POV-Ray : Newsgroups : povray.advanced-users : Req: isosurface function Server Time
15 Mar 2026 09:23:42 EDT (-0400)
  Req: isosurface function (Message 1 to 10 of 20)
Subject: Req: isosurface function
Date: 16 Nov 1999 19:06:51
Message: <3831F244.2665456B@peak.edu.ee>
Could somebody provide me with a function (preferably in a no-brainer macro form
:) that gives concentric cones? I want to use it in a pigment...
Thanks
Margus
Subject: Re: Req: isosurface function
Date: 17 Nov 1999 03:05:30
Message: <dF0yOJvKet+xMsPMYJ4SUMtm7RYo@4ax.com>
On Wed, 17 Nov 1999 02:09:40 +0200, Margus Ramst <mar### [at] peakeduee>
>Thanks
>Margus
Concetric in what manner? Sharing a common vertex and concentric in
terms of angle, or sharing a common angle and concentric in terms of
vertex and base?
Peter Popov
ICQ: 15002700
Date: 17 Nov 1999 05:56:43
Message: <38328A93.B4588A1@peak.edu.ee>
The latter.
Margus
> vertex and base?
> Peter Popov
> ICQ: 15002700
Date: 17 Nov 1999 08:11:40
Message: <3832A98B.640E9D35@inapg.inra.fr>
Still not sure to fully understand what you need, but would something like
this work ?
(To be used with the superpatch of course)
camera{location  -z*10  look_at   0}
plane{ z,0
  texture {pigment {crackle      form x      frequency 3
      color_map{[0 color <1,0,0>][0.25 color <1,1,0>][0.5 color rgb
0][0.75 color <0,0,1>][1 color <0,1,0>]}         }
    finish{ambient 1 diffuse 0}
G.
Margus Ramst wrote:
> The latter.
> Margus
> > vertex and base?
> > Peter Popov
> > ICQ: 15002700
Date: 17 Nov 1999 08:28:57
Message: <FK0yOJfwhr=b31Q=MNnpeMuBacT5@4ax.com>
I wrote,
>> vertex and base?
And on Wed, 17 Nov 1999 12:59:31 +0200, you wrote:
>The latter.
>Margus
So, what parameters will you need? Vertex1, Vertex2 (vectors), Radius1
and Radius2 (floats), right? Maybe just Radius1 and Radius2, with
vertices 1 and 2 being <0,0,0> and <0,1,0> resp. I will think about
that.
Peter Popov
ICQ: 15002700
Date: 17 Nov 1999 08:37:54
Message: <3832B054.7F2551EA@peak.edu.ee>
Hmm... No.
I mean something like the wood pattern, which is basically concentric cylinders.
Imagine a stack of cones, all having the same XZ axis and vertex angle, but each
uniformly scaled larger than than the previous one. This is basically how real
woodgrain is structured.
I hope this explains what I need...
Margus
> this work ?
Date: 17 Nov 1999 08:50:48
Message: <3832B35D.4916D41E@peak.edu.ee>
I would imagine that none of this is necessary, really. Preferably, this should
be an infinitely looping pattern, with the tip of the cones tapering to a point,
and the cones themselves extending into infinity. The vertex angle might make
things more convenient, but everythig can be adjusted by scaling.
I re-iterate, I would use this function for a pattern, not some finite object.
Margus
Peter Popov wrote:
> I wrote,
> >> vertex and base?
> >The latter.
> >Margus
> that.
> Peter Popov
> ICQ: 15002700
Date: 17 Nov 1999 09:15:58
Message: <3832B897.5BCA2F08@inapg.inra.fr>
What I still have trouble figuring out is the kind of pattern you expect to see when
applied to an object, and how it would be different from regular wood, or onion, or
even spherical. Perhaps you could hand-draw something and post it in binaries ???
G.
Margus Ramst wrote:
> Hmm... No.
> Margus
> > this work ?
Date: 17 Nov 1999 09:26:43
Message: <3832bb23@news.povray.org>
After _LOTS_ of thinking I got a really short answer:
  Given an aperture angle 'Angle' for the cone and a point 'p' in space,
the color for that point is:
-sin(Angle)*abs(p.x)+cos(Angle)*vlength(<p.y,p.z>)
Date: 17 Nov 1999 09:29:12
Message: <3832bbb8@news.povray.org>
(Of course if you need a value between 0 and 1 you have to clamp the value
returned by that function; I don't know how isosurface functions work but
I suppose that they do the clamping by themselves when calculating
pigments.)
