I've been trying to use the following pov-ray code in moray without much
success. Can this be used in moray or is it just megapov specific?
Thanks,
dcc
difference{ sphere{ <0,0,0>, 10010 } sphere{ <0,0,0>, 10000 } hollow
translate <-40,-10000+90,0>
//box{ <-100000,40,-100000>, <100000,50,100000> hollow
pigment{ color rgbf <1,1,1,1> }
interior{ media{
method 3 intervals 1 samples 20,1000 aa_level 6
emission <1,1,1>
scattering{ 1, color rgb <1,1,1> }
density{ wrinkles
density_map{
[0 color rgb <0,0,0>]
[0.6 color rgb <0,0,0>]
[1 color rgb <1,1,1>]
scale 150
> Thanks,
> dcc
> interior{ media{
> emission <1,1,1>
> density{ wrinkles
> density_map{
> scale 150
This is specific to MegaPov. You can tell because it uses sampling
method 3 and aa_level 6. If you remove these and increase the
intervals level you might get similar results but there is no
gaurantee that you will get a perfect match and it is likely
that the rendering time will be much longer.
That's what I thought.
Thanks anyway.
dcc
Ken wrote in message <3946B4C1.3EF69DF4@pacbell.net>...
>> Thanks,
>> dcc
>> file://box{ <-100000,40,-100000>, <100000,50,100000> hollow
>> interior{ media{
>> emission <1,1,1>
>> density{ wrinkles
>> density_map{
>> scale 150
>Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
>http://home.pacbell.net/tylereng/index.html http://www.povray.org/links/
To use this script with moray, you must use it as an include and it
will work ok (if you render the scene with megapov of course).
Fabian.
> Thanks,
> dcc
> interior{ media{
> emission <1,1,1>
> density{ wrinkles
> density_map{
> scale 150
