POV-Ray : Newsgroups : moray.win : decoding clouds Server Time
28 Jul 2024 14:31:41 EDT (-0400)
  decoding clouds (Message 1 to 4 of 4)
Subject: decoding clouds
Date: 13 Jun 2000 18:23:38
Message: <3946b46a@news.povray.org>
I've been trying to use the following pov-ray code in moray without much
success. Can this be used in moray or is it just megapov specific?
Thanks,
dcc
difference{ sphere{ <0,0,0>, 10010 } sphere{ <0,0,0>, 10000 } hollow
translate <-40,-10000+90,0>
//box{ <-100000,40,-100000>, <100000,50,100000> hollow
  pigment{ color rgbf <1,1,1,1> }
  interior{ media{
      method 3  intervals 1  samples 20,1000  aa_level 6
      emission <1,1,1>
      scattering{ 1, color rgb <1,1,1> }
      density{ wrinkles
        density_map{
          [0 color rgb <0,0,0>]
          [0.6 color rgb <0,0,0>]
          [1 color rgb <1,1,1>]
        scale 150
Subject: Re: decoding clouds
Date: 13 Jun 2000 18:27:52
Message: <3946B4C1.3EF69DF4@pacbell.net>
> Thanks,
> dcc
>   interior{ media{
>       emission <1,1,1>
>       density{ wrinkles
>         density_map{
>         scale 150
This is specific to MegaPov. You can tell because it uses sampling
method 3 and aa_level 6. If you remove these and increase the
intervals level you might get similar results but there is no
gaurantee that you will get a perfect match and it is likely
that the rendering time will be much longer.
Date: 13 Jun 2000 20:47:24
Message: <3946d61c@news.povray.org>
That's what I thought.
Thanks anyway.
dcc
Ken wrote in message <3946B4C1.3EF69DF4@pacbell.net>...
>> Thanks,
>> dcc
>> file://box{ <-100000,40,-100000>, <100000,50,100000> hollow
>>   interior{ media{
>>       emission <1,1,1>
>>       density{ wrinkles
>>         density_map{
>>         scale 150
>Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
>http://home.pacbell.net/tylereng/index.html http://www.povray.org/links/
Date: 14 Jun 2000 04:32:26
Message: <3947430A.E9266414@umh.ac.be>
To use this script with moray, you must use it as an include and it
will work ok (if you render the scene with megapov of course).
Fabian.
> Thanks,
> dcc
>   interior{ media{
>       emission <1,1,1>
>       density{ wrinkles
>         density_map{
>         scale 150
