According to Chris Colefax's Galaxy.inc documentation, to turn off nebulae
(and just have a nifty background starfield) we should set galaxy_bgnebula
to false. However, it doesn't appear that Moray will allow me to set this
value below 1. Ideas of how to turn off nebulae?
Incidentally, this doesn't seem to work if I set galaxy_bgnebula = false by
hand in the pov output from Moray either. But I suppose *that* question
shouldn't be asked here. Not that I'd ever try and sneak in an extra
question that doesn't quite belong...
- How
Hi How,
Just set the Options Only checkbox - however you will then have to
set-up all of the
other options that you need!
BFN
Keith
> - How
Hmm. Regardless as to whether Options Only is checked or not, Moray will
not allow me to lower bg_nebula below 1. My (flawed?) impression is that
this is how to turn of the nebulae. I cannot seem to turn them off from
within Moray (or by hand, either). Sorry if I'm being dense here...
- How (the confused)
Keith Hull <kei### [at] totalisecouk> wrote in message
news:39579A86.2500F322@totalise.co.uk...
> Hi How,
> set-up all of the
> BFN
> Keith
By hand, you will need to set the option after including Galaxy.inc and
before including Galaxy.bg (assuming you want to use Galaxy.inc to set some
random options - if not, you can skip it altogether and declare your desired
options before including Galaxy.bg), e.g.:
#declare galaxy_seed = 12932;
#declare options_only = true;
#include "galaxy"
#declare galaxy_bgnebula = false;
#declare galaxy_nebula_sphere = false;
#include "galaxy.bg"
Hi How,
What version of the Galaxy PlugIn do you have?
The latest version should allow you to reduce the bg_nebula to 0.
Keith
> > Hi How,
> > set-up all of the
> > BFN
> > Keith
Ah, it appears I have a version dated 1/6/00. I'm downloading the updated
one right now. Thanks, Keith.
And thank you, Chris as well - your advice fixed the hand-coding problem.
- How
news:3958D999.9A8DC9F8@totalise.co.uk...
> Hi How,
> Keith
