POV-Ray : Newsgroups : povray.windows : cmedit.dll Server Time
1 Apr 2026 10:03:45 EDT (-0400)
  cmedit.dll (Message 1 to 8 of 8)
Subject: cmedit.dll
Date: 6 Feb 2000 23:22:36
Message: <389E4880.645EBD15@hotmail.com>
Does anyone know how to build cmedit.dll from the source on the ftp site
contained in the povwin_src\windows\codemax dir of the source archive
PLEASE send replies to pab### [at] hotmailcom as well as here
Subject: Re: cmedit.dll
Date: 7 Feb 2000 08:57:41
Message: <slrn89tjqm.v8.ron.parker@ron.gwmicro.com>
Quoting the README-BEFORE-UNZIPPING.TXT file from that directory:
This means that you will NOT be able to compile this project.
You are not meant to be able to.
The CodeMax VCL component is internal to the POV-Team and
has not yet been released (and probably never will be). It depends heavily
on the presence of the header files, also.
Note that you MAY NOT re-use any of this code anywhere else.
Sorry; ask here, get the answer here.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 8 Feb 2000 01:00:50
Message: <389FB100.E8615387@hotmail.com>
-where - I looked in ftp://ftp.povray.org/pub/povray/Official/Windows/
          & povwin_s.zip\windows\codemax
          & povwin_s.zip
          & all the reademe files in povwin_s.zip
and CANNOT find the file README-BEFORE-UNZIPPING.TXT or the below mentioned
text
The reason I ask is:
1 - To be able to add syntax highlighting for new keywords such as "photons"
& "noise3d" etc. would be useful.
2 - I have started a patch (for the windows & possibly other GUI platforms)
that keeps options & objects & textures & media etc. in memory between
renders, thereby eliminating parsing time altogether, which I crave to be able
to do, esp. when modifying one number such as x translation of an object or
parts of a colour or pigment map.
It basically takes persistent variables to another level and it will? be able
to convert scenes back and forth from text to memory - it (when it gets off
the ground) will use a tree, a properties window and several "link" objects
(which I am currently developing in a testbed) to represent a scene as it is
in memory graphically.  The strategy so far is
1- when converting to the GUI format to
    parse the scene - Done thanks to the POV Team
    duplicate the scene from the global Frame & opts structs into another pair
of Frame & opts structs (specific to the current scene) - in progress
2 - when rendering to
    skip parsing - in progress
    duplicate the scene back to the global one - in progress
    render as usual - Done thanks to the POV Team
3 - converting back to text to
    do some kind of reverse parse - in progress
    free the memory - in progress (will use destroy functions from the povsrc
core)
The reason for all this duplication is that I can't be bothered & am too lazy
to go through the core looking for functions referring to the Frame & opts
structs and modifying them to use a pointer to these passed to them as a
parameter.
The ability to build cmedit.dll would allow a "link bed" control to be put in
place of the CodeMax control.
I guess I'll have to do some thinking & devious message sending or just create
2 tab windows - 1 for CodeMax controls & 1 for my "link bed" controls and
switch between using a menu or toolbar command.
which compiler/s are the following lines specific to
#include <vcl.h> - standard compiler header ??
#pragma package(smart_init)
#pragma resource "*.dfm"
etc.
Bye -Pabs
Download 'us-ascii' (4 KB)
Date: 8 Feb 2000 10:45:48
Message: <slrn8a0egs.v8.ron.parker@ron.gwmicro.com>
>          & povwin_s.zip
>text
It was there in the 3.1e version of the source; if it's missing from the
3.1g source, it must be an oversight.  I'll email it to you if you'd like.
I wouldn't spend much time on this.  Syntax highlighting will almost certainly
be handled differently in 3.5.
Careful.  There's a lot more to POV's current state than what you see in the
frame and opts structs.  Also, everything will change in this regard with 3.5.
They're specific to Borland C++ Builder, but the comments I posted before are
correct: that source cannot be built without parts that you don't have and
can't get.  It is for educational purposes only.
Date: 8 Feb 2000 11:06:05
Message: <38A03EA6.3AAA40F9@pacbell.net>
 Many may not know, or care, but the CodeMax editor that is used with
the Windows version of POV-Ray was generously donated by it's author
as a custom version of a commercial program. Since this author expects
to make money from the sales of his commercial version he does not want
the general public having the ability to modify and redistribute it
without his direct control. Any feature changes to the editor then will
have to be done by the POV-Team in co-operation with of the original
author.
Date: 10 Feb 2000 22:21:34
Message: <38A3802C.DE9A9984@hotmail.com>
good - you could read this at runtime from a text/binary file instead of having an
unchanging struct in cmedit.dll or have the struct in the POV-Ray src so that
patches can use proper syntax highlighting for their new keywords.
When will 3.5 be out by the way. 8-)
I only have the 3.1a source - it's the only verson downloadable from the ftp site -
as indicated by ftp://ftp.povray.org/pub/povray/Official/Windows/README
I QUOTE "NOTE! The source code is still at v3.1a. It's not the source for 3.1g."
anyways I would like that file - please e-mail it to me.
> have to be done by the POV-Team in co-operation with of the original author.
I was talking about cmedit.dll not CMAX101.dll,  the latter being the CodeMax
control code and the former being the POV-Ray support code for the CodeMax control &
therefore I would not and connot even see the src for the donated version, therefore
there is no danger of profit loss.  And I do know AND care.
Oh really what else ?
I know there is a variable called filename but I am not that deep in the src to know
much more. (No need to answer this if you don't have the time)
Damn - well I suppose everything in my version will have to change as well - I hope
I can finish my patch before 3.5 comes out 8-)
Pabs
Bye
Date: 11 Feb 2000 01:10:21
Message: <38a3a7cd@news.povray.org>
In article <38A3802C.DE9A9984@hotmail.com> , Pabs <pab### [at] hotmailcom>
> to know much more.
About 350 more global variables distributed over 60 or so files.  Most of
them are critical for the correct operation...
        Thorsten
Date: 11 Feb 2000 08:14:54
Message: <slrn8a82qe.v8.ron.parker@ron.gwmicro.com>
I'm pretty sure the source that's currently in
ftp://ftp.povray.org/pub/povray/Official/Windows/povwin_s.zip is the 3.1g
source, regardless of what the README might say.  I suspect the README is
a little out of date (note that it's dated over a month before the source.)
