POV-Ray : Newsgroups : povray.advanced-users : What does povray consider degenerate? Server Time
12 Apr 2026 02:52:49 EDT (-0400)
  What does povray consider degenerate? (Message 1 to 7 of 7)
Subject: What does povray consider degenerate?
Date: 5 Jun 2000 06:01:51
Message: <393b7a8e@news.povray.org>
About a recent post in p.general:
  When is a triangle degenerate?
  I think that one case is when two of the vertices or all the three are
actually the same point. In this case it would be just an infinitely thin
line or point.
  I faintly remember that povray also considers denerate a smooth triangle
with the vertex normals pointing to different sides of the triangle. Is
this so?
  Any other case?
Subject: Re: What does povray consider degenerate?
Date: 5 Jun 2000 11:19:52
Message: <393BC566.2A97A18@spiritone.com>
A cylinder with both ends the same position in space is not a disc but a
degenereate cylinder.
I've gotten this one. I'm pretty sure a box with the same two vectors will
also generate the degenerate error.
A smooth triangle with opposing normals is something different, I think. But
it still won't render.
Josh
> line or point.
> this so?
>   Any other case?
Josh English
eng### [at] spiritonecom
Date: 5 Jun 2000 14:10:46
Message: <slrn8jns0t.500.ron.parker@linux.parkerr.fwi.com>
Sometimes it renders.  Sometimes it crashes.  Depends on the compiler
used to build your copy of POV.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 5 Jun 2000 14:20:32
Message: <slrn8jnsj7.500.ron.parker@linux.parkerr.fwi.com>
>line or point.
Or when they fall in a line, such as x, 2*x, 3*x.  The actual condition is
"when the cross product of P1-P2 and P3-P2 is zero."  Note that this is not
the usual "within epsilon of zero" condition; it must actually be zero.
>this so?
The comment in triangle.c says
  /* Degenerate if smooth normals are more than 90 from actual normal
     or its inverse. */
where the actual normal is the aforementioned cross product after
normalization.  The actual test, however, makes more sense: it requires
that the signs of the dot products of the corner normals with the actual
normal must either be all positive or all negative.  In short, what you
said, with the additional requirement that corner normals in the plane
of the triangle are also degenerate.
This calculation, too, ignores epsilon.
Date: 5 Jun 2000 17:50:57
Message: <393C2062.DF49AE46@erols.com>
When it starts buying lap dances at the local strip club.
ICQ: 46085459
Date: 6 Jun 2000 12:17:15
Message: <393D2456.662B3779@spiritone.com>
ARGH!  I don't beleive that I missed this one, as well. The cross product
definition is the most inclusive. I should have seen that. We just covered it
in calculus
Josh
> >line or point.
> >this so?
>      or its inverse. */
Josh English
Date: 8 Jun 2000 07:05:55
Message: <393f7e13@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
:>when two of the vertices or all the three are actually the same point.
: when they fall in a line
: if smooth normals are more than 90 from actual normal or its inverse.
  Ok, thanks. There seems to be three clear cases when a triangle is
degenerate. My program only checks the first one. I have to add the other
two as well.
