I have two questions...
1) How can you render something and leave the wireframe on as in not using
any texture? I need this to produce a
"Moray - Under Contrustion" picture for my site.
2) I've seen pictures not made by Moray, and they have curves on their
cylinders/spheres/ect.. Like if I want to add a hump on a cylinder, how
would I do that?
Thanks in advance!
Hi Exploit, you recently wrote in moray.win:
> any texture?
You can't (simply). What you need to do is to place objects (like
cylinders) where you want the wireframe to be.
> would I do that?
Since Moray only supports the primitives that POV-Ray supports it
doesn't offer triangle mesh modelling. But that is what you would need
to do what you are suggesting.
- Lutz
email : lut### [at] stmuccom
Web : http://www.stmuc.com/moray
> > any texture?
Actually, you can use a wireframe texture. Just do a couple of gradients, in
whatever color you like, with transparence in between. You can also take a
screenshot or something.
> > would I do that?
Heres a couple of utilities that'll do what you want, and export to a format
convertable to UDO/INC with 3DWin(comes with moray, methinks):sPatch:
http://www.cableone.net/alyson/spatch.html
Geometique: http://www.geometique.com
Then, you either convert them to UDO/INCs(or, in the case of sPatch, you can get
the Moray export plugin), and load them into moray. Hope that helps.
> - Lutz
You Know You've Been Raytracing Too Long When:
You personal correspondence to friends starts out with #Dear
hi..
i'm a registered Moray user.. i've been making pretty detailed scenes lately and
it would really help me if a feauter was added.. the dependancy's button is great
but you think you could make an option to copy all the dependacy's to one
location.. to make backups.. it would be great to be able to backup an entire
scene to a directory without digging thorugh each directory hopign to get all the
files needed for the scene..
thanks
darrell miller
> > any texture?
> > would I do that?
> - Lutz
