POV-Ray : Newsgroups : moray.win : Liquid Spray? Server Time
29 Jul 2024 00:36:14 EDT (-0400)
  Liquid Spray? (Message 1 to 2 of 2)
Subject: Liquid Spray?
Date: 30 Jun 1999 11:29:55
Message: <377a37f3@news.povray.org>
I have just downloaded Liquid Spray plugin for Moray, and when I render the
scene (with lights and a camera, I wouldn't forget those:-), I see nothing.
The following fields are set:
Transformation:  1,1,1
Rotate:  0,0,0
Translate:  0,0,0
Strength:  11.0
Gravity:  9.5
Count:  200
Life:  1.8
Stretch:  3.0
Distance:  2.0
Evaporate:  0.0
Spray Loop:  NOT SELECTED (I just want a still picture)
Nozzle spin:  33
Nozzle Angle:  80
Nozzle Width:  2
Neither Blob option is selected, although I have also tried various combo's,
to no avail
Use Ground Plane:  NOT SELECTED
Turbulence Options:
Spray:  .1
Scale:  0.0
Velocity:  0.0
Angle:  0.0
Spin:  0.0
Wind:  0.0
Spray Seed:  0.0
Flow Rate:  1.0
Time Scale:  1.0
Direction:  0,0,1
Wind Dir:  0,0,0
Use Material Texture:  CHECKED
I have a material texture called RED, which is just a solid red pigment,
nothing fancy.  When POV-Ray renders this, it says there are 0 frame-level
objects and 0 infinite objects.  What am I doing wrong?  Help?  Thanks, and
please email me answers if you could.
John
alb### [at] rdsimplexnetcom
Subject: Re: Liquid Spray?
Date: 23 Aug 1999 15:19:24
Message: <37C204B1.65107F32@t-online.de>
> Rotate:  0,0,0
> Translate:  0,0,0
> Strength:  11.0
> Gravity:  9.5
> Count:  200
> Life:  1.8
> Stretch:  3.0
> Distance:  2.0
> Evaporate:  0.0
> Nozzle spin:  33
> Nozzle Angle:  80
> Nozzle Width:  2
> to no avail
> Turbulence Options:
> Spray:  .1
> Scale:  0.0
> Velocity:  0.0
> Angle:  0.0
> Spin:  0.0
> Wind:  0.0
> Spray Seed:  0.0
> Flow Rate:  1.0
> Time Scale:  1.0
> Direction:  0,0,1
> Wind Dir:  0,0,0
> John
Hi John!
I'm not shure, but I think you've got to set the "Spray Loop" to TRUE.
If you don't, the spray include file thinks that it has to generate an
animation with a spray object with increasing strength in time. Since
the clock value is zero the spray does not appear. Setting the "Spray
Loop" to TRUE will generate a spray oject with full strength over all
frames even if the clock value is zero.
