POV-Ray : Newsgroups : povray.windows : pvengine.ini now integrated into the registry? Server Time
16 Mar 2026 19:04:49 EDT (-0400)
  pvengine.ini now integrated into the registry? (Message 1 to 10 of 20)
Subject: pvengine.ini now integrated into the registry?
Date: 23 Feb 2008 16:27:20
Message: <47c08fb8$1@news.povray.org>
In the latest Beta 3.7.beta25 change log, it mentions the pvengine.ini
file is now integrated into the Windows registry. I'm curious as to why
this was done? The editor I can understand due to it's tight integration
with the Windows GUI manager. But why the pvengine.ini? Thx.
Subject: Re: pvengine.ini now integrated into the registry?
Date: 23 Feb 2008 21:56:41
Message: <MPG.222a8a4fbecda20298a108@news.povray.org>
In article <47c08fb8$1@news.povray.org>, jho### [at] northrimnet says...
Gah.. Good question. Most people in *any* sort of open source and/or
user modifiable code are moving away from that. There is even discussion
on the client I use for muds on when/if/how it should move its setting
out of there. The registry creates more problems than it solves usually,
and in the case of the client I mentioned, there is some bizarre bug
which causes the client to forget what the window sizes are, if you have
more than one open at a time. And that is not even mentioning stuff like
being able to export settings and import them to a different machine,
use programs across multiple machines, off of flash drives, and so on,
especially if you have restrictions on certain types of software
installs, and so on. It is, quite simply, a major pain in the ass that I
wish MS hadn't come up with, and completely absurd as a solution to much
of anything (especially now that XP and Vista "both" use user specific
folders for documents now, which means those kinds of settings could be
stored just like on *nix systems). In other words, the stupid reason
they came up with it in the first place, isn't necessary any more.
void main () {
    if version = "Vista" {
      call slow_by_half();
      call DRM_everything();
    call functional_code();
  else
    call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 23 Feb 2008 23:02:07
Message: <47c0ec3f$1@news.povray.org>
I agree with your most of your points. I've always been an advocate of
keeping as much out of the registry as possible. Contrary to popular
belief, many programs do not remove their registry entries completely,
leading to bloated registries and other problems. I've done a lot of
"registry surgery" over the years...
Another aspect is integration with other programs, such as modelers. I
would think it more convenient to read the pvengine.ini file and parse
it than to root around in the registry checking keys...
I'd much rather see it retain it's old form, easy to edit and modify.
Date: 24 Feb 2008 01:38:05
Message: <47c110cd$1@news.povray.org>
Vista compatibility :-(
	Thorsten, POV-Team
Date: 24 Feb 2008 01:39:02
Message: <47c11106$1@news.povray.org>
You have no real clue what you are talking about, do you?
	Thorsten
Date: 24 Feb 2008 10:55:19
Message: <47c19367$1@news.povray.org>
>> why this was done? The editor I can understand due to it's tight
>> integration with the Windows GUI manager. But why the pvengine.ini? Thx.
>     Thorsten, POV-Team
Ah, I see... Then I'm assuming this will alleviate some of the issues
with the "security model" now implemented in Vista... especially as
applied to User Account Control. Symantec has a very good paper on the
subject and goes into more detail concerning DEP and ASLR too.
Thx Thorsten for the info...
Date: 24 Feb 2008 16:58:11
Message: <MPG.222b9618592e96b898a109@news.povray.org>
In article <47c11106$1@news.povray.org>, tho### [at] trfde says...
y
on
> 	Thorsten
Ok, maybe I should say "some", not most. But seriously, the registry is
a major pain in the @$$#$#@$ ass. Its not secure when you need it to be,
too secure on new Windows platforms, when you don't want it to be, its
more easily corrupted than small stand alone files, and damn harder to
simply fix by recreating the part that broke (since it can break the
registry so bad you can't fix any of it), etc. It imho, has been, and
will always be, more trouble than its worth. A fair number of people are
starting to recognize the same thing and abandon it, in favor of going
back to something more like the old .ini method. So, I exaggerated, sue
me.
void main () {
  else
Date: 24 Feb 2008 17:05:35
Message: <MPG.222b97ead33b051198a10a@news.povray.org>
In article <47c110cd$1@news.povray.org>, tho### [at] trfde says...
n
> 	Thorsten, POV-Team
Umm. All one needs if the local the users documents folder is in, then
write your user files there. This is how most programs do it under *nix,
storing settings for the "user" in the "user's" document/program area.
Why bow to MS' broken system, when all its going to do is make it a
nightmare later on, when you find some case where you need access to
that stuff, but its not there. Heck, for that matter, the OS is doing
that anyway. User specific keys are now *stored* in a registry file
"in" the users own document path, rather than in the old monolithic mess
they had prior. But, it still means you are putting all your eggs in one
basket and can break the damn thing too easy making it near impossible
to fix dozens of such keys, especially if someone manages to glitch the
file, or even delete it. Recreating "one" file specific to the program
yours using, is manageable, not recreating one huge file that used to
contain stuff for 50 some odd programs. Its just nuts imho.
void main () {
  else
Date: 24 Feb 2008 22:15:42
Message: <47c232de$1@news.povray.org>
MS doesn't want you to bow to MS's broken system. That's why there's
both ...\local data\application settings and ...\application settings,
depending on whether it's machine-local or not.
Me, I've never seen why this is more of a problem than (say)
accidentally deleting /etc. But still, moving configuration into the
registry at *this* point is still a generation behind.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 25 Feb 2008 00:32:03
Message: <47c252d3$1@news.povray.org>
Darren New nous apporta ses lumieres en ce 2008/02/24 22:15:
A viable alternative would be to still use the INI files, but place them in the
user's folder, or the "all users" folder.
The first way, the settings will be user specific on a multi user machine.
The second way is more like the current 3.6 aproach, the same settings affect
all users equaly on a given machine.
The advantage, you only have to copy your current ini files to the new location.
History, in general, only informs us of what bad government is.
Thomas Jefferson
