![](/i/fill.gif) |
Eitan Tal wrote:
> Hi! I wanted to know how to make somehting like a torus, but instead of
> being O, I need ~
> I will also like to know how they made these beautifull jewlery at the
> documentation...
> Did they use Sin?
Hi !
Regarding torus-strings: Is this wat you need? (see POV-file below)
Regards
Tor Olav Kristensen
mailto:tor### [at] hotmail com
// "String" of torus segments ~~~~~~
// Copyright 2000 by Tor Olav Kristensen.
#version 3.1;
#declare Origo = <0, 0, 0>;
#declare Nullv = <0, 0, 0>;
#declare Unitv = <1, 1, 1>;
// Just some of my macros
#macro vCos(UU, VV)
// Returns cosinus of the angle between two vectors
(vdot(UU, VV)/(vlength(UU)*vlength(VV)))
#end // macro vCos
#macro vangle(UU, VV)
// Returns the angle in radians between two vectors
// 0 <= angle < pi/2
acos(vCos(UU, VV))
#end // macro vangle
#macro VectorAngles(Vector)
// Returnes two angles.
// The first is the angle between Vector and the Y-axis
// The second is the angle between the projection
// of Vector to the XZ-plane and the X-axis
#local VAngles = Nullv;
#if (vlength(Vector) > 0)
#local VAngles = y*vangle(Vector, y);
#if (VAngles.y > 0)
#local tmp = vangle(<Vector.x, 0, Vector.z>, x);
#if (Vector.z < 0)
#local tmp = -tmp;
#local VAngles = VAngles + tmp*x;
#end // if
VAngles
#end // macro VectorAngles
#macro vtilt(Thing, TiltVector)
// Returns the object Thing "tilted" in the direction of
// TiltVector
#local RotateAngles = VectorAngles(TiltVector);
object {
Thing
rotate degrees(RotateAngles.x)*y
rotate -degrees(RotateAngles.y)*z
rotate -degrees(RotateAngles.x)*y
#end // macro vtilt
#macro TorusSegment(Centerpoint, Point1, Point2, SmallRadius)
// A segment of a torus that has Centerpoint as its
// center is returned.
// The torus is cut off by two planes:
// Both these planes are perpendicular to the plane
// that Centerpoint, Point1 and Point2 are in.
// The plane that Centerpoint, Point1 and Point2 lies
// in has the normal vector: VectorUp
// Point1 and the following two direction vectors
// describes the first plane: VectorUp and Vector1
// Point2 and the following two direction vectors
// describes the second plane: VectorUp and Vector2
#local Vector1 = Point1-Centerpoint;
#local Vector2 = Centerpoint-Point2;
#local VectorUp = vcross(Vector2, Vector1);
#local BigRadius = vlength(Vector1); // or Vector2
intersection {
vtilt(torus { BigRadius, SmallRadius }, VectorUp)
plane { vcross(Vector1, VectorUp), 0 }
plane { vcross(Vector2, VectorUp), 0 }
translate Centerpoint
#end // macro TorusSegment
// Here the fun starts
#declare V1 = <2, 3, -1>;
#declare V2 = vlength(V1)*vnormalize(<4, 7, 9>);
#declare CPt1 = Origo-4*V2+2*V1; // Center of 1. torus segment
#declare Pt11 = CPt1 + V1*2; // Start of 1. torus segment
#declare Pt12 = CPt1 + V2*2; // End of 1. torus segment
#declare Pt21 = Pt12; // Start of 2. torus segment
#declare CPt2 = Pt21+V2/3; // Center of 2. torus segment
#declare Pt22 = CPt2-V1/3; // End of 2. torus segment
