POV-Ray : Newsgroups : moray.win : Bug in export? Server Time
17 Jan 2026 19:54:18 EST (-0500)
  Bug in export? (Message 1 to 8 of 8)
Subject: Bug in export?
Date: 27 Oct 1999 00:23:14
Message: <38167e32@news.povray.org>
Occasionally, when I translate an object, I get an error in POV-Ray when
raytracing.  Turns out that occasionally, Moray will export (in a position
vector) something like #INF00.  If I move the object somewhere else, then
move it back, the problem is fixed on the next export.
This message brought to you by:
-=< Ian (the### [at] hotmailcom >=-
Please visit my site at http://spectere2000.cjb.net! :)
Subject: Re: Bug in export?
Date: 27 Oct 1999 03:40:36
Message: <3816ac29.915115@194.174.214.110>
Hi Ian Burgmyer, you recently wrote in moray.win:
Do you see any pattern to it? Does it occur when you are moving the
object in a specific view? Or very far away? Try to see if there is a
pattern to it.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 27 Oct 1999 03:58:36
Message: <3816b0ac@news.povray.org>
i get this occasionally, but also things like
whateveer <35.56,45,345.000000000000000000000000 and on and on>
usually when using a plug when i think abouyt it, but deleting the object or
moving it seems to have fixed the problem everytime so far..
odd
Ian Burgmyer <the### [at] hotmailcom> wrote in message
news:38167e32@news.povray.org...
Date: 27 Oct 1999 05:32:19
Message: <3816c6a3@news.povray.org>
Ian Burgmyer <the### [at] hotmailcom> wrote:
: Occasionally, when I translate an object, I get an error in POV-Ray when
: raytracing.  Turns out that occasionally, Moray will export (in a position
: vector) something like #INF00.  If I move the object somewhere else, then
: move it back, the problem is fixed on the next export.
  This sounds like the program is outputting the result of an illegal
operation. This kind of result appears with operations like x/0 (= inf),
-x/0 (= -inf) or 0/0 (= not-a-number). There exists notations for these
three kind of illegal numbers in the floating point format used by the FPU
and when a compiler generates code for printing those illegal numbers, it
generates something like what you are saying above.
Date: 28 Oct 1999 08:07:35
Message: <38183CC1.98AB65C6@mninter.net>
But shouldn't Moray crap out when doing operations like this? I know when I make
programs that divide by zero, they seriously crap out- why doesn't moray?
Your claims are silly and ridiculous... I'm old, not brain damaged.
-Debate Ballot
Date: 7 Nov 1999 00:58:44
Message: <38251514@news.povray.org>
Lutz Kretzschmar <lut### [at] stmuccom> wrote in message
news:381### [at] 194174214110...
> pattern to it.
> - Lutz
Sorry for the long reply time. . .
No, actually I see no pattern in it.  It seems to happen when I change
something in the texture and translate the object at the same update, but
I'm really going to have to do a bit more investigating to really give you
anything isolated.
One thing I do notice, it always happened when I'm already ready to throw
the computer out the window ;)
Date: 7 Nov 1999 01:00:43
Message: <3825158b@news.povray.org>
Alex Magidow <axi### [at] mninternet> wrote in message
news:38183CC1.98AB65C6@mninter.net...
when
position
then
I make
Ditto here.  Unless Moray has it's own error handler, which I don't really
think is very logical in a Windows program, and is it even POSSIBLE without
seriously hacking up the code?  And, if there is such an error handler, then
I'd think it would iron out these kind of things.  I dunno.
Date: 11 Nov 1999 04:27:38
Message: <382a8c0a@news.povray.org>
news:3825158b@news.povray.org...
[snip]
without
then
It's built in into the output functions of C++ i think.
Try "printf("%d", 10/0);" or "cout << (10/0);" and you should get something
like that (I think).
On the other hand, if you try "int x = 10 / 0"; you will get an exception.
Johannes.
