POV-Ray : Newsgroups : povray.windows : Deployment of POV-Ray on Windows 2000 in a school Server Time
21 Jul 2026 11:12:07 EDT (-0400)
  Deployment of POV-Ray on Windows 2000 in a school (Message 1 to 8 of 8)
Subject: Deployment of POV-Ray on Windows 2000 in a school
Date: 17 Jul 2003 16:19:31
Message: <20030717221931283+0200@news.povray.org>
I'm trying to create a Windows Installer package (.msi) for POV-Ray, so
I can deploy it on 11 or more computers in a school, through Windows
2000 Server.
As students are not supposed to have installation privileges, POV-Ray
would be installed on a machine basis, not a user basis (i.e. it would
be installed with admin / system privileges, but accessible from any
user). Herein lies the problem: the pvengine.exe binary has problems
recognizing the installaton path, which is apparently stored as per-user (
HKCU) registry key, not a machine-wide (HKLM) one.
I've found three different behaviours when trying to launch POV-Ray with
a different user than the one it was installed with:
A) it would complain about a missing "Home" key in the registry. That
one, however, was created (by the installation program) in both HKCU _
and_ HKLM (for whatever reason).
Code bit:
  getHome () ;
  if (HomePath [0] == '\0')
    MessageBox (NULL,
                "ERROR : Cannot find Home entry in registry.\n\n"
                "This entry should have been set by the installation
program.\n\n"
                "If you did not install using the correct installation
procedure, please "
                "do this before running POV-Ray for Windows.\n\n"
                "Otherwise, consult the README file that should have
accompanied this executable file.",
                "Critical Error",
                MB_ICONSTOP) ;
    return (1) ;
"getHome()" seems to look at "HKCU" first, and if that one fails, it'll
try with "HKLM" instead. That's fine. I dunno why I ever received this
error message then.
B) it would complain about not being able to access its INI files. One
would expect the program to try relative paths first, but it seems not.
Relevant code:
  if (stat (EngineIniFileName, &statbuf) != 0 || (statbuf.st_mode & S_
IFREG) != 0)
    if (debugFile)
      fprintf (debugFile, "INI directory not found\n") ;
    MessageBox (NULL,
                "ERROR : Cannot find INI directory in expected location\
n\n"
                "This directory should have been created by the
installation program.\n\n"
procedure, please "
                "do this before running POV-Ray for Windows. Otherwise,
consult the README.DOC "
                "file that should have accompanied this executable file.
                "Critical Error",
                MB_ICONSTOP) ;
    return (1) ;
This error message mentions a "README.DOC" file, which doesn't exist;
the "readme.txt" file consists mostly of information regarding the
rendering engine.
If the error message included the current "HomePath" var, that would
ease debugging greatly. Maybe getHome() returned the wrong contents?
[ C) it wouldn't launch at all, as in: it wouldn't react to it being
launched. This may be a Windows XP bug, however. ]
The process of creating the MSI package works by launching the "povwin35.
exe" setup file with specified parameters, and watching it through a
capturing tool. The parameters we're giving the setup are:
1. custom destination folder: "C:\Applications\Graphics\POV-Ray" (
adhering to school-wide standards)
2. no backup folder (as this isn't an upgrade install)
3. custom shortcut folder: "Graphics\POV-Ray"
4. no update checking (as we manually check for new program versions for
the whole network, then update the deployed packages)
It would then ask to do a test render, which works fine. Then we remove
all traces of the program, customize the created MSI package and run
that one instead. Running POV-Ray as the same user again would work.
Running it as a test user of one of the students, however, will give one
of the three problems A / B / sometimes C.
I suspect that even though the installer offers to install into a custom
directory, the app does not truly support this, and still expects at
least some of its files to reside in C:\Programs\POV-... - this, however,
is bad application design (and not something I'd expect from this
otherwise great program). As the source code is open
I'm not familiar with C much, so I'm not sure if I can help fix this,
but there is something wrong either with the Wise installer, or with
what happens at pvengine.exe launch time.
I'd appreciate any help.
<http://www.chucker.rasdi.net>
Subject: Re: Deployment of POV-Ray on Windows 2000 in a school
Date: 20 Jul 2003 14:44:25
Message: <3f1ae309$1@news.povray.org>
If you need an woring, tested automatic installtion for POV 3.5/Mega-POV you
can use the one here:
http://www.it-berater.org/smpov.htm for FREE.
You just drop it on any PC together with the "povray35.exe" and start it.
