POV-Ray : Newsgroups : povray.advanced-users : Snakes, Sinus shapes, chains (like in the povray documentaion) using SINUS Server Time
21 Mar 2026 07:39:37 EDT (-0400)
  Snakes, Sinus shapes, chains (like in the povray documentaion) using SINUS (Message 1 to 6 of 6)
Subject: Snakes, Sinus shapes, chains (like in the povray documentaion) using SINUS
Date: 25 Feb 2000 16:48:58
Message: <38B6F838.6F69F2E9@netvision.net.il>
Hi! I wanted to know how to make somehting like a torus, but instead of
being O, I need ~
I will also like to know how they made these beautifull jewlery at the
documentation...
Did they use Sin?
Subject: Re: Snakes, Sinus shapes, chains (like in the povray documentaion) using SINUS
Date: 25 Feb 2000 19:13:37
Message: <38B71B29.AA075F04@peak.edu.ee>
With a bit of trig, you can do this by stringing clipped torii.
Margus
> being O, I need ~
> documentation...
> Did they use Sin?
Date: 25 Feb 2000 20:40:27
Message: <38B72E00.68A8BA92@hotmail.com>
> being O, I need ~
> documentation...
> Did they use Sin?
Hi !
Regarding torus-strings: Is this wat you need? (see POV-file below)
Regards
Tor Olav Kristensen
mailto:tor### [at] hotmailcom
// "String" of torus segments ~~~~~~
// Copyright 2000 by Tor Olav Kristensen.
#version 3.1;
#declare Origo = <0, 0, 0>;
#declare Nullv = <0, 0, 0>;
#declare Unitv = <1, 1, 1>;
// Just some of my macros
#macro vCos(UU, VV)
// Returns cosinus of the angle between two vectors
  (vdot(UU, VV)/(vlength(UU)*vlength(VV)))
#end // macro vCos
#macro vangle(UU, VV)
// Returns the angle in radians between two vectors
// 0 <= angle < pi/2
  acos(vCos(UU, VV))
#end // macro vangle
#macro VectorAngles(Vector)
// Returnes two angles.
// The first is the angle between Vector and the Y-axis
// The second is the angle between the projection
// of Vector to the XZ-plane and the X-axis
  #local VAngles = Nullv;
  #if (vlength(Vector) > 0)
    #local VAngles = y*vangle(Vector, y);
    #if (VAngles.y > 0)
      #local tmp = vangle(<Vector.x, 0, Vector.z>, x);
      #if (Vector.z < 0)
        #local tmp = -tmp;
      #local VAngles = VAngles + tmp*x;
  #end // if
  VAngles
#end // macro VectorAngles
#macro vtilt(Thing, TiltVector)
// Returns the object Thing "tilted" in the direction of
// TiltVector
  #local RotateAngles = VectorAngles(TiltVector);
  object {
    Thing
    rotate  degrees(RotateAngles.x)*y
    rotate -degrees(RotateAngles.y)*z
    rotate -degrees(RotateAngles.x)*y
#end // macro vtilt
#macro TorusSegment(Centerpoint, Point1, Point2, SmallRadius)
// A segment of a torus that has Centerpoint as its
// center is returned.
// The torus is cut off by two planes:
// Both these planes are perpendicular to the plane
// that Centerpoint, Point1 and Point2 are in.
