POV-Ray : Newsgroups : povray.windows : Portable POV? Server Time
5 Feb 2026 01:00:54 EST (-0500)
  Portable POV? (Message 1 to 10 of 10)
Subject: Portable POV?
Date: 21 Oct 2009 08:20:01
Message: <web.4adefc22e3a0fbb7b297fcdc0@news.povray.org>
Hi folks.
First, it has been about three or four years since dabbling with POV. Life has a
way of getting busy! Anyway, I am trying to get back to rendering things and was
wondering if there is a standalone, portable version of POV that I could put on
a flash drive. I tend to bounce between computers at home and cannot install POV
al each of them (though I can run *.exe files...).
Any help would be much appreciated.
Thanks.
Paul
Subject: Re: Portable POV?
Date: 21 Oct 2009 09:05:01
Message: <web.4adf05fb9ec4d4483a6325dd0@news.povray.org>
"pdjones2112" <pau### [at] gmailcom> wrote:
> Hi folks.
> Thanks.
> Paul
Portable POV-Ray is a very good idea, I am also interested!
Date: 22 Oct 2009 02:35:00
Message: <web.4adffbae9ec4d448cac4259f0@news.povray.org>
> Hi folks.
> Thanks.
> Paul
It sounds like you're talking about POV-Win.  I think you can do this currently,
almost, or awkwardly at least.  What version of POV-Ray do you want to use?
I tried this:  If you copy the directory structure of an installed copy of v3.62
to a flash drive, and then run the executable on a different machine, it will
run.   However, first it will complain about the registry, the availability of
include files and it will create a POV-Ray directory in My Documents. (Earlier
versions like 3.61 shouldn't create that directory.) If you store a copy of the
files that are supposed to be in the My Documents\POV-Ray directory on your
flash drive, and copy them over(and either remove them or leave them when you're
done)*, you now have a not-exactly-hassle-free portable POV-Ray.  I tried this
up to the point before making sure all the library paths were correct in
povray.ini.
*I wouldn't put your scenes in this directory.
Charles
Date: 26 Oct 2009 14:10:01
Message: <web.4ae5e5df9ec4d448b297fcdc0@news.povray.org>
Sorry, yep the windows version. I would love to use the latest and greatest
release.
I was thinking that maybe there might be a way to configure the installation of
POV-Win such that you could specify a completely "local" installation. That is
to say, make pov run and store all files from a specified location (nothing is
done in any other folder/location).
This is well beyond my skill level though... :-)
paul
Date: 26 Oct 2009 15:29:52
Message: <4ae5f8b0$1@news.povray.org>
Actually it shouldn't be too difficult:
- The POV-Ray binary can be "installed" /anywhere/, even on a memory stick.
- You need to set up a few registry keys in HKCU\Software\POV-Ray, one
of which will point to the "installation" directory.
- As of POV-Ray 3.6.2 / 3.7.0, the sample, include and config files must
be copied to a directory named "POV-Ray/v3.6" or "POV-Ray/v3.7" in the
user's "My Documents" directory. (Unfortunately this can't be configured
with a registry key.)
It should be possible to write a batch file that copies all of POV-Ray's
files into the "POV-Ray/v3.x" directory in the user's "My Documents"
directory (including binaries), then creates the registry keys by
generating a registry patch file and have it imported using "regedit /s
MyRegistryPatch.reg".
Date: 27 Oct 2009 00:55:01
Message: <web.4ae67cb19ec4d448cac4259f0@news.povray.org>
> release.
Yeah... I noticed which newsgroup you were posting in only after my reply. :)  I
really haven't done more than try what I mentioned.
I agree, that sounds like it'd be a useful thing.
Charles
Date: 27 Oct 2009 01:00:09
Message: <web.4ae67e379ec4d448cac4259f0@news.povray.org>
I'm starting to wonder why POV-Ray uses the registry at all. (Store more in
pvengine.ini) Am I remembering correctly that there was some discussion of this
sometime in the recent past?
Charles
Date: 27 Oct 2009 01:05:05
Message: <web.4ae67f2b9ec4d448cac4259f0@news.povray.org>
> Charles
Ahh:
http://news.povray.org/povray.windows/thread/%3C47c08fb8$1@news.povray.org%3E/
Date: 27 Oct 2009 04:33:55
Message: <4ae6b073$1@news.povray.org>
 From what I see, the registry is used for all the stuff closely related
to CodeMax (the syntax-highlighting editor control used by POV-Ray for
Windows), while the pvengine.ini is used for everything else that's
specific to the Windows platform.
Date: 27 Oct 2009 04:36:23
Message: <4ae6b107@news.povray.org>
... and the beta timeout mechanism data resides in the registry, too,
but as that'll appear in the official release I wouldn't count it.
