POV-Ray : Newsgroups : moray.win : Scene render problem Server Time
18 Jan 2026 02:50:11 EST (-0500)
  Scene render problem (Message 1 to 10 of 13)
Subject: Scene render problem
Date: 16 May 1999 17:01:55
Message: <373F242A.5D59A9A6@pcsrock.com>
Greetings,
I'm a new user to Moray, and I have encountered a problem:
I have used Rhino to model a fairly complex scene.  I exported to .udo
format, producing a 224 meg include file (!).  After some brief fiddling
with the light sources and camera angle, I applied a wood material to
the entire .udo and performed a few test renders to fine tune the
camera.  Then I began to texture the scene, using a couple of Moray's
library textures, but mostly editing my own, with image and bump maps,
etc.  Everything looked good until render time, when POV died with the
following message:
     //   $MRY$:  'floor'
     #declare floor  <----ERROR
     destroy.inc:238:  error:  undeclared identifier expected but float
function 'floor' found instead
     Returned from rendered (non-zero return value)
Obviously floor is the name of one of my custom textures and destroy is
the name of the Moray .mdl.  I went in and looked at the destroy.inc,
and the floor entry doesnt really look any different than any of the
others.
I'm using the most recent version of both Moray and POV.
What in the name of polluted pixels am I doing wrong??
Thanks,
J R
Subject: Re: Scene render problem
Date: 16 May 1999 17:04:02
Message: <373f24b2.0@news.povray.org>
If you have spaces in your texture or object names, take them out and make
it all one word.  I've had this problem before.
-Ian
Johannes Riechart <ant### [at] pcsrockcom> wrote in message
news:373F242A.5D59A9A6@pcsrock.com...
> Greetings,
> following message:
>      //   $MRY$:  'floor'
> others.
> Thanks,
> J R
Date: 16 May 1999 17:32:22
Message: <373F2B4E.F43D11AD@pcsrock.com>
Ian,
I went and double checked the texture and object names to be sure... that's
not the problem.
Any other guesses?
Thanks
J R
> -Ian
Date: 16 May 1999 17:51:16
Message: <373f2fc4.0@news.povray.org>
Now this is a huge guess, but maybe the file didn't export properly.  If you
would, send me the POV file (it's in "Program Files\Moray for
Windows\PovScn\") and I may be able to see the problem.
-Ian
> Ian,
that's
> not the problem.
> Any other guesses?
> Thanks
> J R
make
> > -Ian
Date: 16 May 1999 18:12:03
Message: <373F349C.2F6B2AE8@pcsrock.com>
Ian,
consider it mailed.
Thanks,
J R
> -Ian
> > Ian,
> that's
> > not the problem.
> > Any other guesses?
> > Thanks
> > J R
> make
> > > -Ian
Date: 17 May 1999 00:03:01
Message: <373F86B0.BDC17840@Kopp.com>
Johannes Riechart wrote:
>      //   $MRY$:  'floor'
"floor" is a reserved word in POV-Ray.  Change the name to something else
and you won't see this error anymore.
-Nathan
Subject: Re: Scene render problem--solved
Date: 17 May 1999 00:13:30
Message: <373F8951.28F795E8@pcsrock.com>
Nathan,
Thanks a bunch for the tip-- I renamed the material and it worked perfectly.
Any other reserved words I should watch out for?  Or maybe read the
documentation a little more thoroughly  :-( !!
Thanks again,
J R
> -Nathan
Date: 17 May 1999 02:30:21
Message: <373FA939.E814EC36@pacbell.net>
> Nathan,
> Thanks again,
> J R
  The povray docs have an entire section devoted to detailing the
reserved keywords that is uses as instructions. It should not be
too difficult to locate but it certainly takes quite a while to
remember them all (or the majority of them). I thought I had heard
them all but the "floor" keyword floored me when I read Nathans
reply to you. What the word floor has to with math operators is
anyones guess but it is in the list. I guess it's time "I" RTFM !
  You can easily avoid any chance of having this happen again if you
always make sure your #declare identifiers are capitolized in the
first letter. You could have #declare Floor and be all right and I
often see #declare Sphere which is also exceptable because of the
capitolization of the first letter.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 17 May 1999 03:06:36
Message: <3740ad99.21747611@news.povray.org>
On Sun, 16 May 1999 20:13:21 -0700, Johannes Riechart
  Section 4.1.1 of the POV-Ray docs has a list of the reserved
keywords...
  Good catch, Nathan!
Alan
povray.org - official home of the Persistence of Vision Ray Tracer
news.povray.org - where POV-Ray enthusiasts from around the world
                - get together to exchange ideas and experiences
Date: 17 May 1999 03:30:45
Message: <373FB794.DE833737@aol.com>
'ceil' also exists, goes with 'floor' somehow I guess. What I didn't find
anything on is 'track'.
> > Nathan,
> > Thanks again,
> > J R
> Ken Tyler
 mailto://inversez@aol.com?Subject=PoV-News