// The plane that Centerpoint, Point1 and Point2 lies
// in has the normal vector: VectorUp
// Point1 and the following two direction vectors
// describes the  first plane: VectorUp and Vector1
// Point2 and the following two direction vectors
// describes the second plane: VectorUp and Vector2
  #local Vector1 = Point1-Centerpoint;
  #local Vector2 = Centerpoint-Point2;
  #local VectorUp = vcross(Vector2, Vector1);
  #local BigRadius = vlength(Vector1); // or Vector2
  intersection {
    vtilt(torus { BigRadius, SmallRadius }, VectorUp)
    plane { vcross(Vector1, VectorUp), 0 }
    plane { vcross(Vector2, VectorUp), 0 }
    translate Centerpoint
#end // macro TorusSegment
// Here the fun starts
#declare V1 = <2, 3, -1>;
#declare V2 = vlength(V1)*vnormalize(<4, 7, 9>);
#declare CPt1 = Origo-4*V2+2*V1; // Center of 1. torus segment
#declare Pt11 = CPt1 + V1*2;     // Start of 1. torus segment
#declare Pt12 = CPt1 + V2*2;     // End of 1. torus segment
#declare Pt21 = Pt12;            // Start of 2. torus segment
#declare CPt2 = Pt21+V2/3;       // Center of 2. torus segment
#declare Pt22 = CPt2-V1/3;       // End of 2. torus segment
#declare Pt31 = Pt22;            // Start of 3. torus segment
#declare CPt3 = Pt31-V1/3*2;       // Center of 3. torus segment
#declare Pt32 = CPt3+V2/3*2;       // End of 3. torus segment
#declare Pt41 = Pt32;            // Start of 4. torus segment
#declare CPt4 = Pt41+V2;         // Center of 4. torus segment
#declare Pt42 = CPt4-V1;         // End of 4. torus segment
#declare V3 = vcross(V1, V2);
#declare V4 = vcross(V2, V3);
#declare V5 = V3-V2/2;
#declare V6 = V4-4*V3;
#declare R = 2;
#declare Pt51 = Pt32;                  // Start of 5. torus segment
#declare CPt5 = Pt51+R*vnormalize(V5); // Center of 5. torus segment
#declare Pt52 = CPt5-R*vnormalize(V6); // End of 5. torus segment
// And then we visualize it all
#declare sr = 0.5; // sphere radius
#declare cr = 0.2; // cylinder radius
#declare tr = 0.4; // torus radius
union {
  sphere { Pt11, sr }
  sphere { Pt12, sr }
  sphere { Pt21, sr }
  sphere { Pt22, sr }
  sphere { Pt31, sr }
  sphere { Pt32, sr }
  sphere { Pt41, sr }
  sphere { Pt42, sr }
//  sphere { Pt51, sr }
//  sphere { Pt52, sr }
  pigment { color Yellow }
union {
  sphere { CPt1, sr }
  sphere { CPt2, sr }
  sphere { CPt3, sr }
  sphere { CPt4, sr }
//  sphere { CPt5, sr }
  pigment { color Cyan }
union {
  cylinder { CPt1, Pt11, cr }
  cylinder { CPt1, Pt12, cr }
  cylinder { CPt2, Pt21, cr }
  cylinder { CPt2, Pt22, cr }
  cylinder { CPt3, Pt31, cr }
  cylinder { CPt3, Pt32, cr }
  cylinder { CPt4, Pt41, cr }
  cylinder { CPt4, Pt42, cr }
//  cylinder { CPt5, Pt51, cr }
//  cylinder { CPt5, Pt52, cr }
  pigment { color Green }
union {
  TorusSegment(CPt1, Pt11, Pt12, tr)
  TorusSegment(CPt2, Pt21, Pt22, tr)
  TorusSegment(CPt3, Pt31, Pt32, tr)
  TorusSegment(CPt4, Pt41, Pt42, tr)
//  TorusSegment(CPt5, Pt51, Pt52, tr)
  pigment { color Red }
light_source {  100*<1,-1,  0>, White }
light_source {  100*Unitv,  White }
  location <10, -2, 2>
  look_at (Pt31+Pt32)/2
background { color White }
Date: 25 Feb 2000 21:33:19
Message: <38b73b6f@news.povray.org>
This is one way.  I just messed around to get it right for this example of it,
and it does use only sin for the waviness.
light_source { <0,1,-10> color rgb <1.5,1.5,1.5>}
  location  <0,0,-5>
  angle 30
  look_at   <0,0,0>
background {rgb .5}
#declare Curve=.25; // amount of curvature [higher is larger]
#declare C=360;
#declare c=0;
#while (C>0)
#declare c=c+(1/360);
// blob { threshold .1 // slower
sphere {0,.1 // ,1 // for blob
        translate -1*z rotate C*y
        translate (sin(c * 4 * pi)*Curve)*y
   pigment {rgb <c,1-c,.5+c/2>}
//  pigment {rgb 1} // for blob
// } // for blob
#declare C=C-1;
"Eitan Tal" <eit### [at] netvisionnetil> wrote in message
news:38B6F838.6F69F2E9@netvision.net.il...
| being O, I need ~
| documentation...
| Did they use Sin?
Date: 26 Feb 2000 13:48:02
Message: <38b81fe2@news.povray.org>
#version unofficial MegaPov 0.4;
camera { location <-5,1,-4>*3 look_at 0 angle 35 }
light_source { <0,100,-100> 1 }
plane { y,-2 pigment { checker rgb 1, rgb .5 } }
isosurface
{ function { sqr(y+sin(x))+sqr(z)-1 }
  contained_by { box { <-50,-2,-1><50,2,1> } }
  pigment { rgb x } finish { specular .5 }
Date: 27 Feb 2000 13:20:34
Message: <slrn8biqqb.v8.ron.parker@parkerr.fwi.com>
Without the trig, you can do it using my torus spline macro,
available at the "my other stuff" address below.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
