![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Trying to find a, unit long) vector parrallel to the intersection line of two
planes, and in an attempt to understand vcross, I did the following:
take 3 points: A, B, C.
N1= vnormalize(A-B)
N2= vnormalize(A-C)
Nx is the normal of a plane
L= vnormalize(vcross(N1,N2))
Is L the vector I'm looking for?
If not, how do I find the vector, and what is the meaning of vcross?
ingo
Met dank aan de muze met het glazen oog.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>N1= vnormalize(A-B)
>N2= vnormalize(A-C)
Where are A, B, and C?
If N1 and N2 are the normals of the planes, then L is indeed the vector you're
looking for. To find the normal of a plane given three noncollinear points
A, B, C on the plane, you'd use vnormalize(vcross(B-A,C-A)). Repeat for three
points in the other plane. You can leave off the vnormalize in this case
because you'll be normalizing your final result.
vcross is the vector cross-product, which is a vector perpendicular to both of
the two given vectors and with a length equal to twice the area of the triangle
between the two vectors.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ron Parker heeft geschreven in bericht <37b1df4f@news.povray.org>...
>looking for.
In my case three points on a bicubic_patch, and N1, N2 are the normals of the
planes.
And this bit goes into my "knowledgebase".
The docs say something similar, but reading it and understanding it are two
things.
Thanks Ron,
ingo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I should have a visible demonstration of this up on the cyclopedia soon... I find a
picture is worth a thousand words. I'll let you know when it's done
> >looking for.
> planes.
> things.
> Thanks Ron,
> ingo
Joshua English
eng### [at] spiritone com
IQC: 1946299
"It's a thankless job, but I've got a lot of Karma to burn off."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
