POV-Ray : Newsgroups : povray.advanced-users : Advice on sheer fabric texture? Server Time
30 Jul 2024 02:18:05 EDT (-0400)
  Advice on sheer fabric texture? (Message 1 to 2 of 2)
Subject: Advice on sheer fabric texture?
Date: 25 Jul 2000 18:56:06
Message: <397DFF69.A1C554B0@yahoo.com>
I want to create a fabric texture that will give the effect of thin
cotton or even silk. The key points are:
- a cream or off white colour
- Slight transparency/translucence so that a little light comes through
and a hint of the body limbs underneath are given
- a slight roughness to suggest the warp of the cloth - very subtle or
fine texture.
Any suggestions for the parameters? I considered using a texture map
from a photo, but I can't seem to get the translucence effect as well if
I use an image map.
Subject: Re: Advice on sheer fabric texture?
Date: 26 Jul 2000 14:48:03
Message: <chrishuff-DE927A.13484626072000@news.povray.org>
In article <397DFF69.A1C554B0@yahoo.com>, Simon Lacey
> fine texture.
Hmm...try giving it a fairly large scale bozo normal and use a high
brilliance value in the finish. Some very small scale normal coupled
with low-brightness specular highlights might help, maybe also a small
amount of reflection, not enough to really be visible, but just to add a
small effect. You might also want to try some iridescence.
Add some filtering transparency, and if you are using MegaPOV, use
double_illuminate. And finally, use radiosity.
