POV-Ray : Newsgroups : povray.advanced-users : Isosurface math questions Server Time
30 Jul 2026 13:58:09 EDT (-0400)
  Isosurface math questions (Message 1 to 9 of 9)
Subject: Isosurface math questions
Date: 16 Dec 1999 17:37:22
Message: <38596824.1F573B72@isd.net>
First of all, how do I make angle-dependent equations, such as helixes,
when isosurface doesn't support atan2?
Second, how do I add or subtract equations, to do stuff like blobbing?
David   http://thunder.prohosting.com/~davidf  (ICQ 55354965)
"The paper holds their folded faces to the floor" -Pink Floyd
Subject: Re: Isosurface math questions
Date: 16 Dec 1999 18:00:21
Message: <chrishuff_99-41D518.18005416121999@news.povray.org>
Um, atan2 is supported-at least, it seems to be in the Multipatch. And
there are also:
sin  asin  sinh  asinh
cos  acos  cosh  acosh
tan  atan  tanh  atanh
and a few others, these are just the trig functions.
You might want to check out the built in library functions too, there
are some for making helixes in there.
With the + and - operators. :-)
If you have two functions that are #defined, say MyFuncA and MyFuncB, do
something like
function {MyFuncA(x, y, z) + MyFuncB(x, y, z)}
Also try using * and & for multiplication and boolean AND.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 16 Dec 1999 18:39:14
Message: <chrishuff_99-8BB908.18394416121999@news.povray.org>
Here is a list of the functions and keywords available(from a template
menu in MacMegaPOV):
x y z
clock pi
cos() cosh() acos() acosh()
sin() sinh() asin() asinh()
tan() tanh() atan() atanh() atan2(a, b)
abs() ceil() floor() min() max()
sqrt() cub() exp()
noise3d(x, y, z)
degrees() radians()
if(a, b, c)
And an example of mixing functions:
isosurface {
   function {
      (1-sqrt(x^2 + y^2 + z^2))//The spherical function
      - (sin(atan2(x, z)*7 + y*3)*0.15)//a helical function
   threshold 0
   bounded_by{box {<-5,-5,-5>, < 5, 5, 5>}}
   accuracy 0.001
   texture {WhateverTextureYouWant}
In case you are interested, the helical function is controlled like this:
- (sin(atan2(x, z)*NumberOfRidges + y*AmountOfTwist)*RidgeDepth)
Chris Huff
Date: 16 Dec 1999 19:26:32
Message: <385981B6.2B077A4C@isd.net>
> something like
If I have three torus functions, on the x-y, x-z, and y-z planes, then a
point p might be 3 units from one circle and 1 unit from another and 6 units
from another and have a value of 10 and that doesn't do what I want it to,
combine functions like they were unioned or isoblobbed.
Date: 16 Dec 1999 19:55:58
Message: <chrishuff_99-87E76F.19563216121999@news.povray.org>
> > do
> > something like
> units
> to,
To union functions, use the boolean OR operator(|) between the functions.
To make them blob together, you have to make them into density
functions, try using min and max to clamp the values into a specific
range. Here is a useful function for doing this:
#declare clamp = function {min(y, max(x, z))}
clamp(value, minimum, maximum)
Clamps the value to the range [minimum, maximum]. Can only be used in
isosurface functions and function pigments.
But really, this is what the isoblob object was designed for, why not
use it? It is included in MegaPOV.
Chris Huff
Date: 16 Dec 1999 23:31:01
Message: <3859BAFD.4E15D2E8@isd.net>
Thanks for the info.
Because I like to experiment with the math, I find it interesting. I learn ten
times more on my own than I ever do in school.
Date: 17 Dec 1999 06:56:11
Message: <chrishuff_99-8CBA3B.06564517121999@news.povray.org>
> learn ten times more on my own than I ever do in school.
I know what you mean, especially with all the time school wastes
"teaching" stuff they already taught you or which you learned in other
places. And their assumption that whatever you learned on your own is
worthless.
Oh well, I am done ranting now. :-)
Chris Huff
Date: 17 Dec 1999 17:11:29
Message: <385AB390.71D8DAB2@isd.net>
I'm never done ranting!
I think school wouldn't be *that* bad if they didn't always hold people
back. Math is finally moving at a decent pace now, I'm getting my first
new material in 3 years. If the counselors did more than pick their butts
all day I could have had this new material 3 years ago. Everything goes
down the toilet in middle school.
Actually, I heard once that the USA has some of the best elementary
schools, but some of the worst high schools. My theory is that middle
school f*cks it all up and the high schools can't get students back on
track fast enough.
Date: 22 Dec 1999 19:09:55
Message: <38616853@news.povray.org>
Hi
units
To blob them together you could try this:
Sum up for all your functions f : 1/f(x,y,z)
To bound the values and gradients you might have to use min
(sum,someconstant). Also you will have to negate the sign-value and adjust
the threshold-value.
Well, I hope that was what I've tried lately. Can't look it up now, sorry.
Have fun
                   Bjoern