#declare Pt31 = Pt22; // Start of 3. torus segment
#declare CPt3 = Pt31-V1/3*2; // Center of 3. torus segment
#declare Pt32 = CPt3+V2/3*2; // End of 3. torus segment
#declare Pt41 = Pt32; // Start of 4. torus segment
#declare CPt4 = Pt41+V2; // Center of 4. torus segment
#declare Pt42 = CPt4-V1; // End of 4. torus segment
#declare V3 = vcross(V1, V2);
#declare V4 = vcross(V2, V3);
#declare V5 = V3-V2/2;
#declare V6 = V4-4*V3;
#declare R = 2;
#declare Pt51 = Pt32; // Start of 5. torus segment
#declare CPt5 = Pt51+R*vnormalize(V5); // Center of 5. torus segment
#declare Pt52 = CPt5-R*vnormalize(V6); // End of 5. torus segment
// And then we visualize it all
#declare sr = 0.5; // sphere radius
#declare cr = 0.2; // cylinder radius
#declare tr = 0.4; // torus radius
union {
sphere { Pt11, sr }
sphere { Pt12, sr }
sphere { Pt21, sr }
sphere { Pt22, sr }
sphere { Pt31, sr }
sphere { Pt32, sr }
sphere { Pt41, sr }
sphere { Pt42, sr }
// sphere { Pt51, sr }
// sphere { Pt52, sr }
pigment { color Yellow }
union {
sphere { CPt1, sr }
sphere { CPt2, sr }
sphere { CPt3, sr }
sphere { CPt4, sr }
// sphere { CPt5, sr }
pigment { color Cyan }
union {
cylinder { CPt1, Pt11, cr }
cylinder { CPt1, Pt12, cr }
cylinder { CPt2, Pt21, cr }
cylinder { CPt2, Pt22, cr }
cylinder { CPt3, Pt31, cr }
cylinder { CPt3, Pt32, cr }
cylinder { CPt4, Pt41, cr }
cylinder { CPt4, Pt42, cr }
// cylinder { CPt5, Pt51, cr }
// cylinder { CPt5, Pt52, cr }
pigment { color Green }
union {
TorusSegment(CPt1, Pt11, Pt12, tr)
TorusSegment(CPt2, Pt21, Pt22, tr)
TorusSegment(CPt3, Pt31, Pt32, tr)
TorusSegment(CPt4, Pt41, Pt42, tr)
// TorusSegment(CPt5, Pt51, Pt52, tr)
pigment { color Red }
light_source { 100*<1,-1, 0>, White }
light_source { 100*Unitv, White }
location <10, -2, 2>
look_at (Pt31+Pt32)/2
background { color White }
![](/i/fill.gif) |
![](/i/fill.gif) |
This is one way. I just messed around to get it right for this example of it,
and it does use only sin for the waviness.
light_source { <0,1,-10> color rgb <1.5,1.5,1.5>}
location <0,0,-5>
angle 30
look_at <0,0,0>
background {rgb .5}
#declare Curve=.25; // amount of curvature [higher is larger]
#declare C=360;
#declare c=0;
#while (C>0)
#declare c=c+(1/360);
// blob { threshold .1 // slower
sphere {0,.1 // ,1 // for blob
translate -1*z rotate C*y
translate (sin(c * 4 * pi)*Curve)*y
pigment {rgb <c,1-c,.5+c/2>}
// pigment {rgb 1} // for blob
// } // for blob
#declare C=C-1;
"Eitan Tal" <eit### [at] netvision net il> wrote in message
news:38B6F838.6F69F2E9@netvision.net.il...
| being O, I need ~
| documentation...
| Did they use Sin?
![](/i/fill.gif) |
![](/i/fill.gif) |
#version unofficial MegaPov 0.4;
camera { location <-5,1,-4>*3 look_at 0 angle 35 }
light_source { <0,100,-100> 1 }
plane { y,-2 pigment { checker rgb 1, rgb .5 } }
isosurface
{ function { sqr(y+sin(x))+sqr(z)-1 }
contained_by { box { <-50,-2,-1><50,2,1> } }
pigment { rgb x } finish { specular .5 }
![](/i/fill.gif) |
