I used POV-Ray to make a character moving over some video background. It was simple to
render it into tga files each frame with alpha channel and import into Adobe Premiere
as
numdered stills. And when I placed my character into 2d scene I discovered a PROBLEM -
it has no shadow! May be anybody did the same and solved the problem?
I have only one idea - to render character without shadow but with alpha channel in
first sequence, and shadow without object in second, and then use images of second
sequence as
alpha chanel of completely black image. But this method first: needs 2 render stages,
second: sutable only for shadows on planes (because more complex surfaces will produce
shadows too).
So, we have a problem - to get image of our object and it's shadow and nothing else
at all. Is there a better way to do this, than mine?
Alex Kluchikov
mailto:klk### [at] ukr net
This would be easily solved if POV-Ray supported a "shadow function" of some
sort.
Hmm... maybe if I ever get back to working on Slime-POV...
- Slime
[ http://www.slimeland.com/ ]
>simple to render it into tga files each frame with alpha channel and import
>into Adobe Premiere as
>PROBLEM - it has no shadow! May be anybody did the same and solved the problem?
>channel in first sequence, and shadow without object in second, and then use
>images of second sequence as
>stages, second: sutable only for shadows on planes (because more complex
>shadows too).
>else at all. Is there a better way to do this, than mine?
Have you tried applying the "no_shadow" keyword in your shadow rendering
pass to the complex surface that you want to cast the shadow onto? That
might prevent it casting self shadows, but you probably need to ensure
that all parts of the surface that are visible from your camera position
are illuminated.
My usual method for this sort of thing is to do two renders, the first
one is for the shadows and has special lighting. The shadows are
rendered without alpha, but with very bright lighting (I use rgb 10) so
that the surface onto which the shadows are cast becomes 100% white
where it is illuminated. All the objects are no_image.
I then use a second POV render stage, with normal intensity lighting, to
render the objects and cast the shadow image map onto the background by
using a two-colour gif image with transmit palette specifiers that makes
the white bits invisible and the dark bits partially transparent,
something like.
object { Background
pigment {image_map {gif "shadow2.gif" once
transmit 1,1 // bright bits become 100% transparent
transmit 0,0.8 // dark bits partially transparent
rotate x*90
translate <-5,0,-5>
The thing about two-colour gif images is that it should be easy to know
which palette numbers correspond to your two colours. If you want soft
shadows, I think you may need to have 256 transmit palette entries.
Mike Williams
Gentleman of Leisure
Mike Williams wrote:
--skip--
>something like.
--skip--
>Mike Williams
Ok. My method is almost the same. But DO we need two stages of rendering?
I'm not too lazy, but I'd like to render scene once... But maybe two-staged
render os the only possible way. :(
Bye.
Yours KLK aka Alex Kluchikov
Alex Kluchikov <klk### [at] ukr net> wrote:
> And when I placed my character into 2d scene I discovered a PROBLEM - it has no
I have thought about this same thing myself as well: How to create
a semi-transparent shadow of an object, which is projected onto the surface
of an invisible object (eg. a plane)?
There doesn't seem to be any viable and easy solution currently.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
In article <3e0cb100@news.povray.org>, Warp <war### [at] tag povray org>
Well, the problem is that a shadow is the absence of light on a surface,
not a "thing".
You could do something like an object whose transparency at a point is
dependant on how brightly lit that point is. You might want to ignore
any intersections with it after the first one. I don't think this would
be very useful...
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
> not a "thing".
Perhaps a patch could be made for this purpose. It wouldn't be realistic,
but it could be used for this special effect. It certainly has its uses.
It would be like an advanced drop shadow effect (like the one in most
image manipulation programs, but a lot more advanced in the sense that
the shadow can be "dropped" onto any (invisible) surface, not just
a plane facing the camera, like in the image manipulation programs).
This in conjunction with area lights would make very good effects for
transparent pngs.
It's not all that difficult to do with the official version of POV.
It just needs two passes.
<http://www.econym.demon.co.uk/shadowtut>
Mike Williams
