POV-Ray : Newsgroups : moray.win : help :) Server Time
28 Sep 2024 19:18:43 EDT (-0400)
  help :) (Message 1 to 5 of 5)
Subject: help :)
Date: 4 Oct 1998 21:32:27
Message: <3618144B.76C2AEB7@nettaxi.com>
'elloz all
I just started usin' Povray again (after last using it about 3 years
ago).. and also discovered Moray in the last few days.
I've figured out how to create new textures, edit them, export 'em,
etc..  But got a few questions :)
1) can I load .pov files into Moray and edit them in the viewable
windows?
2) I see how to load .inc files.. figured that out myself before all the
postings... but if I add a .inc file containing textures, how can I
assign those textures in my scene without having to export the .pov file
and manually edit it to the new textures.
3) How do I create anything other than cubes, spheres, standard shapes?
More complex stuff?  Are there any tutorials available on the web for
Moray (as opposed to Povray).
Thanks.
John Aldred
axe### [at] nettaxicom
Subject: Re: help :)
Date: 5 Oct 1998 03:46:00
Message: <36186b5e.890230@194.174.214.10>
Hi Axe, you recently wrote in moray.win:
> windows?
No.
Create a texture with the same name as the one you have in your
include file. Export the scene. Edit the INC file of the scene and
search for the texture name. Above it is a line that reads
  //$MRY:texturename
where texturename is the name of your texture. Change this line to
read:
  //$MRX:texturename
and delete the definition of the texture from this INC file.
When you next export the scene, Moray will not export the texture
again and POV-Ray will use the definition in your other INC file.
> More complex stuff?
Use CSG.
Hmmm, that's a tough one. You have worked through the tutorial that
comes with Moray I assume (Chapter 3 of the manual)? You may want to
check out http://twysted.net, he may have some tutorials.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 5 Oct 1998 22:14:47
Message: <36196FDD.6621D1D8@nettaxi.com>
> > windows?
> No.
Cool.. sharp, simple, to the point :)
> include file
Cool... got it :)
> > More complex stuff?
> Use CSG.
Yup... been playin' with CSG today...but having a slight prob.. well.. kinda..
(see attached image - will post the .mdl if anybody wants it)...
I'm just doing something basic and creating a column.... But having a slight
problem getting the texture to work right.Any hints anyone?
Nope.. none that I can find.. yup, I checked the one in the manual :)
> - Lutz
Thanks Lutz.
Date: 6 Oct 1998 06:27:31
Message: <3619da19.2824841@194.174.214.10>
It looks to me like you are assigning textures to each part of the
CSG. You need to attach the texture to the CSG only, not to the
subobjects (like the sphere/cylinder/sphere combo you are using to cut
away the grooves with).
- Lutz
Date: 6 Oct 1998 19:34:55
Message: <361A9BE4.792C7644@nettaxi.com>
> CSG.
Yuppers
Ahhh gotcha... altered, works.. cheers.. great stuff :)
> - Lutz
John
