POV-Ray : Newsgroups : povray.advanced-users : REQ: reorienting a vector Server Time
10 Apr 2026 02:24:04 EDT (-0400)
  REQ: reorienting a vector (Message 1 to 8 of 8)
Subject: REQ: reorienting a vector
Date: 24 Apr 1999 22:35:23
Message: <3722715b.0@news.povray.org>
Hey all you math-enabled people!
I need a macro to give me the rotation vector to rotate vector A to have the
same direction as vector B. I suspect I could do it myself, but could
somebody spare me the head-ache?
Margus
Subject: Re: REQ: reorienting a vector
Date: 24 Apr 1999 22:44:43
Message: <372271a9.213964711@news.povray.org>
On Sun, 25 Apr 1999 04:33:36 +0300, "Margus Ramst"
John VanSickle's Thoroughly Useful Macros will help with this.  A copy
of the one you need can be found at http://twysted.net/macroscope
Date: 24 Apr 1999 23:02:54
Message: <372277ce.0@news.povray.org>
Ronald L. Parker wrote in message <372271a9.213964711@news.povray.org>...
I don't think so. The Reorient macro is close, but it uses matrix
transformation to reorient an object. What I need is a rotation vector I
could use in vrotate().
Margus
Date: 24 Apr 1999 23:21:19
Message: <372379f4.216088045@news.povray.org>
On Sun, 25 Apr 1999 05:01:07 +0300, "Margus Ramst"
Ah, okay, that's actually how I read it at first, but I couldn't
imagine why you would need such a thing so then I assumed that you
really wanted the Reorient macro.  I can get you an angle and an axis,
which you can use with vaxis_rotate(), if you'd like.  This isn't
tested, so it may be faulty.  In particular, you may have to fix the
sign on the angle. (It's times like this that I don't trust a
left-handed coordinate system.)  You may, of course, get rid of all
the intermediate local variables and make this a one-liner.
#macro vvec_rotate( Vec, RefA, RefB )
  #local nA = vnormalize(RefA);
  #local nB = vnormalize(RefB);
  #local axis = vcross(nA,nB);
  #local angle = degrees(atan2(vlength(axis),vdot(nA,nB)));
  vaxis_rotate( Vec, axis, angle );
Subject: Re: reorienting a vector
Date: 25 Apr 1999 04:15:15
Message: <3722c103.0@news.povray.org>
Margus Ramst wrote in message <3722715b.0@news.povray.org>...
the
Interrupt me if I am wrong ;-) but do I understand you correctly?
You want to rotate a vector such, that it points in the same direction as
some other vector?
If so, I don't see the need for any rotational math. I would do it like
this:
Compute the length of vector A.
    lengthA = sqrt(Ax*Ax + Ay*Ay + Az*Az)
Normalize B to length 1. (B')
    lengthB = sqrt(Bx*Bx + Ay*Ay + Az*Az)
    B' = [ Bx/lengthB  By/lengthB  Bz/lengthB ]
Multiply it with the length of A (B'')
    B''= [ B'x*lengthA B'y*lengthA Bz*lengthA ]
B'' is now the same direction as B and with the length of A.
All in one formula:
            [ Bx / lengthB * lengthA ]
   B'' =    [ By / lengthB * lengthA ]
            [ Bz / lengthB * lengthA ]
(where lengthA and lengthB as given above)
Is that what you want?
Johannes.
P.S. So, I'm showing my math in public? I *really* hope I got it right ;-)
Date: 25 Apr 1999 09:31:41
Message: <37230b2d.0@news.povray.org>
Thank you, this is perfect.
One of these days I'm sure I'll learn to use vdot... Maybe. I hope.
Margus
Ronald L. Parker wrote in message <372379f4.216088045@news.povray.org>...
>#end
Date: 25 Apr 1999 09:32:11
Message: <37230b4b.0@news.povray.org>
Thanks. You understood correctly a somewhat incomplete explanation. What I
really needed was to rotate vector A by the same amount that base vector B
differs from new vector C (hope this makes sense). Ron seems to have divined
my purpose, so I have the answer.
BTW, you could've written
vlength(A)*vnormalize(B)
Trust me, I woud have understood :)
Margus
Johannes Hubert wrote in message <3722c103.0@news.povray.org>...
>some other vector?
>this:
>All in one formula:
>Johannes.
Date: 26 Apr 1999 00:39:07
Message: <3723DFEC.8D22575@ij.net>
	subtract?
