POV-Ray : Newsgroups : povray.windows : WIndows 7 multi-core operation Server Time
2 Mar 2026 11:49:15 EST (-0500)
  WIndows 7 multi-core operation (Message 1 to 4 of 4)
Subject: WIndows 7 multi-core operation
Date: 21 Jan 2009 22:40:00
Message: <web.4977e9e71c8d05126dba9e5f0@news.povray.org>
I installed POVRay 3.7 Beta 30 on a Windows 7 Beta and the benchmark (all cores)
runs well. All other traces run with a single thread. I have checked and the
thread setting is at 4. Is this Windows or just the POVRay install...
Jay
Subject: Re: WIndows 7 multi-core operation
Date: 24 Jan 2009 08:16:59
Message: <497b14cb@news.povray.org>
this is interesting. what does the messages pane say at at startup about
the CPU? Just after the message about it being a time-limited beta test,
there is another section mentioning the tools menu and the CPU. For example:
  Loaded 8 tools into Tool Menu.
  Detected 2 CPU's providing 8 physical cores and 8 logical ones.
I would like to know the latter for your install.
(Also, what information are you using to determine the traces run with a
single thread? Observation of CPU load, or some other data?)
-- Chris
Date: 26 Jan 2009 07:00:00
Message: <web.497da526835cc853db9c0890@news.povray.org>
> -- Chris
It does not show number of cores found. just this:
THe thread count in the message window is what I was using, but I also installed
a gadget that showed core activity. The first day I ran it, it showed running on
1 thread on the message pane. When it rendered this morning, it ran on 4 threads
(a seperate gadget showed all four cores running this time). The render was also
a few seconds slower. (259 vs 254). Just so all information is there, I am
running 64 bit versions of Windows 7 and POVRay.
Off topic... POVRay login screen doesn't seem to like AOL software. Had to use
IE to post this message (couldn't login).
Jay
Date: 10 Feb 2009 16:13:31
Message: <4991edfb$1@news.povray.org>
"JayWiz" <nomail@nomail> wrote in message
news:web.497da526835cc853db9c0890@news.povray.org...
>> > (all cores)
>> > and the
Just FYI... I started using W7 beta (32 bit) last week on my AMD Turion 64
X2. No apparent problems.
> installed
> running on
> threads
> was also
Regular and SSE2 32 bit POV shows this correctly, for me, and renders the
benchmark in half/double the time as expected. Render menu, Thread Count...
also shows 2 automatically.
However, the photon parse reports threads erroneously:
  Photon Time:      0 hours  0 minutes  0 seconds (0.686 seconds)
              using 4 thread(s) with 0.686 CPU-seconds total
  Radiosity Time:   No radiosity
  Trace Time:       0 hours 13 minutes 21 seconds (801.795 seconds)
              using 1 thread(s) with 799.629 CPU-seconds total
And when All CPU's used:
  Photon Time:      0 hours  0 minutes  0 seconds (0.593 seconds)
              using 5 thread(s) with 0.685 CPU-seconds total
  Trace Time:       0 hours  6 minutes 46 seconds (406.521 seconds)
              using 2 thread(s) with 804.433 CPU-seconds total
Of course, since photons hasn't been finished AFAIK that's probably not
unusual.