Everything else is done automatically by some busy WinRobots.
(Only for Windows PC's)
--Theo
Distributed Network-Rendering or Local SMP-Rendering. With SMPOV and
POV-Ray 3.5. * Download free at: http://www.it-berater.org/smpov.htm
"Soeren Kuklau" <use### [at] chuckerrasdinet> schrieb im Newsbeitrag
news:20030717221931283+0200@news.povray.org...
> Hi,
> 2000 Server.
> Code bit:
>   getHome () ;
>     MessageBox (NULL,
> program.\n\n"
> procedure, please "
>                 "Critical Error",
>                 MB_ICONSTOP) ;
>     return (1) ;
> error message then.
> Relevant code:
> IFREG) != 0)
>     if (debugFile)
>     MessageBox (NULL,
> n\n"
> procedure, please "
>                 "Critical Error",
>                 MB_ICONSTOP) ;
>     return (1) ;
> rendering engine.
Date: 21 Jul 2003 17:33:55
Message: <3f1c5c43@news.povray.org>
"Soeren Kuklau" <use### [at] chuckerrasdinet> wrote in message
It's also a bad assumption, because the program does not do this.
-- Chris
Date: 22 Jul 2003 08:33:31
Message: <3f1d2f1b$1@news.povray.org>
People like to make things ten times. I cannot recommend that to you,
Soeren.
The installer which is included with POV-Ray works very well and is TESTED.
Therefore we (from Winrobots see www.winrobots.com) just take this installer
to install the programm automatically. No MSI etc. is needed. Why use
complicated
technology to make a "repackaging" if its not necessary because everything
(Installation/Deeinstallation) is already there and tested from those people
who made the program?
Our "WinRobots" click the buttons etc. like any person would do it
"manually".
No chance to find a diffrence between a manual or our automatic installation
using WinRobots-Technology.
Of course if someone tries to make a "private repacking" of Software,
there is a real danger that something will NOT WORK under certain
conditions.
Several big Software Companies deny support if you "repack" their programms
with whatever technology. For good reasons.
--Theo
"Chris Cason" <new### [at] deletethispovrayorg> schrieb im Newsbeitrag
news:3f1c5c43@news.povray.org...
however,
> -- Chris
Date: 23 Jul 2003 17:14:34
Message: <20030723231433742+0200@news.povray.org>
Theo Gottwald * wrote on 22 Jul 2003 02:33  Uhr:
> Soeren.
I'm more of a lazy person, trust me.
> installer to install the programm automatically. No MSI etc. is needed.
> Why use complicated technology to make a "repackaging" if its not
> necessary because everything (Installation/Deeinstallation) is already
> there and tested from those people who made the program?
Because Windows 2000 Server works with MSI. That's why. The only other
choice offered is ZAP, which I wouldn't want to use even when forced to.
I'd like to know what Network Rendering has to do with automatically
deploying an application over a network, btw. What you're probably doing
is just letting the Wise Installer run in silent mode. I could of course
create a script that does something similar, but that sounds way more
complicated to me than just going the route I took.
As a sidenode, I think I fixed the problem.
Thanks anyway.
Date: 23 Jul 2003 17:18:51
Message: <20030723231850931+0200@news.povray.org>
Chris Cason wrote on 21 Jul 2003 11:28  Uhr:
> "Soeren Kuklau" <use### [at] chuckerrasdinet> wrote in message news:
>> custom directory, the app does not truly support this, and still
>> expects at least some of its files to reside in C:\Programs\POV-... -
>> this, however, is bad application design (and not something I'd
>> expect from this otherwise great program). As the source code is open
True; I'll take that back. There was apparently a Zombie entry in the
tested user's HKCU registry tree, which pointed to a C:\Progra...
location (I still have no idea how it got there, though).
Date: 25 Jul 2003 12:46:00
Message: <3f215ec8@news.povray.org>
Hi Soeren,
Wasn't meant as critics, was meant as a general statement, comparing
diffrent methods of installations.
See
http://groups.google.de/groups?q=MSI+repackaging+support&hl=de&lr=&ie=UTF-8&oe=UTF-8&selm=OIEdkOREAHA.60%40cppssbbsa04&rnum=2
I am quite shure, in your special case what you did is what was the best.
Especially as you solved your problem.
deploying an application over a network ...
I can tell that to you :-). Before you can render in a network you need to
install POV-Ray on each of those machines. And why do that "manually" if its
sooo easy done automatically? However you may still need a way to bring
those files on all the PC's.
