POV-Ray : Newsgroups : povray.windows : Splitter Server Time
16 Dec 2025 09:39:55 EST (-0500)
  Splitter (Message 1 to 10 of 12)
Subject: Splitter
Date: 3 Sep 2002 11:00:09
Message: <web.3d74cdb5a8d359cf2b597c920@news.povray.org>
I'd like to see the windows POV installer divided into floppy-fitting chunks
so I can take it from work (fast connection) to home (catatonic turtle
connection).  Or I could just download a splitter utility myself....
Where should/could I suggest this?
--Mark
Feel the power of the penguin at www.libranet.com
Subject: Re: Splitter
Date: 3 Sep 2002 11:15:33
Message: <3d74d215$1@news.povray.org>
"LibraryMan" <mrm### [at] attnet> wrote in message
news:web.3d74cdb5a8d359cf2b597c920@news.povray.org...
chunks
> --Mark
To do it yourself you could use either WinZIP (www.winzip.com), WinRAR
(www.rarlab.com/) or WinACE (www.winace.com/), all you are supposed to buy
but can 'evaluate'.  I prefer WinRAR myself.
-tgq
Date: 3 Sep 2002 11:26:27
Message: <3D74D4A3.B19F0C2C@gmx.de>
Floppy - that are these tiny plastic things formerly used for transporting
and storing data, right? ;-)
Yes, those good old times...
I guess you will have to split it up yourself.
Date: 3 Sep 2002 11:35:03
Message: <web.3d74d643bac72e722b597c920@news.povray.org>
Are you sure you can use WinZip that way, to actually _split_ a file?  I
could see compressing the other files into various zipped packages,
especially the ones that are only text or html, but the pov binary itself
is over the size of a floppy, and cannot be compressed but so much....  (I
should think)
The utility I was talking about can actually split files that weren't meant
to be split, and glue them back together.
--Mark W
>news:web.3d74cdb5a8d359cf2b597c920[at]news.povray.org...
>chunks
>> --Mark
>To do it yourself you could use either WinZIP (www.winzip.com, WinRAR
>-tgq
Date: 3 Sep 2002 12:01:16
Message: <3d74dccc@news.povray.org>
news:web.3d74d643bac72e722b597c920@news.povray.org...
> should think)
meant
    Yes - It's called Multiple Disk Spanning - the option to do this becomes
available in the WinZip Add dialog if you set the location of the target zip
file to be on a floppy...
Pandora/Scott Hill/[::O:M:C::]Scorpion
Software Engineer.
http://www.pandora-software.com
Date: 3 Sep 2002 12:04:03
Message: <3d74dd73$1@news.povray.org>
> should think)
meant
> --Mark W
You are supposed to be able to.  See WinZIP help regarding multiple volumes.
It appears you need to create a new archive, add the files you want and save
the .zip to the a:, WinZIP will prompt when you need to add another disk.
But as I said, I prefer WinRAR, much easier to use, especially for volumes.
-tgq
Subject: RE: Splitter
Date: 3 Sep 2002 14:58:28
Message: <3d750654@news.povray.org>
chunks
Try Hacha (Axe). It's a small program (19Kb) that split your files in the
size you want.
Very very useful. I've been using it all august and it is the easiest
program of its kind I've
ever had.
The link is (for the english language):
http://leodonaire.tripod.com/uk.htm
For the spanish language
Hope this helps
Txemi Jendrix
tji### [at] txemijendrixcom
http://www.txemijendrix.com
Date: 4 Sep 2002 08:55:36
Message: <3d7602c8$1@news.povray.org>
<snip>
As others have noted winzip (and pkzip) can do this, but, iirc, you have to be
writing to the disk directly, which can be a pain.
I've got a perl-script that will split and unsplit a file into user-specified
chunks (I wrote it to handle breaking up very large binary files into CD-sized
chunks).
Date: 4 Sep 2002 11:22:05
Message: <3d76251d$1@news.povray.org>
WinRAR will break it up into floppy sized pieces right on the hard disk.
-tgq
Date: 5 Sep 2002 13:02:14
Message: <Yj59lDAUUxd9Ew0G@econym.demon.co.uk>
I use a tiny free program called "Split" that was written by Syed Nasir
Alsagoff of Snake Soft in 1997. It will split any file, and also outputs
a BAT file that contains all the commands needed to join the bits
correctly at the other end. The recipient of the split file doesn't need
to have a copy of Split in order to reconstruct the original file.
It's small, free, fast and does the job, but you have to run it from a
DOS prompt.
Mike Williams
Gentleman of Leisure
