POV-Ray : Newsgroups : moray.win : Animation Plug-in Server Time
28 Jul 2024 16:27:40 EDT (-0400)
  Animation Plug-in (Message 1 to 9 of 9)
Subject: Animation Plug-in
Date: 3 Mar 2000 08:53:33
Message: <38bfc3dd@news.povray.org>
I noticed if you right mouse click on the key at the lower left of the
screen you have Set->Selected/Object/Scene  - what does each do?  I would
suspect that I need to select Scene for each key frame.
Mike
mwe### [at] sciticom
For 3D pictures and animations http://www.geocities.com/mikepweber
Subject: Re: Animation Plug-in
Date: 3 Mar 2000 10:01:52
Message: <38bfd3e0$1@news.povray.org>
Now that I actually tried it - I see that Scene isn't implemented yet.
Mike
"Mike Weber" <mwe### [at] sciticom> wrote in message
news:38bfc3dd@news.povray.org...
> Mike
Date: 3 Mar 2000 11:21:58
Message: <38bfe6a6@news.povray.org>
That's for forcing the keyframe (when you don't get a yellow key otherwise, if
that can ever happen) while setting them up as you normally would, for example
if you want the another keyframe somewhere in-between two which were already
set.
'Selected' should set the current highlighted portion of a model/object, and
'Object' would be any Parent including Children (or vice versa) parts I guess,
but I don't know.
You can say Delete>Scene to reset the keyframing to none and still leave the
scene in it's current state so you can start again from there without any
previous animation remaining as I understand it.
"Mike Weber" <mik### [at] pyxiscom> wrote in message
news:38bfd3e0$1@news.povray.org...
| Mike
| > Mike
Date: 3 Mar 2000 13:59:48
Message: <38c00ba4$1@news.povray.org>
Thanks Bob,
From another time that I was testing out the anim plug-in, I noticed that I
was able to animate the scene without doing any rendering - but I don't know
how I did that.  I went back to try again, but still can't find a menu
command to do this.  Any ideas?
Mike
"Bob Hughes" <omn### [at] hotmailcom?subject=PoV-News:> wrote in message
news:38bfe6a6@news.povray.org...
otherwise, if
example
already
> set.
and
guess,
> but I don't know.
the
> Bob
> | Mike
would
> | > Mike
Date: 3 Mar 2000 14:48:49
Message: <38C0135C.B79D93D4@gmx.de>
> that I was able to animate the scene without doing any rendering -
> but I don't know how I did that.  I went back to try again, but
> still can't find a menu command to do this.  Any ideas?
That's easy, and it can help quite a lot. Just activate the animation
controls and pull the VCR at animation speed. If your computer is fast
enough, Moray will redraw the scene quite completely so that you can
actually see something :-)
ToDo for Xander: please add a button for 'playing' the anim
automatically!
Florian
Date: 3 Mar 2000 15:19:31
Message: <38c01e53@news.povray.org>
The camera also needs to have a move option so that it can be moved in one
step rather than move the position, then the look_at.
Mike
"Florian Fischer" <flo### [at] gmxde> wrote in message
news:38C0135C.B79D93D4@gmx.de...
> automatically!
> Florian
Date: 6 Mar 2000 07:44:29
Message: <38C3A82A.476F4B76@mitre.org>
The greyed out middle button on the VCR controls is for doing just
that.  The problem is that it hasn't gotten implemented yet.  I'm
thinking along the lines of playback as fast as your machine will go and
playback at a particular speed (maybe the FPS you selected in the anim
options?) with frame dropping if Moray can't keep up.
Until then, click on one of the arrow buttons on the time slider and
keep the mouse button down.  It will provide close to what you want...
Xander
Mike Weber wrote:
> Thanks Bob,
> Mike
Date: 6 Mar 2000 07:48:00
Message: <38C3A8FE.30E9D29B@mitre.org>
That sounds more like a Moray/UI problem, rather than an animation
plugin problem.  I just track what you did to the camera.
Xander
Date: 6 Mar 2000 09:00:08
Message: <38c3b9e8@news.povray.org>
Xander -
I agree.  Since the subject was animation related, it came to mind.
Sounds like this is better for a Moray next release request.
Mike
Alexander Enzmann wrote in message <38C3A8FE.30E9D29B@mitre.org>...
>Xander
one
