![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
i've read about a future plugin interface
(http://www.stmuc.com/moray/menews.html) for moray.
Now my idea is - let's start a project for things, we "all" need in
Moray (the best ever seen ...), for example
- a mesh-editor, that moray can native handle this universal type of
objects
- an animation plugin
- import plugins for 3ds, lwo, obj, raw ...
... the great sense will be: lets make FREE things, to support moray in
the spirit of POV-Ray.
-- Steffen
... there's a question to Lutz Kretschzmar: Gibt es Einschraenkungen
fuer den C/C++-Compiler ??? (am besten waeren ja GCC, Borland, ... )
SPr### [at] heyde de
for reply remove no-spam from the e-mail adress
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Steffen Prietz, you recently wrote in moray.win:
> objects
This first version of the plugin interface does not allow a plugin to
takeover the views, so this is not going to be easily done.
This is thinkable with the current version....
This can be done, too, I've created Import and Export interfaces, but
you still need to write the code to handle the files<g>...
By default Plugins can be free, they will function in the shareware
and the registered version. If the developer wants to make a shareware
plugin, that can be done, too.
At the moment, the interface support MS VC++ 5.0, but this is because
I don't have another compiler at the moment. The plugin header file
should work on all compilers, once I've adapted it. The sample code
will probably only compile with MS VC, but should compile with others
with a bit of tweaking.
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
anyone know of a great blob editor?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
NO! No good blob editors that are non-commercial/shareware. Winblob,
which is barely adequate, can be aquired via POV ftp- however, I don't
know where exactly. Check out comp.graphics.rendering.raytracing
If anyone can program, it would be great to have a blob plugin for
Moray!!!!! I can program about as well as I can unicylce and juggle
simultaneously(the former is easy. Latter much harder. Together
impossible.)
"Intensification of food production to feed an increased
population only results in a further increase of population."
-Peter Farb
"It may be that my progeny[humans] will
teem over the earth like locusts,
stripping it bare,until they drown
in their own filth and hate the very
sight of one another and go
mad. Still they must go on,
because to grow without limit is
good and to accept the limits of the
law is evil." Ch.9-6 Ishmael, By Daniel Quinn.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
