![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Is there a way to manipulate a image map on a height field, e.g. if I use a
material that contains an image map how do I translate and scale the
material map so it does not tile on the height field.
thanks
Mitch Waite
former publisher of Ray Tracing Creations, Image Lab and Fractal Creations
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Mitch,
you know, I was wondering whether it was you, I was just too shy to
ask :-). Wonderful to hear from you!
> Is there a way to manipulate a image map on a height field, ...
Sure. Once the image map material has been assigned to the
heightfield, it will be displayed as a green scquare. You can select
this square (either with Alt-T or graphically with the mouse) and then
scale and translate it into position, in this case preferably in the
TOP view.
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Manipulating a image map in Moray
Date: 31 Dec 2001 14:04:49
Message: <3c30b6d1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Excellent, thank you thank you, that was just what I needed.
I'm having fun with the new Moray, its an amazing improvment. I tried
fighting with Bryce on the Mac and got really frustrated with its interface,
then switched to Moray and it was like taking candy from a baby, soooo EZ.
(course I would never take candy from any baby :)
Mitch
PS I see how Alt T selects the material, but did not see it listed in the
Select tab so I could select it with the mouse like I select other objects.
Is there a way to make it show up in that list?
"Lutz Kretzschmar" <lut### [at] stmuc com> wrote in message
news:22a03uo4nmeq1jduig1ae8uec9b0q4nqu8@4ax.com...
> Hi Mitch,
> TOP view.
> Regards,
> - Lutz
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Mitchell Waite, you recently wrote in moray.win:
No, it's not listed there. You can select it with the mouse in the
views just like you select objects (Shift-Drag).
- Lutz
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
