)
of course I know. but it complicates intersection checking.
you considered memory problems and mine seems optimal in this case.
My code is universal. Just replace spheres condition (distance<2R) with own
method based on another set of traces or whatever you want.
I know. My point was to write readable and fast enough code.
ABX
Date: 12 Dec 2001 13:00:51
Message: <3c179b53$1@news.povray.org>
Hmm, do you mean something like this:
http://news.povray.org/povray.binaries.images/20145/?ttop=20670&toff=50 ?
Jonathan.
Date: 12 Dec 2001 18:08:18
Message: <3c17e362@news.povray.org>
news:rpje1uknmu0c8ip0530f6dfje5o8hbv0p8@4ax.com...
[snip]
There was a discussion on p.u.p re trace() and I think also this
section a while ago on the difficulty of testing for <0,0,0>. This is
the first time I've seen this solution and it seems so simple. I can't
believe I missed it when I first tried to figure out an easy answer :(
Alf
