![](/i/fill.gif) |
Hi stefan, you recently wrote in moray.win:
> It is my understanding (correct me if I'm wrong) that although
> Moray3.1 ships with a plugin for Nathan Kopps' LensFlare include file,
> the plugin just provides for exporting parameters used by the lens
> flare include which is actually processed by POVRay.
OK, you are wrong<g>. The plugin exports the lens flare parameters and
then include 'NKFlare\xxxx.inc'. If you don't change the directories
from the default installation it'll work out of the box. If you do,
you'll need to copy the NKFlare subdirectory (found in POVSCN) to the
directory where you have your POV files created.
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
![](/i/fill.gif) |