>, btw. What you're probably doing is just letting the Wise Installer run in
silent mode.
To be honest I did never even know that this would work. maybe I don't
needed that ever.
Going away from POV-Ray, my statement was more general saying "How can
anyone be shure that a "repacked file " Will work under all circumstances?"
(see Link at top).
Thats not a question "How good" you can use all those repackaging-tools, the
question is just "How good can you know what needs to be done while the
installation". I saw those problems Chris told you about and thought the
article I read in the newsgroup.
It wasn't personal but I am just working with these installation things, so
I saw a chance to produce myself a bit :-))).
By the way ...  http://www.it-berater.org/download/down.pl?file=31  (Hope
you have XP Prof. somewhere :-).
Try this one and tell me :-) which installer we used in silent mode.
have fun
--Theo
news:20030723231433742+0200@news.povray.org...
> > Soeren.
> Thanks anyway.
Date: 30 Jul 2003 19:16:26
Message: <20030730191626197-0400@news.povray.org>
Theo Gottwald * wrote on 25 Jul 2003 12:46  Uhr:
> Hi Soeren,
> See
Sorry, won't work (the message ID OIEdkOREAHA.60%40cppssbbsa04 won't be
accepted).
> best. Especially as you solved your problem.
Thanks. The reason I opt for MSI repackaging is that once the package is
tested and fine, you can easily deploy it over >50 clients without a
software besides W2K Server (which we need running anyway).
Installing using Pov-Ray's Wise Installer simply didn't seem feasible
for me, especially because that's not at all what we're doing with other
software either.
> need to install POV-Ray on each of those machines. And why do that
> "manually" if its sooo easy done automatically? However you may still
> need a way to bring those files on all the PC's.
So, it's an automated installation? Like a snapshot or something?
>>run in
> silent mode.
> needed that ever.
> circumstances?" (see Link at top).
Since the link won't work for me, I suppose you mean an argument that
goes along the lines of this:
Repackaging
There are several tools around which can take a "snapshot" of a
machine's state before and after a manual installation, compute the
differences between the states, and bundle them up as an "installer".
The Wise product line provides good support for this, and Microsoft's
free tool (recently updated) provides bad support for it.
The main problem with this approach is that it fundamentally cannot work
reliably.  Installers can vary their behavior depending on the exact
initial state of the machine, such as the OS version or the presence/
absence of other installed software.  So the repackaged installer will
almost never do exactly the same thing that a fresh installation would,
unless the target machine is completely identical to the original
machine.
In addition, for every new release of an application, you will need to
repackage it again.  And there are other disadvantages which even
Microsoft recognizes.
For these reasons, I think repackaging is a very bad idea and I advise
against it.
( From <http://unattended.sourceforge.net/installers.html> )
> tools, the question is just "How good can you know what needs to be
> done while the installation".
I'm aware of that problem; however, I have yet to run into any real
trouble regarding that. POV-Ray is open-source anyway, so we're pretty
much in control of what it *might* do, right? The only huge software
package that is *not* open-source and that we use regularly (since the
teachers won't adapt to OpenOffice.org) is MS Office - well, and that
one *is* available as MSIs already (has been since version 2000 / 9.x),
so we don't need repackaging in that case. :-)
It's school computers. We don't need a lot of software; nothing
particularly complicated. I try to use simple and / or free software
whenever I can - 7-zip instead of WinZip or WinRAR, IrfanView instead of
ACDSee, MediaPlayer Classic (MPC) instead of RealPlayer, QuickTime or
Windows Media Player.
So what I'm doing is spend at least a day analyzing on at least two
different machines what a program's installer does, and then I let a
software like Wise Package Studio build an MSI of that progress. And
that would have worked just fine with POV-Ray if only there hadn't been
that weird wrong entry. Anyways.
> about and thought the article I read in the newsgroup.
> things, so I saw a chance to produce myself a bit :-))).
I'm sorry that I might have sounded annoyed. I was just frustrated that
I couldn't find what's wrong. Anyway, as said, I actually *did* now -
the user we've been testing it on had a wrong "Home" entry in the POV-
Ray HKCU tree structure. *Why* is another question, but do I wanna know? ;-)
> Hope you have XP Prof. somewhere :-). Try this one and tell me :-)
I'm sorry, but I'm on a trip to Canada right now, and only have Mac OS X
here. I'll have a chance to give it a try in two weeks.
Thanks again and see you around,
