POV-Ray : Newsgroups : povray.unix : Install povray-3.7.0.0 using source Server Time
11 May 2025 11:54:40 EDT (-0400)
  Install povray-3.7.0.0 using source (Message 1 to 10 of 12)
Subject: Install povray-3.7.0.0 using source
Date: 27 Apr 2023 01:10:00
Message: <web.644a03627994ebcf410f270e9fce7bf5@news.povray.org>
Hello folks,
I'm trying to install povray-3.7.0.0 on my machine. I've downloaded the tar file
and extracted the tar file but unable to find configure file in it.
I request if any one provide me the proper documentation where I can install
povray easily. or else
Help me out with steps to install povray on our machine.
Our machine is running with CecntOS 7.
Subject: Re: Install povray-3.7.0.0 using source
Date: 27 Apr 2023 02:15:00
Message: <web.644a122ff414c9be58c093306cde94f1@news.povray.org>
hi,
"puni" <pun### [at] gmailcom> wrote:
> Hello folks,
> I'm trying to install povray-3.7.0.0 on my machine. ... unable to find configure
file in it.
pre 3.8.0 beta versions, the 'configure' script was made from the archive's top
level directory, ie:
  $ ( cd unix ; ./prebuild-sh )
regards, jr.
Date: 4 May 2023 01:35:00
Message: <web.645343e1f414c9be98c6a7ac9fce7bf5@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> > Hello folks,
file in it.
> regards, jr.
I've executed ./prebuild-sh but after that I didn't get any configure file after
execution.
After execution of ./prebuild.sh the files are generated can be viewed in the
attached screenshot.
Download 'povray.jpg' (41 KB)
Preview of image 'povray.jpg'
Date: 4 May 2023 02:25:00
Message: <web.64534f73f414c9be58c093306cde94f1@news.povray.org>
hi,
> execution.
my bad.  typo, sorry.  as you found out, the name is 'prebuild.sh'.
starting "pristine" (source from github.com/POV-Ray/povray/tags/) -
  $ cd /tmp
  $ tar -xf v3.7.0.9.tar.gz
  $ cd povray-3.7.0.9
  $ ( cd unix ; ./prebuild.sh )
  $ ./configure ...
note that the INSTALL file carries complete instructions, and advice.  hth.
regards, jr.
Date: 4 May 2023 04:15:00
Message: <web.64536858f414c9be6621f1d9fce7bf5@news.povray.org>
> hi,
> > Hello folks,
file in it.
> regards, jr.
executed ./prebuild.sh and found configure file in it.
later I encountered with the error and attached with this reply.
Download 'povray1.jpg' (65 KB)
Preview of image 'povray1.jpg'
Date: 4 May 2023 07:00:00
Message: <web.64538f5ef414c9be58c093306cde94f1@news.povray.org>
hi,
first up, for building and testing, you do not need to be 'root'.  second, the
image shows me that the 'boost' library is not available, ie not installed.  you
don't say which (Linux?) OS you have, but, all things considered, I think you
ought to install a POV-Ray version via your OS' package manager first.  this
will ensure that all required libraries, and their header files, are in place
when you start building your own version(s).
regards, jr.
Date: 4 May 2023 07:55:00
Message: <web.64539c21f414c9be98c6a7ac9fce7bf5@news.povray.org>
> hi,
> regards, jr.
One confirmation to you, I've to install povray from source, I need this package
in all nodes of HPC cluster so I'm installing this on mounted storage system
from source.
I've given path of boost libraries while installing and it taken too, u can
check in previous attached image (whether the Boost::Thread library is
available... yes) but it is giving error with this line (whether the boost
thread library is usable... no)
Date: 4 May 2023 08:20:00
Message: <web.6453a170f414c9be58c093306cde94f1@news.povray.org>
hi,
> from source.
ok.
your '/usr/include/boost/' is fully populated ?  (I see a little more than a
screen's worth of sub-directories + headers)
if you have all headers, then I can't really guess.  fwiw, if you could capture
the output, something like
  $ script build-log
  $ ./configure ...
  $ make ...
  $ exit
and post it, I'd be happy to look it over (fwiw :-)).
regards, jr.
Date: 4 May 2023 15:23:37
Message: <64540639$1@news.povray.org>
> from source.
I'll say a few things in addition to what jr has said.
First, You've specifically stated the version of source you are trying
to compile is v3.7.0.0. There have been a number of issues fixed over
time and the current v3.7 source release is: v3.7.0.0.10. See:
https://github.com/POV-Ray/povray/releases/tag/v3.7.0.10
There have been a number of boost related linking issues in the past
with various compile configuration triggers. Many were worked around by
adding:
LIBS="-lboost_system -lboost_thread -lboost_date_time"
and later for a brief time just
LIBS="-lboost_date_time"
to the ./configure invocation.
The newer v3.8 release has worked to remove some of the boost
dependencies and IIRC v4.0 (master) uses only boost headers.
The latest v3.8 release - including a more traditional unix tarball
where you need run only the ./configure script in the traditional way
can be found at:
   https://github.com/POV-Ray/povray/releases/tag/v3.8.0-beta.2
with povunix-v3.8.0-beta.2-src.tar.gz being the traditional sort of unix
tarball.
Of course, you may or may not want to use v3.8 for other reasons.
Some linux distributions put the boost libraries in directory location
certain versions of autotools won't find automatically and you need to
point to the library explicitly while running ./configure.
This had to be done on some Raspberry Pi systems running the Raspbian OS
(Now called Raspberry Pi OS I think). Let me see if I can find that
thread... Yep, from June 2017 a user found they had to configure with:
  ./configure ... --with-boost-libdir=/usr/lib/arm-linux-gnueabihf
If your boost library is in a non-standard location, you might need
something similar while running ./configure. Though it looked from the
snippet as if you are finding some of boost during configuration for the
compile and link.
Bill P.
Date: 5 May 2023 00:25:00
Message: <web.6454841bf414c9be83ea0acb9fce7bf5@news.povray.org>
> > from source.
> adding:
> can be found at:
> tarball.
> compile and link.
> Bill P.
Thanks for your brief description, I've downloaded v3.7.0.10 tar ball and
configured with below option as u suggested but I'm unable overcome with an
error.
.../configure COMPILED_BY=ParamSeva --prefix=/opt/ohpc/pub/utils/povray/3.7.0.10
--with-boost=/home/apps/spack/opt/spack/linux-centos7-cascadelake/gcc-11.2.0/boost-1.79.0-sv5pretdpxzcpzqzivwu3mkbgjhr4
w3w
I'm getting the same error
checking for boostlib >= 1.37... yes
checking whether the Boost::Thread library is available... yes
checking for exit in -lboost_thread... yes
checking whether the boost thread library is usable... no
configure: error: in `/opt/ohpc/pub/source_files/povray-3.7.0.10/build':
configure: error: cannot link with the boost thread library
See `config.log' for more details
