POV-Ray : Newsgroups : povray.advanced-users : uv_map not turning Server Time
30 Jul 2026 09:40:04 EDT (-0400)
  uv_map not turning (Message 1 to 6 of 6)
Subject: uv_map not turning
Date: 9 May 2000 22:38:08
Message: <3918cb90$1@news.povray.org>
Here is the code i'm using to map the image of a face onto a head...
#declare Head = object {head
        uv_mapping texture {
                        image_map {gif "face.gif" }  // face image
                        scale <.8,.9999,.9999>      // scaling the image to
fit the head
                        rotate -23.5*y rotate 9*x  // rotating the image to
position eyes  with eyes, mouth with mouth etc.
scale 10  // enlarging the head to see it better
rotate 180*y // rotating the head to face the front
object {Head
rotate -45*y // attempting to turn the whole head, texture and all
I try this and the image stays pointing forward and the head turns, so that
the face is on the side of the head......
any ideas?
Subject: Re: uv_map not turning
Date: 10 May 2000 10:57:47
Message: <39197873.DAB463AA@inapg.inra.fr>
> any ideas?
What kind of object is the head ? There are only a limited number of objects
that support uv mapping in Megapov 0.4 : bicubic_patch, mesh, mesh2, lathe,
sor, sphere and box
Other objects are not supported (but could be) while others, like blobs or
julia fractals, won't be supported (from the Megapov 0.4 doc). Using a uv map
for an unsupported object could give unexpected results.
G.
Date: 10 May 2000 19:04:51
Message: <chrishuff_99-C93A7A.18081310052000@news.povray.org>
In article <3918cb90$1@news.povray.org>, "kane"
> that the face is on the side of the head......
I recall seeing some odd-looking code for UV-mapping while writing the
transform patch(it didn't seem to be transforming the UV-stuff
correctly), if it is a bug, Nathan probably has already fixed it while
including my patch.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 23 May 2000 19:10:53
Message: <392b0ffd@news.povray.org>
"kane" <ann### [at] mindspringcom> wrote in message
news:3918cb90$1@news.povray.org...
[snipped code]
that
> any ideas?
I'm with Giles on wanting to know what type of object "head" is. Personally
I tend to include the texture declaration for UV-mapped objects with the
mesh2 declaration of the mesh. E.G.
mesh
    smooth_triangle {
        <-0.0277779 , 0.371302 ,-0.0331393 > <-0.0639206 ,-0.152895
,-0.986173 >,
        <-0.0257146 , 0.367395 ,-0.0327338 > < 0.00433927 ,-0.113552
,-0.993523 >,
        <-0.0238329 , 0.370178 ,-0.0331331 > < 0.0084841 ,-0.150033
,-0.988645 >
       uv_vectors
            < 0.638865 , 0.36532 >,< 0.640906 , 0.361171 >,< 0.642727 ,
0.364192 >
...more trianlges...
    smooth_triangle {
        < 0.00102733 , 0.335028 ,-0.00355518 > <-0.112846 ,-0.934316 ,
0.338112 >,
        < 0.000504653 , 0.335198 ,-0.00377561 > <-0.28251 ,-0.900641 ,
0.330201 >,
        < 0.000501327 , 0.337475 , 0.00231839 > <-0.432333 ,-0.855839 ,
0.28395 >
        uv_vectors
            < 0.666954 , 0.328181 >,< 0.666477 , 0.328178 >,< 0.666358 ,
0.327304 >
    uv_mapping
    texture {MyTextureNameHere}
and I haven't noticed any problem with UV--POV or MegaPOv (0.3,0.4, and just
started using 0.5). I *did* notice some odd features when trying to do
UV-mapping in official POV (and befor eI got the hang of the syntax used
above) but not since.
Hope this helps (which version of POV are you using BTW?)
Cheers,
Cliff Bowman
Date: 23 May 2000 22:23:02
Message: <392b3d06@news.povray.org>
Personally
   It was an .obj file converted to .3ds then to pov, in which it was a
union of smooth triangles. I later converted the .obj again to get it into
mesh. So far this hasn't help but thanks for the advice, I try an work with
it some more at a later date when I have more time to fool with it.  Thanks.
  I'm using MegaPov.
Thanks again,
   Kane
Date: 23 May 2000 23:24:00
Message: <392B3D7A.64161789@peak.edu.ee>
Try this link:
http://www.stmuc.com/thbaier/tools.html
Check out 3Dto3D version 4. AFAIK it supports MegaPov's mesh2 format, which can
store uv information, and should therefore work better with uv mapping than
plain mesh.
Margus Ramst
