![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am importing, from a generic database, a very large number of items into
an include list.
The items will be classed as possibly 100 distinctly different 'objects',
not all of which will be predefined during the initial display.
When the items are parsed I want a non-defined item to be simply ignored.
I could of course provide an #ifdef....#end around each and every item but I
wonder if there is an easier way, possibly through a macro, to do the job.
David
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I don't think it's possible with a macro. Something like this will not work:
#macro Item(name)
#ifdef(name)
do_whatever_with name
because 'name' _is_ always defined in the context of the macro.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Nieminen Juha" <war### [at] sarakerttunen cs tut fi> wrote in message
news:38c6179a@news.povray.org...
work:
> #macro Item(name)
> #ifdef(name)
> #end
> #end
Also, I think calling Item(Name) will cause an error if Name is undefined.
The only legal use of an undefined name I can think of are (1) define it
(with #declare or #local or #macro) and (2) check its "existence"
(definess?) with ifdef / ifndef.
Philippe
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>an include list.
Are the 'objects' such that they can be stored in an array? If so, MegaPOV
has an extension to the syntax that allows you to check whether a particular
array element is defined, so you could do whatever you're doing inside a loop
or by passing the array and an index to a macro.
These are my opinions. I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
