POV-Ray : Newsgroups : moray.win : where are my legs? Server Time
17 Jan 2026 12:49:00 EST (-0500)
  where are my legs? (Message 1 to 10 of 12)
Subject: where are my legs?
Date: 5 Aug 2000 14:28:17
Message: <398c5cc1@news.povray.org>
In the moray.binaries area I posted a mdl file of a table I'm creating, but
when I put it in my scene and light it,
half the legs disappear.  at first I thought it was shadow, but then i put a
light right in the middle of the legs, and still the same.
any suggestions would be appreciated/
thanks,
Dean
ps if you use the animation plugin and render from that in raytracer mode,
you can see it in white without texturing it's odd. half legs
Subject: Re: where are my legs?
Date: 5 Aug 2000 14:39:54
Message: <398c5f7a@news.povray.org>
I've enclosed a pic textured with 3 lights
1 directly above table
1 directly below table between legs
and 1 to the left of camera in front of table
still top of legs missing
Download 'table.png' (8 KB)
Preview of image 'table.png'
Date: 5 Aug 2000 15:25:30
Message: <398c6a2a@news.povray.org>
Are they bounded in any way?  That could clip them if so I guess.
You don't mention what objects are involved (box, etc.) in the CSG.
Date: 5 Aug 2000 15:42:16
Message: <398c6e18@news.povray.org>
sorry
the top is csg box differenced by four cylinders to trim the edges, and the
legs are translational sweeps (only because I thought I'd taper them)
no bounding boxes I'm aware of, and there is 1 sweep, and 3 references to
that.  The sweeps are 2 units high, and the cut off seems to be at the 1
unit line.
Date: 5 Aug 2000 18:02:46
Message: <398C8EE1.EEE1A755@yahoo.com>
do you get the same results against a white background?
> thanks,
> Dean
Date: 5 Aug 2000 18:31:17
Message: <398C958F.4E238B33@yahoo.com>
i just rendered your table and it came out fine.  i used a white
background.  by the way, is there a reason you used groups instead of
csg?  if i remember correctly, groups are moray specific and don't
translate to anything pov.  i could be wrong.  i just always use csg.
> > thanks,
> > Dean
Subject: Re: where are my legs? Lost in the ANIM Plugin
Date: 5 Aug 2000 22:41:12
Message: <398cd048@news.povray.org>
Got it
I was doing quick renders using the animation plugin renderer set to
raytracing for whatever reason it croaks at one unit for the legs.  Povray
rendered fine
Xander any thoughts?
I apologize for posting all this binary stuff in the wrong place.  I posted
in both, but the thread took off here.
my last attachment for this group, I promise, will be the scene file.  It
almost looks as if it has something to do with my texture ballwood not sure
though.
RYAN,
groups worked if not translated into anything in POV, however, In my
organizational thought groups aren't csg (a group of non attached legs) vs.
the csg of the tabletop and cylinders.  It's just in my head.
Thanks for the help apparently it's in the animation plugin raytracer.
my next question is this what are the green things attached to the texture
that show up in my modeling space.  I can select them, and move them, but
what are they?
Dean
Download 'table2.mdl.dat' (6 KB)
Date: 6 Aug 2000 10:01:29
Message: <eurqosk96skcou24mmps6lb3m102vkdleu@4ax.com>
Hi Dean MacIsaac Jr., you recently wrote in moray.win:
> what are they?
They are texture proxies. They help you see where your texture is
placed.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 7 Aug 2000 21:43:34
Message: <398F65DE.34EC00F7@mitre.org>
> Got it
> rendered fine
Sure - my first thought is I have a bug to find.  I'll look it over and
see what's going on.
Xander
Date: 14 Aug 2000 09:46:44
Message: <3997F871.1C42F35@mitre.org>
I found the bug.  Turns out I wasn't paying proper attention to the
zmin/zmax values for a translation sweep (a box might have been better
for your particular scene anyway...).  You can get around it for now by
making the sweep go from 0 -> 1 in z and using scaling to make it the
right size.  Will be fixed in next version.
Xander
> > Got it
> > rendered fine
> Xander
